connies4ever
Skydiving From The Edge Of Space
Mon Sep 06, 2010 1:33 pm
Hopefully this is the correct forum for this thread. I'll move it if people suggest Non-Av.
Anyhoo, link goes to the Guardian article about two people vying to become the first supersonic skydivers, jumping from about 120,000 ft. One, Fournier (French) I knew about as he has been trying for some time to launch from North Battleford, Saskatchewan, unsuccessfully so far due to a host of problems. He's getting up in years, too. The other, Baumgartner (Austrian) I didn't know about. But, he has Red Bull behind him.
http://www.guardian.co.uk/science/20...gartner-michel-fournier-supersonic
I wish both gentlemen well, but, as Rummie once said, there are some unknown unknowns here.
474218
RE: Skydiving From The Edge Of Space
Mon Sep 06, 2010 2:40 pm
Quoting connies4ever (Thread starter):
Been done before: http://en.wikipedia.org/wiki/Project_Excelsior
connies4ever
Mon Sep 06, 2010 9:05 pm
Quoting 474218 (Reply 1):
Kittinger is part of the Red Bull team (mentioned in the article).
a) Kittinger didn't get as high as these dudes plan to go;
b) Kittinger didn't go supersonic, which these guys plan on.
What happens at the sonic boundary vis-a-vis shock interaction with the suit is really an unknown unknown.
HaveBlue
Tue Sep 07, 2010 12:28 am
Quoting connies4ever (Reply 2):
Kittinger certainly did go supersonic, a record for which he is famous for (the only human to do it without a vehicle). The speed of sound is not 740mph at that altitude and temperature...
And while his 102,000'+ jump may not be quite as high as the planned 120,000' jump... I'm not sure there's anymore challenges or difficulties between those 2 altitudes. I'd wager its about the same.
[Edited 2010-09-06 17:36:36]
Here Here for Severe Clear!
connies4ever
Tue Sep 07, 2010 12:21 pm
Quoting HaveBlue (Reply 3):
I realise Mach 1 is not the same at that altitude as at sea level, or even in the tropopause.
FWIW, Wikipedia does not mention him going supersonic, nor any of the citations:
http://en.wikipedia.org/wiki/Joseph_Kittinger
Nor does this one, which might be considered semi-official. It does note "approaching the speed of sound" ...
http://www.centennialofflight.gov/essay/Dictionary/kittinger/DI29.htm
zanl188
Tue Sep 07, 2010 12:29 pm
If there's no significant difference between 102Kft & 120Kft I suspect someone would have done it a long time ago....
Seems to me the difficulty is not so much the jump (although that remains to be seen) but getting to altitude in the first place. Are scientific/experimental balloons getting to 120Kft? and with what kind of payload weights?
connies4ever
Tue Sep 07, 2010 3:11 pm
Quoting ZANL188 (Reply 5):
Yes they do, and generally are intended to study upper atmospheric winds and to do some relatively persistent studies of the mesosphere and/or ionosphere.
I agree getting the jumper up to altitude is probably the big issue, since a suit problem on the way up would quite possibly be fatal. Well, it would on the way down as well, depending on where it happened:
http://en.wikipedia.org/wiki/Nick_Piantanida
HaveBlue
Tue Sep 07, 2010 3:57 pm
Quoting connies4ever (Reply 4):
I had got this from Balloonlife.com, and had heard long, long ago that Kittinger had went supersonic. I dismissed Wiki because though I use it a lot and love it, it's not the Bible.
http://www.balloonlife.com/publications/balloon_life/9510/balloonm.htm
"Kittinger followed this flight with two more. Excelsior II launched on December 11, 1959 and rose to a height of 74,700 before Kittinger left the gondola. His final flight in this series, Excelsior III, took place on August 16, 1960. Kittinger piloted his craft to an altitude of 102,800 feet before exiting the open gondola. On the descent Kittinger became the first man to exceed the Speed of Sound without an aircraft or space vehicle. It is still the highest parachute jump ever. The freefall lasted four minutes and thirty-six seconds, a record."
But alas you were correct, so my apologies. Here is an excellent article that has many quotes about Kit going supersonic, and yet explains why this is not true, and why even though it's not true why it is widely reported as having happened.
http://webcache.googleusercontent.co...personic&cd=11&hl=en&ct=clnk&gl=us
Friend, Tim. "Captain's jump put NASA on the map." USA Today. 12 February 1999. "Kittinger fell for four minutes before his main chute opened. In the vacuum of the upper stratosphere, his body accelerated to 714 mph, breaking the sound barrier."
Hamilton, Tom. "Balloonmeister - Joe Kittinger." Balloon Life. October 1995: 41. "On the descent Kittinger became the first man to exceed the Speed of Sound without an aircraft or space vehicle."
rlwynn
Tue Sep 07, 2010 10:11 pm
He may have exceeded the speed of sound in ground speed. But I do not see how it would be possible to break the sound barrier without thrust.
I can drive faster than you
connies4ever
Tue Sep 07, 2010 11:37 pm
Quoting rlwynn (Reply 8):
Gravity, the Big G, provides all the thrust you need in this situation.
MD11Engineer
Wed Sep 08, 2010 8:02 pm
He didn´t need thrust. He had gravity to provide the necessary force.
Jan
Users browsing this forum: cumulushumilis and 1 guest
