andz
F-14 Swing Wing
Fri Jan 09, 2009 8:28 pm
Disclaimer: search is frustrating.
Top Gun is on TV right now and once again I wonder... how is the F-14 swing wing operated and controlled?
Moose135
RE: F-14 Swing Wing
Fri Jan 09, 2009 10:07 pm
Here is a pretty good graphic of the inner workings of the swing wing.
http://www.anft.net/f-14/f14-detail-wsm.htm
In normal operations, it it controlled by an air data computer based on airspeed (Mach number), to provide the optimum L/D ratio. The pilot could switch to manual mode and position the wing as desired. In normal operations, the wing could sweep between 20 and 68 degrees, but when parked, could move to an "oversweep" of 75 degrees (where it would overlap the stabilators) to reduce the footprint for carrier parking. In an emergency, the aircraft could land with the wings swept back at 68 degrees, or with asymmetrical sweep.
LMP737
RE: F-14 Swing Wing
Sat Jan 10, 2009 4:18 am
Quoting Moose135 (Reply 1):
http://www.anft.net/f-14/f14-detail-...m.htm
An interesting side note the box beam and the wingbox were both titanium. That's one of the reasons the structure of the F-14 was able to take the punishment of carrier ops. In fact in most crashes the box beam was relativley undamaged.
andz
RE: F-14 Swing Wing
Sat Jan 10, 2009 5:18 am
Thanks, I still find it amazing that a single pivot point can take the stresses associated with flight.
Lemmy
RE: F-14 Swing Wing
Sat Jan 10, 2009 8:29 pm
Does anyone know what type of bearing was used in the pivot? Was it a roller bearing, or some kind of bushing? How often did it have to be serviced?
(Sucks talking about the F-14 in the past tense ...)
I am a patient boy ...
KFLLCFII
RE: F-14 Swing Wing
Thu Jan 15, 2009 3:44 am
Speaking of...
http://www.anft.net/f-14/f14-detail-wsm-04.htm
Was this intentional?
Could it be done on command?
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
Moose135
RE: F-14 Swing Wing
Thu Jan 15, 2009 4:47 am
Yes it was intentional. That was Tomcat #3, one of the test aircraft used by Grumman. It was done during a series of test flights to see if the aircraft could be controlled and landed in an asymmetrical condition. The right wing was locked in the 20 degree position, then they varied the sweep angle of the left wing to determine handling characteristics. They determined that with the wing swept back to 60 degrees (just short of full sweep) the aircraft could still make carrier landings. That aircraft now resides at the Cradle of Aviation Museum on Long Island.
And no, it could not be swept that way in normal operations.
LMP737
RE: F-14 Swing Wing
Mon Jan 19, 2009 5:28 pm
The wing sweep actautors were interconnected on teh F-14. Obviously this was in case a hydraulic sustem failure. I remember the airframers would get in a tizzy if you moved the wings with only one hydraulic system running. Puts a lot of strain on the crossover shaft.
Users browsing this forum: MrHMSH, wimdemeester and 18 guests
