444Pilot
Any Replacements For The C-5 Galaxy On The Horizon
Fri Apr 22, 2011 3:52 am
I was happy that a decision has finally been made for the replacement of the venerable KC-135. I believe the C-17 replaced the C-141 ... but what about the C-5 Galaxy? Are there any proposals in the works about a possible replacement for this mammoth workhorse?
tristarcrazy
RE: Any Replacements For The C-5 Galaxy On The Horizon
Fri Apr 22, 2011 3:56 am
Yes, the C-5M Super Galaxy
http://www.lockheedmartin.com/products/c5/
I believe all the C-5B's and half of the C-5A's will get the mods
717,722,732,733,737.738,739,742,744.752,753,762,763,764,772,L10,L15,DC3,DC6,DC8,DC9,DC10,MD11,MD80,MD90,CV880,A310,A332,A333,A319,A320
ADent
Fri Apr 22, 2011 3:58 am
The C-5 replacement will be fielded right after the B-52s are parked and all the KC-135s are replaced.
crownvic
Fri Apr 22, 2011 4:46 am
The C-5 is similar to the DC-3 in that the only thing that can replace it, is another C-5! Tristarcrazy has the correct answer along with the large C-17 fleet. There is nothing "on the books" beyond this even in concept. The combination of a large fleet of C-17's along w/ the Super Galaxy fits the air forces future requirements, although many will disagree.
mayor
Fri Apr 22, 2011 5:54 am
I had always thought that the C-17 more or less bridged the gap between the 141 and C-5, more than replaced the C-141.....depending on how many hours were on even the newest 141s, I thought they might have re-engined them and got a lot more service out of them.
"A committee is a group of the unprepared, appointed by the unwilling, to do the unnecessary"----Fred Allen
ebj1248650
Fri Apr 22, 2011 12:41 pm
Quoting mayor (Reply 4):
I believe the C-141s were at the point where they were literally worn out. New engines wouldn't have helped them. They were great airplanes but they were run hard and the fleet paid the price for that. I suspect in years to come we'll be saying something similar about the C-17.
Dare to dream; dream big!
par13del
Fri Apr 22, 2011 12:47 pm
Why does there have to be a new C5, by that I mean for the type of missions required there will be no new design technology, the next a/c that replaces the C5 will have 4 engines, will have high wings to allow loading of cargo and a ramp either front and or back.
What technology will do is to change the materials used, manufacturing techniques and electronics, avionics etc. so ultimately, why would Lockheed not simply take the current specifications they have on paper and build new frames, what radical change in design can they come up with for a cargo carrier, its not like a fighter with stealth or no stealth.
I think the same thing for the A-10, if the US really want a ground attack a/c simply start building new A-10's the basic design of the a/c is sound and works, tweak the materials etc and away you go.
The current conversion program to the C5-M standard is expensive, if they still had the tooling, would it have been cheaper to simply build new frame with the modifictaions included, the 767 is still in production, is a 767 purchased new today identical internally to ones produced 20 years ago or have improvements been incorporated?
JohnM
Fri Apr 22, 2011 7:13 pm
Quoting ebj1248650 (Reply 5):
The C-141 had to die to make way for the C-17. I would look bad for the old plane to be as good, or better than it's replacement. The AF does not have the money or manning to operate both. Some 141's flew to DM code 1, pretty good for a plane that was to be cut up.
With all due respect, any future large air lifters need to be produced by Boeing. I am not willing to go beyond that, but I have my reasons.
Flighty
Fri Apr 22, 2011 8:20 pm
Given their rate of use, the C-5 still has 30 years of use left. In C-5M format.
HaveBlue
Fri Apr 22, 2011 9:38 pm
Quoting par13del (Reply 6):
I'm with ya on that kinda thinking.. just make newer, lighter and more up to date C-5's and A-10's. The design itself is sound, especially in the A-10's case. I know the C-5 was a maintance nightmare but if we built them anew with modern tech doesn't seem like a bad idea.
Here Here for Severe Clear!
Galaxy5007
Sat Apr 23, 2011 1:06 am
Correct; the C-17 wasn't a bridge, it was designed to replace the C-141 which were worn out to the max. They were showing their age and signs of fatigue in the late 80s.
Quoting JohnM (Reply 7):
I agree with the first 141s that they retired probably had 10 years left in them; but the remaining fleet was used like crazy, alot of the 141s had 40K hours on them, some had more, some had less.
Actually, building new frames would be extremely costly; if you built a C-5M from scratch, it would be at least $300M a pop. Thats why AMP and RERPing them is the best and most cost effective way in keeping them in the fleet.
Quoting HaveBlue (Reply 9):
I agree. There are still some legacy issues that need to be worked on that the AMP/RERP doesn't cover; fix those issue and incorporate it into new build C-5s and there you go. Fix (replace) the Dewar system, redesign the hydraulic system so you don't have 8 lines crossing one another and you have to take 7 out to get to one that needs changing, make it a fly by wire system, and make the flap/slat system and aft loading complex less complicated.
The thiing that has me aggravated is the fact that there are C-17s replacing C-5s right now because of the morons running our country. 8 C-17s should NOT replace 10 C-5s...and 8 more C-17s shouldn't be replacing 12 at another base. And the latest is another 8 will replace 10 more now...so 24 C-17s are replacing 32 C-5As...Thats Bogus. All I can hope for is the remaining A models get RERPed.
mayor
Sat Apr 23, 2011 5:11 am
Kind of off topic, but is Air Force thinking still leaning towards the Army getting the ground support role, once the A-10s are gone? I had heard at one time that the upper echelons in the AF at the pentagon weren't exactly fans of the A-10, anyway.
HaveBlue
Sat Apr 23, 2011 6:06 am
Quoting mayor (Reply 11):
The Air Force has been trying to rid itself of the A-10 almost since it was incepted. Its not a flashy fighter or impressive strategic bomber, its the bastard child it never wanted. However nothing can do what the A-10 does as well as it does it, and the Gulf War proved that and thus staved off the vultures... for a time. My opinion is that it is a low cost, low maintenance airframe that does what it does better than anything we can come up with (be it the F-16XL, F-15E or F-35) and it should be left alone. It is exquisite at tank/armor killing, leave it be, and if the USAF doesn't want it give it to the US Army, which the AF is loathe to do.
As much as I'm a fan of the F-22, and I am, we aren't going to always need that kind of air supremacy (though I believe strongly its needed regardless) but we will always need a great CAS platform, and nothing touches the A-10 when it comes to that.
[Edited 2011-04-22 23:10:13]
mayor
Sat Apr 23, 2011 3:05 pm
Quoting HaveBlue (Reply 12):
My reserve unit at Barksdale was just converting to A-10s from A-37s when I got there in '80. Our local ANG unit here at FSM recently converted from F-16s to A-10s and while many at the time thought it was better than having the unit shut down, I think many have changed their minds about the capabilities of the A-10, down in the mud.
Ok, back on topic (which I willingly veered off of).
What are the percentages of airlift that are performed active vs. reserve/ANG?
dimik747
Sat Apr 23, 2011 4:31 pm
Question that is slightly off topic, but since the C-5 is such a unique aircraft as you say (and i agree) have any been created for civilian cargo operations?
HaveBlue
Sat Apr 23, 2011 5:14 pm
They had a proposal, the L-500, which never panned out.
An interesting story by TIME back in the day, it speaks of it towards the bottom of the page
http://www.time.com/time/magazine/article/0,9171,712157,00.html
And discussed here a while back.
http://www.airliners.net/aviation-fo...eneral_aviation/read.main/2693118/
747400sp
Thu Apr 28, 2011 3:40 am
If Boeing wanted to build a super size cargo lifter to replace the C-5, they could. A C-5 replacement with a 24 ft wide and a nose and aft loading door that is powered by four GE 90-115, could be built, but runways at Air Force Bases would have to be redesigned to fix it.
Users browsing this forum: CandleFlight, dcchipper, mikeyoung1801 and 1 guest
