bigbird
Oldest Usaf Aircraft
Thu Dec 30, 2010 8:23 pm
With all of the talk about the KC-X I was wondering what the oldest aircraft in the USAF is. It is probably a KC-135 and if so does anyone know the serial number? Even if it is not a KC-135 can someone tell me what is the oldest tanker still going? Also are there any older ones in other branches of US services. The U S Navy
Beaver at PAX River comes to mind.
bigbird from georgia
hka098
RE: Oldest Usaf Aircraft
Thu Dec 30, 2010 9:09 pm
I would tend to think some of the B-52s, still in service, are up there in age.
mechatnew
Fri Dec 31, 2010 12:16 am
With the retirement of the T-37 Tweet last year I think that a Fiscal year 1957 KC-135R would be the oldest in the USAF. None of the 1955/56 KC-135A/E were converted to 'R' models. Maybe 57-1419 of the 117ARS Kansas ANG. The B-52Hs are 1960/61. There are a few 1960/61/62 T-38Cs ,and 1961/62 C-130Es still in service.
As for the USN/MC I belive you are corect about the U-6A Beaver. Most of the KC-130Fs have been retired, but I think there are a couple still in service. These were based on the C-130B and would have been delivered in the early 1960s. The CH-46 are from the mid 1960s.
ebj1248650
Fri Dec 31, 2010 1:35 am
Quoting mechatnew (Reply 2):
That sounds logical. I presume there are absolutely no more piston engined airplanes anywhere in the USAF?
Dare to dream; dream big!
HaveBlue
Fri Dec 31, 2010 3:15 am
Quoting ebj1248650 (Reply 3):
According to Wiki there are still a few T-41s (Cessna 172) used by the Air Force Academy and Flight Team. It was my guess that they still used them, I just wasn't sure where.
Here Here for Severe Clear!
zanl188
Fri Dec 31, 2010 4:52 am
A model Predators are piston powered.
Moose135
Fri Dec 31, 2010 1:26 pm
Quoting ZANL188 (Reply 5):
That's a drone - real airplanes have pilots...
kc135topboom
Fri Dec 31, 2010 1:37 pm
Quoting HaveBlue (Reply 4):
The USAFA still has, I believe 3 T-41Cs in use. The USAF purchased the T-41A (C-172E) in 1964, and the T-41C (C-172F) in 1966. The US Army bought the T-41B (also a C-172E) in 1964 and 1965.
Several USAF T-41A/B/Cs were still flying in USAF-MWR Areo Clubs as recently as a few years ago, I don't know if the still have them.
The T-41A/B had a lever to operate the flaps, the T-41C had electricly operated flaps.
The oldest jet still flying in the USAF is KC-135R tail number 57-1419, ordered in FY 1957 and delivered in 1958. There are a number of 1957 and 1958 model KC-135Rs and several 1958 model KC-135Ts still on active flying with the USAF, ANG, and USAFR. The remaining B-52Hs are all FY 1961 and 1962 buys.
mechatnew
Fri Dec 31, 2010 2:46 pm
In terms of piston engine aircraft still in service. I think the USAF Academy, besides the T-41s,has a least one Cessna 150, , with no military designnation. The US Army had 2 Cessna O-2A's, but I think they were just retired a few months ago, while the US Navy still has one. The US Army used to have 2 Cessna 182s at its Academy, and 2 AN-2s, but I am not sure if they are still in service. The US Navy has at least 2 U-6As[DHC-2 Beaver], and one U-1A [DHC-3 Otter ] with the Test Pilots School.
zanl188
Fri Dec 31, 2010 5:07 pm
Quoting moose135 (Reply 6):
Still it's piston powered... and probably expending more ordinance than any USAF mann, er, "crewed" aircraft at the moment....
2H4
Fri Dec 31, 2010 5:54 pm
Quoting mechatnew (Reply 8):
Two...both with N-numbers, and both registered to the United States Air Force:
Photo © Je89 W.
http://www.flickr.com/photos/woodfinx/2792607740
Intentionally Left Blank
hka098
Fri Dec 31, 2010 6:01 pm
Quoting KC135TopBoom (Reply 7):
1958! That says something about the manufacturers and maintainers of this aircraft.
covert
Fri Dec 31, 2010 9:31 pm
The 557th Flying Training Squadron (US Air Force Academy) operates piston engined aircraft. They have T-41s, T-51s, and T-52s. (Cessna 150, 172, and Diamond DA40 military designations) Additionally, several of these aircraft are found in Aero Clubs donated as surplus. They now bear N registrations, however.
It has also been mentioned that Predators are piston powered. The US Army especially operates several smaller UAS' that are powered by piston engines (Shadow, Hunter, Warrior A, etc.)
none
B727LVR
Fri Dec 31, 2010 9:37 pm
Quoting covert (Reply 12):
Not to get too far off topis but the PUMA uses the 3 cylinder Smart car engine.
Back on topic...
I am amazed that the KC-135 fleet has older aircraft than the B52 fleet. I would have thought it would be the other way around...
I'm like a kid in a candy store when it comes to planes!
SEPilot
Fri Dec 31, 2010 10:37 pm
I used to fly a T-41 for Civil Air Patrol; I was under the impression that it was a T-41B, and it definitely had electric flaps. Either I am wrong, and it was a T-41C (which is possible) or the -B had electric flaps. The original engine was the Continental O360 which had been replaced by the Lycoming O360, and it had a constant speed prop.
Quoting B727LVR (Reply 13):
Only the latest B-52's are still flying; all of the early models have been retired. A much greater percentage of the B-52 fleet has been retired than the KC-135 fleet.
kc135topboom
Sat Jan 01, 2011 4:08 pm
Quoting SEPilot (Reply 14):
Correct, the B-52B/C/D/E/F/Gs were all built between 1954 and 1959 (the last few B-52Gs were delivered in 1960). All of these bombers have been retired, and most of them have been scrapped. There is only 2 B-52Bs remaining, one at the SAC Mesuem at OFF, and the NASA flight test B-52B which flew until about 2005. There is one surviving B-52C owned by P&W (no longer flying and may have been scrapped by now), a few B-52Ds in museums, all the B-52Es are scrapped, 1-2 B-52Fs in museums, and several B-52Gs in museums.
The CAP received the T-41A/B/C from the USAF (T-41A/C) and US Army (T-41B). All originally were C-172Es, except the T-41C was the C-172F and all originally had the Continental engines. The Lycoming engine began with the production of the C-172I in 1968, and was available to reengine the Continental engined aircraft. So your CAP T-41 most likely got reengined. The US Army also got some C-172Fs, which had the electric flaps, but still called them the T-41B. The USAF C-172Fs were all called T-41Cs while the USAF C-172Es were called the T-41A. You very well could be right then as your CAP T-41 could have been a "B" model.
mechatnew
Sat Jan 01, 2011 6:21 pm
There are 4 B-52Bs preserved.
B-52B 52-0005 at the old Lowry AFB museum, in Colorado.
NB-52B 52-0008 , the NASA one, at Edwards AFB,CA
RB-52B 52-0013 at the National Atomic Museum near Kirtland AFB,NM
RB-52B 52-8711 at the SAC museum, Nebraska.
The is also NB-52A 52-0003 at the Pima Museum in Arizona., and B-52F 57-0038 at Palmdale, CA. the rest of the reserved ones are B-52Ds, and B-52Gs.
SEPilot
Sun Jan 02, 2011 1:32 am
Quoting KC135TopBoom (Reply 15):
It absolutely was; that was what I meant in my original post. One thing I did not emphasize is that while the Cessna 172's of that era had the Continental O-300 (145HP) the T-41's had the Continental O-360 (200HP) and a constant speed prop. The Lycoming conversion only had 180HP. Cessna did offer the 172SP, which had the Continental O-360 and constant speed prop, but I believe it was not offered until later. One other quirk of the T-41's; they had no baggage door.
2H4
Sun Jan 02, 2011 1:40 am
Quoting SEPilot (Reply 17):
Are you sure? Baggage doors are visible on all of these:
Photo © Joe Brown
Photo © Tony Zeljeznjak
Photo © Alex McMahon
Photo © Eduardo Cardenas
DiamondFlyer
Sun Jan 02, 2011 2:03 am
I think you mean the 172XP, with a Continental IO-360 with a constant speed prop. While it is marketed as a 172, it was actually built on the 175 type certificate. The 172SP (built since the late 1990's) is powered by a Lycoming IO-360, with a fixed pitch prop.
-DiamondFlyer
From my cold, dead hands
SEPilot
Sun Jan 02, 2011 2:43 am
Quoting DiamondFlyer (Reply 19):
You're right.
SEPilot
Sun Jan 02, 2011 2:46 am
Quoting 2H4 (Reply 18):
They certainly are. The one I flew, however, did not have one. I was under the impression that none of them did; obviously I was wrong.
kc135topboom
Sun Jan 02, 2011 12:09 pm
2H4
I have flown in T-41A N4976R, it was part of the Aero Club at BED. IIRC, they had 2 T-41As and 2 or 3 Archers. N4976R did not have electric flaps.
SEPilot
Sun Jan 02, 2011 1:27 pm
I just noticed that the third picture you posted has a fixed prop; which indicates that it probably had the Continental O-300 instead of the O-360. So does anyone have any information on which T-41's had the larger engine?
rwessel
Tue Jan 04, 2011 9:13 am
The USAF Test Pilot School operates, on a semi-regular basis, a B-17, HU-16 Albatross, MiG-15 and DC-3. I'm not sure of the ownership status of any of those aircraft, so I don't know if they should count as "USAF Aircraft" for purposes of this discussion, but the B-17 or DC-3 would certainly have been produced prior to the 1957 KC-135s, and the HU-16 and MiG-15 could have been.
kc135topboom
Tue Jan 04, 2011 1:32 pm
Quoting rwessel (Reply 24):
Yes, all of them were built long before any KC-135A. But each of the aircraft you mentioned are rented and or leased for short terms by the USAF, all are owned by civilians and have "N" numbers. IIRC, the DC-3 is actually a former C-47B or C-47D. The B-17G, C-47B/D, and HU-16B are former USAAF or USAF airplanes bit none are owned by the USAF.
rwessel
Tue Jan 04, 2011 7:54 pm
Quoting KC135TopBoom (Reply 25):
Just to play with semantics a bit, the original question was "what the oldest aircraft in the USAF is." If the original 767 tanker deal had happened, would those tankers have been "in the USAF?" And assuming that they would have been, how would that be distinguished from leases or rentals (short or long term) for any of the above four civilian owned aircraft?
SEPilot
Tue Jan 04, 2011 8:45 pm
Quoting rwessel (Reply 26):
I would say that an aircraft on long-term lease would count as being in the USAF, just as you would count it in an airline's fleet. A plane that is only rented or leased on occasion and is used or is available to be used by others would not count. In other words, if it is EXCLUSIVELY used or available to the USAF, it is part of the fleet. Any outside use or availability means that it is not.
kc135topboom
Tue Jan 04, 2011 11:09 pm
Yes, it would still be a USAF aircraft, with a USAF FY tail number. Originally all of the C-21s (Lear-35s) the USAF got in the 1980s were on long term leases. IIRC, about 5 or 6 years into the lease the USAF finally bought them. The same happened with the C-40C (B-737-BBJ2), originally leased, then bought after a while.
The C-40Cs were leased from two companies, including Ford Motor Company, as 2 of them were former Ford owned aircraft. I forgot who the second company was, but it wasn't from Boeing. All 6 USAF C-40Cs were used aircraft when they came to the USAF, as was the C-32Bs (also leased for a few years).
FlyingSicilian
Mon Jan 10, 2011 10:45 pm
And just to add the highest hours airframes in the USAF flight are the E-3Bs and Cs (soon to be Gs) Higher than the oldest tanker and buff. They took the title around mid-2002 IIRC
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
bigbird
Thu May 03, 2012 11:10 pm
Is KC-135R 57-1419 still active? If so, I am sure that it is definitely the oldest jet in regular service.
cargotanker
Fri May 04, 2012 2:23 pm
bigbird
Fri May 04, 2012 8:20 pm
Is KC-135R 63-7990 or 62-3554 still active? There is not a shot in the data base of 990. Also is there a place to find an active list of -135s?
Confuscius
Sat May 05, 2012 4:10 am
Quoting hka098 (Reply 11):
1958! That says something about the manufacturers and maintainers...
It's great, but the US Navy has the oldest commissioned vessel.
"Old Ironsides"
Ain't I a stinker?
Zkpilot
Sat May 05, 2012 5:24 am
Quoting Confuscius (Reply 33):
"Old Ironsides"
lol Go Navy....
but................................. Her Majesty's Royal Navy has the oldest commissioned vessel:
The First Rate 104-gun Ship of the Line - HMS Victory was launched in 1765 whilst the 44-gun USS Constitution was launched 32 years later in 1797.  http://en.wikipedia.org/wiki/HMS_Victory
57 types. 38 countries. 24 airlines.
Confuscius
Sat May 05, 2012 4:42 pm
How old are the T-38 Talons?
Quoting Zkpilot (Reply 34):
I wonder if these ships can be upgraded with VLS to complement their cannons.
Ain't I a stinker?
rc135x
Sun May 06, 2012 12:44 am
Quoting FlyingSicilian (Reply 29):
The high-time airframe recently was RC-135W 62-4139.
KC-135A, A(RT), D, E, E(RT), Q, R, EC-135A, C, G, L, RC-135S, U, V, W, X, TC-135S, W
flyingturtle
Sun May 06, 2012 11:44 am
...which leads to the question if the USAF has an aircraft that is kept in flying condition and will never get retired for any reason, just for tradition's sake?
Well, what are the chances that the USS Constitution will see some active duty on the shores of Somalia?
MD11Engineer
Sun May 06, 2012 12:21 pm
Quoting flyingturtle (Reply 37):
Didn´t she see some action in an anti-piracy operation off the shores of the Barbary coast?
Jan
ebj1248650
Mon May 07, 2012 12:24 am
Quoting mechatnew (Reply 16):
Chanute AFB in the mid 70's had a B-52F and I presumed it remained there and is now part of the Air Museum now that the base has been closed. Was the airplane scrapped or moved?
sprout5199
Wed May 09, 2012 1:15 pm
The Victory is the oldest "commissioned" vessel, and the Constitution is the oldest "commissioned" vessel afloat. The Victory is in permament dry dock while the Constitution is moored in Boston harbor.
Dan in Jupiter
kc135topboom
Wed May 09, 2012 11:43 pm
Quoting KC135TopBoom (Reply 7):The oldest jet still flying in the USAF is KC-135R tail number 57-1419, ordered in FY 1957 and delivered in 1958. There are a number of 1957 and 1958 model KC-135Rs and several 1958 model KC-135Ts still on active flying with the USAF, ANG, and USAFR. The remaining B-52Hs are all FY 1961 and 1962 buys.
Quoting KC135TopBoom (Reply 25):Yes, all of them were built long before any KC-135A. But each of the aircraft you mentioned are rented and or leased for short terms by the USAF, all are owned by civilians and have "N" numbers.Just to play with semantics a bit, the original question was "what the oldest aircraft in the USAF is." If the original 767 tanker deal had happened, would those tankers have been "in the USAF?" And assuming that they would have been, how would that be distinguished from leases or rentals (short or long term) for any of the above four civilian owned aircraft?
Quoting Confuscius (Reply 33):Quoting hka098 (Reply 11):
"Old Ironsides"
lol Go Navy....
Quoting MD11Engineer (Reply 38):
Quoting flyingturtle (Reply 37):Well, what are the chances that the USS Constitution will see some active duty on the shores of Somalia?
Didn
[quote=ebj1248650,reply=39]Quoting mechatnew (Reply 16):and B-52F 57-0038 at Palmdale, CA.
That was B-52F tail 57-0042, most of her was scrapped, but her nose section is in Santa Monica, CA.
Quoting bigbird (Reply 32):
63-7990 never became a KC-135R. She crashed on 31 Jan. 1989.
We had 62-3554 for a while when I was at Pease AFB in the late 1980s. She was the test airplane for the strobe lights replacing the rotating beacons. She was equipped with the anti-collision strobes from the KC-10. They worked very well. Later 3554 did become a KC-135R. She is currently assigned to the 22nd Air Refueling Wing.
http://www.airport-data.com/aircraft/63-7990.html
http://www.airport-data.com/search/s...earch=Search&code=Boeing%20KC-135A
http://www.airport-data.com/aircraft/62-3554.html
[Edited 2012-05-09 16:48:53]
Spacepope
Thu May 10, 2012 12:53 am
Quoting rc135x (Reply 36):
What's high time on a KC-135? 40,000 hours?
Users browsing this forum: angad84, LightningZ71 and 21 guests
