stevenlee505
Limitations Keep F-22 From Use In Libya Ops
Wed Mar 23, 2011 9:28 am
http://www.airforcetimes.com/news/20...ptor-absent-from-libya-ops-032211/
I thought the reason that F-22s weren't deployed to Libya were due to the logistics problems involved with the stealth coating on the aircraft. I read somewhere that they need to be in special climate-controlled hangers, though I may be confusing it with the B-2.
F-22s aren't really needed in Libya, right? It's not like Libya has an air force worth worrying about.
checksixx
RE: Limitations Keep F-22 From Use In Libya Ops
Wed Mar 23, 2011 12:39 pm
Without going into how they need to be maintained...
Yes, they could be deployed to that theater. No, they probably don't need to go over there. Yes, they have already been over that way.
nomadd22
Wed Mar 23, 2011 12:45 pm
It's more because F-22s can't transmit on the standard Link-16 data link most coalition aircraft use and they aren't really much of a ground attack aircraft anyhow. Plus, you sure don't want to risk F-22 parts showing up at the local bazaar when there's no real need for the plane in this operation.
It'll be different in North Korea. You'd probably see the 22s escorting the B-2s in a real war.
[Edited 2011-03-23 05:45:47]
Anon
par13del
Wed Mar 23, 2011 1:16 pm
Quoting nomadd22 (Reply 2):
Why, the whole point of stealth is to not attract attention to your presence, you really believe the F-22 is more stealthy than the B2?
bikerthai
Wed Mar 23, 2011 2:46 pm
Quoting par13del (Reply 3):
   I can see it now. The B2 is shooing the F-22 away . . . "Get away from me boy, you are attracting too much attention".
Besides, with the limited Libyan radar capability already destroyed, most if not all allied planes are more or less undetectable with respect to the Libyan air defense. Right?
bikerthai
Spacepope
Wed Mar 23, 2011 3:05 pm
If there was a conflict where the F-22 was less needed, I couldn't think of one.
Don't forget, the Russians are in the med with electronic listening ships. No need to fire up the F-22 radar or to give them any good idea of the true stealth signature. All interception missions so far have been flown with external tanks, and clean configuration flights have radar reflectors attached...
Eagleboy
Wed Mar 23, 2011 3:19 pm
Indeed. Don't show your trump card when its not needed.
Save it in case you really do have need of it in the future.
nomadd22
Wed Mar 23, 2011 3:22 pm
Neither one is invisible and a hopped up Cessna could shoot down a B-2. One villager looking up is all it would take to have 12 Migs after your flying wing butt.
Anon
FlyingSicilian
Wed Mar 23, 2011 6:09 pm
As the article states, the data link system is the major negatvie factor, and frankly has been since day one.
Link 16 receive only is not going to cut it. The Air Force knows this, and has for years.
But, the F-22 is not needed in the theatre. Vipers and Beagles can handle.
The "fat guys" are more important right now, AWACS, tankers, RJ.
The fighter pool is coming from all over.
The AWACS coverage 24/7 and possible expanded to multiple orbits is a bigger concern. Espcially with NATO losing some tails to other ops at Geilenkirchen.
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
par13del
Wed Mar 23, 2011 7:47 pm
Quoting bikerthai (Reply 4):
I would get into the colour thing and day and night flying but, the shooing away is good, works for me
Bigger question to the experts on this site, how many knew of this limitation in the F-22 communication suite and how were they planning on overcoming that with the F/A version that was proposed, add another few billion?
We know CAS is not the Air Force mantra, maybe they had new tech on the way which would allow one way communication when conducting ground missions.
On the other hand, the Air Force I guess was always jealous of the navy sub commanders who go out on missions and listen only, finally they got the same thing for a few billion less, go figure the Air Force jealous of the navy.
