4tet
Why Not Sell Some Of The "stuff" On Davis Monthan?
Wed May 26, 2010 8:36 am
Hi A.netters, I don't know if this has been discussed before.
I think I would be a great idea for the DoD to have an extra income (and also for aviation enthusiasts  ) to sell some of the stuff on Davis Monthan.
They could demilitarize some of the F15's, Phantoms and I'm even thinking of the C-130's and sell them off.
They would save the cost of having them stored, plus they also could provide maintenance so they can have some kind of income.
Seeing the photos on A.net and also looking on google earth ( as of Nov.10' ) I see 100+ C130's, 70+ F15's, 110+ Phantoms etc...
I'm pretty sure they would find some buyer!!
R.
kc135topboom
RE: Why Not Sell Some Of The "stuff" On Davis Monthan?
Wed May 26, 2010 11:34 am
About half the airplanes stored at DM are 'on hold' for possible return to the US fleet, some 15% are used to harvest parts, and 10% are on hold for FMS. That leaves about 25% of the aircraft available for sales, but many are just to worn out to be flown ever again and will be scrapped. Some aircraft do get sold, mostly as water tankers to fight wild fires. But those airplanes need an FAA certification to be able to legally fly.
GPHOTO
Wed May 26, 2010 12:27 pm
Quoting 4tet (Thread starter):
Hello Roger,
Aircraft are stored at DM for a number of reasons, but one of the key ones is for reclamation of parts to keep other aircraft in the fleet flying. As most parts on an aircraft, especially a military aircraft are limited in availability, this process can provide a cost effective solution. For example, it is apparently cheaper in many cases to keep, salvage, inspect and approve a part from one of these aircraft than to try and source new original parts from the manufacturer. This is especially significant since by the time aircraft start arriving at DM, the type is likely to have been out of production and manufacturers are likely to have either stopped making parts or changed to newer (different) ones which may not be compatible. New parts are more expensive than reclaimed ones in any case. I understand that this processing at DM saves the US taxpayer significantly more money in reduced costs than it takes to run the place, so in effect, it already makes a healthy profit.
Older models of a type still often share many, many parts in common with their newer, upgraded sisters. A good example of this is the number of civilian Boeing 707 aircraft stored there for many years. These are used as parts sources for the 135 fleet. I'll bet this was a pretty cost effective investment on the Air Forces part.
Of course many aircraft are also stored for shorter periods before being rotated back into service and some are sold to other air arms, especially less weaponised vehicles such as light transports, trainers and helicopters. The dry atmosphere and suitable protection techniques ensures storage corrosion is minimal.
This is probably one of the most 'green' places in the aviation industry, where the environmental three 'R's - Reduce, Reuse, Recycle - are followed to to the ultimate level!
An interesting place, I'd love to visit one day.
Jim
Erm, is this thing on?
4tet
Wed May 26, 2010 5:32 pm
Quoting KC135TopBoom (Reply 1):
I think is fairly possible that most of that half 'on hold' won't be back to service, so assuming this maybe it would be even more profitable to sell them and with that money buy spares for other aircraft (In the case of the F15's for example).
Then comes the F4's that are fully retired in almost every NATO ( I think Germany is retiring them on 2012 ) except Japan, who's looking for a replacement. Then it makes no sense IMHO to store them then, because I don't think they're coming back to service with the F14, F16, F18, F22 still in service ( JSF? ), all much more capable than the F4. They're very well stored, see this photo ( http://www.panoramio.com/photo/27407366 ).
So, could I arrive to DM and for example 'ask' for an F4 ? ( If I had the money obviously, lol)
Salut
R.
bikerthai
Wed May 26, 2010 6:49 pm
Quoting 4tet (Reply 3):
It may be easier for you to purchase a Mig 25.
Some F-4s are reincarnated as target drones . . . a really short second life I'd say.
bikerthai
KPHXFlyer
Wed May 26, 2010 9:56 pm
I recall when the USN retired the F-14 from active service (2005?) that Iran asked somewhat nicely if they could use them for spare parts as they have been flying F-14As from the days of the Shah. I believe the US said "not just no, but HE!! NO!"
So I think it will be a while yet before they release F-4s or F-14s for civilian use though it's not unheard of for former fighter planes converted to civilian use. But boy, could you imagine the fuel costs for either an F-4 or F-14? Although, such as with Hummers, if you can afford to buy one, fuel usually isn't a major cost factor.
HaveBlue
Wed May 26, 2010 10:17 pm
Quoting KPHXFlyer (Reply 5):
There already is a civilian F-4... the Collins Foundation has one. Unless you acquire an Iranian F-14 you will never see a civilian flying F-14... the CIA/US Government made sure of that.
Here Here for Severe Clear!
4tet
Wed May 26, 2010 11:04 pm
Quoting HaveBlue (Reply 6):
Does really make sense to stop civilians from buying F14 since its technology its pretty obsolete vs. 4th and 5th generation fighters?
They could demiliterize them "just in case"
Editing: Plus, economically, some (I don't know, let's say 1M or 2M for a F4?) at 3% - 4% interest, annually it's between 30k - 80k so you can certainly buy some parts with that I suppose
[Edited 2010-05-26 16:09:14]
KPHXFlyer
Wed May 26, 2010 11:07 pm
I didn't know that, thanks!
Iran also flies F-4s...do you know if the US government put similar restrictions on mothballed F-4s as the F-14s?
kingairta
Thu May 27, 2010 1:03 am
All the US's F-14s outside of a museum have been destroyed as a means to prevent Iran from getting spare parts. So as a result the only ones that could be "civilionized" would have to come from Iran.
kc135topboom
Thu May 27, 2010 12:31 pm
The F-4 is still flown by Israel, Turkey, Egypt, and Greece, too.
boeingfixer
Fri May 28, 2010 3:22 am
Quoting KC135TopBoom (Reply 10):
Israel no longer flies the F-4. You can add Germany, Japan, Republic of Korea Air Force and of course the USAF into that list though.
John
Cheers, John YYC
GPHOTO
Fri May 28, 2010 7:27 am
I see that one of the F-4's has been earmarked for a museum in the Netherlands. I imagine several others will go the same way with the QF-4 program winding down and Germany retiring their F-4's soon. Don't know when the other nations plan to finally withdraw theirs, but there are still a few years worth of 'spares duty' required from the desert F-4's yet.
Jim
4tet
Fri May 28, 2010 9:47 am
Quoting bikerthai (Reply 4):
I suppose the point then would be the spares and the manteinence, much difficult than the F4 in the western countries.
Could the F4 became the 'new' L-39? I mean in terms of private users that fly them, for aviability and easy to find spares, the large number built ( 5000+ ), and the 'low price' ( US$2.4 million when new as per wiki )
Spacepope
Fri May 28, 2010 12:41 pm
Also for example the US DoS has just ordered 120 remanufactured SeaKings, which are also coming from AMARC. new Zealand has taken delivery of 10 Seasprites in the past few months as well, and stred F-16s will be the source of Romania's 24-unit order, if it ever goes through. Italy did a similar thing with their F-16As, though they've managed to destroy 5 so far.
I personally think older F-16A/Bs should be used in the CONUS by ANG units, most in storage have far fewer airframe hours than active -C models. There's a stink here because the Buckley AFB units are flying ones beyond their normal lifespan (8000 hours).
n901wa
Fri May 28, 2010 3:06 pm
I wish they would allow some Stored Aircraft to be sold. I would love a TA-4 or a HH-3H. In fact they had a huge sell off of TA-4's and A-4M's and in the govt. Auction stie 100 percent of the aircraft had to be reduced to no more then 12 inch squares. I know they are affraid of selling Tactial Aircraft off, for fear that someone will sell them overseas, but you can buy and import anoher country's Tactial aircraft ( The Sea Harrier in VA and the EE lightining and the Drakens and Migs and Su's that have shown up) but you can't get a TA-4 here. Also on the Tomcats the scuttlebutt was the DOD was affraid of letting some end up in overseas museums for fear of that some items would be sold off, even though most Tomcats in US were gutted real bad for fear of Tomcat parts showing up on eBay and going overseas. The funny part is most Warbirds that were sold off made it out of the scrapping that went on after WWII and are great reminders of our Avation History, but sadly we will never see a bunch of Jets flying from the 80's Flying the same way. I do hope a few more A-4's and F-4's make it out intact and a Intruder or Prowler, a Corsair II and a Viking and F-15 , F-111 and even a few C-141's make it out one day. Can you imagine 20 years from now a Fly by with a A7, F-4U at a airshow.   Oh and I forgot the Collings guys are trying to get a F-105D flying
Users browsing this forum: cpd, Google [Bot] and 1 guest
