raysaron
Propellers C-46 And C-47
Tue Sep 22, 2009 1:34 pm
What were the diameters of the propellers used on
the C-46 (three bladed and four bladed) and C-47 aircraft?
ptrjong
RE: Propellers C-46 And C-47
Tue Sep 22, 2009 2:44 pm
C-47: 11.63 ft according to http://www.philskies.net/library/Kom...F-Putangina/PAFAI-C47/aircraft.cfg
Why on earth do you need to know?  Smile
raysaron
Wed Sep 23, 2009 10:44 am
Ptrjong:
I have a diecast model of a C-46 with a broken propeller. The scale is 1/144.
Aero Club (England) makes a C-47 propeller in that scale. With your info,
I know that the C-47 propeller is too small (11 feet vs 14 feet). Thanks for
your reply.
Ray
ptrjong
Wed Sep 23, 2009 11:03 am
Yes, I guess it's rather larger since the C-46 is a much larger aircraft.
Peter
[Edited 2009-09-23 04:03:31]
L-188
Sun Oct 04, 2009 5:00 am
Which C-46 prop are we discussing?
I am aware of 2, a 3 bladed hydraulic unit, I want to say it was an Hamilton Standard.
The other one was basicly the same 4 bladed electric prop that was used on the P-47, P-61 and B-26.
raysaron
Sun Oct 04, 2009 8:42 am
The broken prop on my 1/144 scale C-46 is the three bladed prop. If I could find a correct prop (three or four bladed) I'd go with either.
FBU 4EVER!
Tue Oct 06, 2009 11:47 am
Could the 3-bladed Ham. Std. prop be identical to the ones fitted on DC-4's?
"Luck and superstition wins all the time"!
raysaron
Tue Oct 06, 2009 12:10 pm
FBU:
good suggestion, the DC-4 propellers (each) are 7' 4".
I will see what is available in 1/144 scale
thanks
Ray
L-188
Wed Oct 07, 2009 2:55 am
Quoting Raysaron (Reply 7):
FBU:
thanks
Ray
I want to say no because DC-4's ran Wrights and the C-46 had Pratts.
actually now that I am thinking about it....The Corsair also was running R2800's and the early ones had a three bladed prop..I don't know who the maker was though.
L-188
Wed Oct 07, 2009 3:13 am
Dude I must be getting senile.
The FAA has an internet site will all the Type certificate data sheets on it.
for the C-46E TCDS #A-786
http://www.airweb.faa.gov/REGULATORY...D112485256724004DDC5C?OpenDocument
Propellers
2 Curtiss Controllable Electric C542S-B/836-17C2-0
Pitch: High 45° at 54" sta.
Low 15° at 54" sta.
2 Ham. Std., Hubs 23E50, Blades 6491-0 to 6491-3 incl.
Max. Diameter 15' 3/8", Min. Diameter 14' 8-1/2".
Min. low pitch setting, 10° at 72" sta.
FBU 4EVER!
Thu Oct 08, 2009 9:01 am
The DC-4 used almost exclusively the P&W R-2000 Twin Wasp. Some Canadian developments, almost all prototypes, used a variety of P&W R-2800, Wright R-1820, and on the DC-4M, R.R. Merlins.
FBU 4EVER!
Thu Oct 08, 2009 9:28 am
Check aeroclub.com.uk and you'll find a set of 4 white metal DC-4 props in their catalogue.
FBU 4EVER!
Thu Oct 08, 2009 10:38 am
Quoting L-188 (Reply 8):
In both cases they were Ham. Std's. The P-47 used 3 different Curtiss Electric props and 1 type of Ham. Std. The B-17 had Wright R-1820 engines and used Ham. Std. props. The B-24 had P&W R-1830 with Ham. Std. props, except for the LB-30 Liberator II which used Curtiss Electric props.
FBU 4EVER!
Thu Oct 08, 2009 11:02 am
Disregard my previous post on aeroclub's site. It should be www.aeroclub-models.com. The code for the 1/144 DC-4 props is W030. You get 4 of them in the set.
Users browsing this forum: GrayMatter and 1 guest
