AC_B777
Space Shuttle Piggyback Questions
Sun Jan 11, 2009 12:51 am
I was looking at pictures of the shuttle riding piggyback on the 747 and was wondering, does anyone (pilots, astronauts, technicians) ride in the shuttle while it is being brought back to Kennedy from Edwards?
I would assume there would be people onboard in case of a breakaway situation due to an emergency on either the 747 or shuttle.
Does anyone have any info on this and what procedure might be? Also, how would they get in the shuttle? Surely there are'nt any airstairs/ladders that can reach to the hatch on the shuttle. Probably from the mating platform?
In life, some days you are the bug..... some days you are the windshield!
474218
RE: Space Shuttle Piggyback Questions
Sun Jan 11, 2009 1:35 am
Quoting AC_B777 (Thread starter):
No
I would assume there would be people on board in case of a breakaway situation due to an emergency on either the 747 or shuttle.
No
There is none.
They can't.
The Shuttle just sits there and rides back to the Cape.
unattendedbag
Sun Jan 11, 2009 4:47 am
Question directed back to AC_B777:
what would a passenger do if the Shuttle did break away???
Slower traffic, keep right
zanl188
Sun Jan 11, 2009 11:12 am
Quoting UnattendedBag (Reply 2):
Strictly speaking I suspect there are no passengers however...
For the Approach and Landing Tests (ALT): the 2 crew aboard the orbiter had ejection seats. 747 crew would have bailed out using an escape chute leading from the flight deck and out the belly - window bursters would've been used on the main deck to depressurize the hull.
On the ferry flights the orbiter is crewless, powered down, and flight controls locked. IIRC there are no airborne escape provisions for the 747 crew- escape system was deactivated following the ALT.
AC_B777
Sun Jan 11, 2009 11:42 am
Well, thanks for the replys. I was a little surprised to learn that nobody would ride in the shuttle during piggyback.
Well, I did'nt mean 'passengers' but people who were qualified to fly the shuttle to a landing site if some major problem happened with the 747.
Thorny
Sun Jan 11, 2009 6:14 pm
Quoting AC_B777 (Reply 4):
The Shuttle is not crewed during the ferry flight. The fuel cells are not active during the ferry flight (no electrical power), and the Auxiliary Power Units are not active during the ferry flight (no power to the control surfaces.) There are also no explosive bolts to separate the Shuttle from the 747 as there were during the Approach and Landing Tests, and the ferry flights use a shorter nose-strut, not the longer strut that gave a high angle of attack to allow clean separation during the ALTs.
If the Shuttle broke away during the ferry flight, it would almost certainly not be a clean break, and would probably take the 747 with it, both breaking up in the event. If by some miracle all three attach points failed simultaneously, the Shuttle would probably impact the 747's tail and then drop like a rock, leaving the 747 crippled and its crew hopefully bailing out.
unattendedbag
Thu Jan 15, 2009 11:12 pm
Quoting ZANL188 (Reply 3):
that would be a sight to see!
you are aware that as the shuttle returns to earth, it is in effect a glider. it has no working engines and the odds of "flying" it to a landing site would be next to impossible.
Im pretty sure NASA wouldn't want to put crew in the shuttle for the rare event that the shuttle becomes detached from the host, only to have them try and safely "crash land" the shuttle and save an already aging orbiter. That seems like putting two lives at risk for very little reward.
vikkyvik
Fri Jan 16, 2009 6:35 am
Quoting UnattendedBag (Reply 6):
Especially considering the fact that the shuttle isn't a particularly efficient glider.
A commercial airplane could glide for over 100 miles from cruising altitude. By comparison, the shuttle is still at something like 70,000 feet when it's around 50 miles from touchdown. If it were to glide from airliner cruising altitude (say, around 30,000 feet), you'd probably have somewhere in the region of 15-20 miles of glide distance to work with, far as I can tell. That doesn't give you many - if any - options for landing sites.
bmacleod
Sat Jan 17, 2009 7:15 pm
The shuttle is, as many engineers have quoted, a flying brick without its fuel.
If it were to break away from the 747 it is virtually impossible to make a successful landing because of its shear weight and limited maneuverability so close to the ground.
"What good are wings without the courage to fly?" - Atticus
rwessel
Sat Jan 17, 2009 7:56 pm
Quoting Bmacleod (Reply 8):
They did drop Enterprise from the first SCA five times for the initial landing tests. And the drops were from 19,000 to 26,000ft. Of course those were planned and carefully set up.
Max Q
Sat Jan 17, 2009 11:48 pm
Check out 'Moonraker' with my favourite Bond, Roger Moore for an inflight 'theft' of a space shuttle AC777 !
