747400sp
Any Photos Of Proposed CFM-56-2 Powered B-52?
Wed Mar 03, 2010 3:00 am
Around 2006, I found out that there was a proposed program I believe in the 80's, to re-engine B-52s by replaceing their eight T-33s with six CFM-56-2. If anybody has any photos of how this re-engine B-52 would have looked, please post it? It would have been cool to see a jet with six CFM-56.
tf39
RE: Any Photos Of Proposed CFM-56-2 Powered B-52?
Wed Mar 03, 2010 5:13 am
Unfortunately I don't have any photos/images but I thought the proposal was only for four CFM engines. At 34K pounds of thrust each, that should be enough since two TF-33 produce the same thrust. Hopefully someone has some pictures though
HaveBlue
Wed Mar 03, 2010 5:49 am
Quoting tf39 (Reply 1):
I agree with tf39 I think it was only 4 engines, which makes sense since they already have 4 pylons ready to go for that and 6 would be overkill.
Here Here for Severe Clear!
sasd209
Wed Mar 03, 2010 7:38 am
Yes, I think the 6 engine idea would most likely result in a re-designing of the wing pylons? I would think that with the power available with more modern engines, as you have earlier said, this could easily be done with the 4 pylons and existing more modern engines than they currently fly with?
a380heavy
Wed Mar 03, 2010 9:15 am
Found this image of the B52 re-engined with Rolls-Royce RB211's which will give you some idea of how the '52 would look with modern engines.
http://homepage.ntlworld.com/rez.manzoori/fakes/524-buff.jpg
Flown in:732,733,734,738,742,752,763,772,F27,DC9,MD-11,A300,A332,ATR72,DHC-6,Bell206,C172,Auster,PA-28
N328KF
Wed Mar 03, 2010 2:17 pm
Just two GE90-115Bs would do the job, too! But they'd never fit.
kc135topboom
Wed Mar 03, 2010 3:07 pm
Quoting HaveBlue (Reply 2):
Quoting sasd209 (Reply 3):
The mid 1980s B-52 reengine proposal was for 6 CFM-56-2B engines (F-108-100), the same engine then going on the KC-135R, and it would have looed like a modern day B-47E. The reengine proposal was for all B-52G/H airplanes as it was before the START treaty that scrapped the B-52G. The engine struts would have been changed in the proposal, as well as brakes, landing gear, modifications to electrical and hydraulic systems, and adding a duel APU for "quick-start" (same engines and APUs as the KC-135R), etc. IIRC, the costs were estimated at around $45M-$50M per aircraft, compared to the $29M costs to reengine the KC-135R. The B-52 reengine proposal was never funded.
Quoting A380Heavy (Reply 4):
Correct, but that proposal was also never funded either.
