fxramper
Shuttle Endeavour Being Built (pics).
Fri Apr 29, 2011 2:35 pm
Pretty cool article and slide show chronicling the build of Endeavour OV-105.
article
beiaard
RE: Shuttle Endeavour Being Built (pics).
Fri May 13, 2011 6:25 am
Very interesting! Perhaps I'm a little off (well, I am, but I digress), but I was surprised by how different the thing looked prior to final assembly. For instance, when most aircraft are partially disassembled, you can typically recognize the thing (c.f. 747s in the desert), but the nose section of this thing minus the radome (or whatever the equivalent structure is called on the Shuttle) as seen in photos 4 and 10 looks completely alien. Perhaps it's due to the fact that I am simply less familiar with the Shuttle versus most civil aircraft/airliners, but I wouldn't even have been able to guess what the thing was if I was only shown those two photos.
I was also shocked at how..."fake" some of the components look. The photo I'm thinking of specifically is 11, detailing the joining of the mid-fuselage to the empennage. It looks like it's made of cardboard or similar! You wouldn't think that something that looks like that would be able to stand up to the stresses and temperatures that it must be subjected to in routine use, but I guess 131 mission would stand to prove me wrong!
BONARUM ARTIUM RERUMQUE HUMANARUM AC DIVINARUM STUDIOSOS CONVOCAMUS
eksath
Crew
Sat May 14, 2011 3:37 pm
Quoting Beiaard (Reply 1):
The entire structure i.e the vehicle is NOT a "shuttle but an orbiter. To be accurate, the word "shuttle" refers to orbiter + 2 SRBs + ET= shuttle transport system aka shuttle. People commonly refer to it as "the shuttle". Even the nomenclature on this database has it wrong
World Wide Aerospace Photography
MadameConcorde
Sat May 14, 2011 10:09 pm
Call them how you wish, Shuttles or Orbiters
only two more to fly
... soon to be grounded
they will be greatly missed.
twincommander
Sun May 15, 2011 1:44 am
I always wondered how the crew module was designed to seperate in case of an emergency. now that ive seen the pictures of it seperated from the rest of the machine and how its lowered into the lower fuselage section, it makes so much more sense.
eksath
Crew
Sun May 15, 2011 1:53 am
Quoting MadameConcorde (Reply 3):
Not by the American taxpayer   $10,000 per pound of payload into space is not good economics. Successive administrations kicked the can down the road hence the lessons learned were not applied to develop improved iterations. The STS program never lived up to the 40 launches/year initial design plan hence the cost continued to escalate. These turkey are done   I will miss working around them but it is time to let them go peacefully into the history books.
zanl188
Sun May 15, 2011 2:21 am
Quoting TwinCommander (Reply 4):
Let's be clear... There is no provision to seperate the crew module in an emergency... none.
328JET
Sun May 15, 2011 9:16 am
Thanks for sharing!!!
That is really interesting and makes me really sad.
The shuttle concept is still fascinating and un-reached by all other nations.
twincommander
Sun May 15, 2011 1:04 pm
Quoting ZANL188 (Reply 6):
i thought part of the rogers commission report stated that an explosive charge was to be added to the remaining shuttles so to seperate the crew module from the rest of the shuttle, if the situation was proper for it to be used?
NoUFO
Sun May 15, 2011 1:26 pm
Quoting 328JET (Reply 7):
It is.
At the same time it is an inherently flawed concept. The Space Shuttle was never the cash cow, the pay-as-you-go system it was intended to be. What's worse, the project has never been as safe as it could have been. Post-Apollo NASA was underfunded and understaffed; the agency had won the race to the moon, and the American Congress was willing to spend the billions of dollars NASA had been consuming elsewhere. The lack of an escape system, the position of the orbiter, which exposed it to fragments of the ET insulation falling down, as well as the SRB design, four segments sealed by eroding O-rings, were results of it.
When the Shuttle concept was introduced, it was basically designed as a space freight service, UPS for satellites - for which you don't necessarily need astronauts. The Shuttle would only pay off, would the new spaceship launch everything.
This 'we lauch everything with the Shuttle' unnecessarily exposed astronauts to situations that could easily kill them and ruin families. At best, those families would cry in relief after a mission went well.
I support the right to arm bears
zanl188
Sun May 15, 2011 4:01 pm
Quoting TwinCommander (Reply 8):
There is no provision for this.
What was added after Challenger was a telescoping pole that allowed the crew to bail out thru the crew hatch without impacting the wing. Only usuable when the orbiter was in unpowered, wing borne flight...
The Rogers Commission recommendation regarding crew escape:
VII
LAUNCH ABORT AND CREW ESCAPE
The Shuttle program management considered first-stage abort options
and crew escape options several times during the history of the
program, but because of limited utility, technical infeasibility, or
program cost and schedule, no systems were implemented. The
Commission recommends that NASA:
- Make all efforts to provide a crew escape system for use during
controlled gliding flight.
- Make every effort to increase the range of flight conditions under
which an emergency runway landing can be successfully conducted in the
event that two or three main engines fail early in ascent.
http://science.ksc.nasa.gov/shuttle/...-commission/table-of-contents.html
bueb0g
Sun May 15, 2011 5:33 pm
Quoting eksath (Reply 5):
On some launches it's close to $60,000.
Quoting NoUFO (Reply 9):
While that's true, it's as safe as it was designed to be. NASA projected a "disaster" occuring once every 75 flights, and, so far, that seems to hold roughly true. Neither of them should have happened, however - Challenger should not have launched that day and the Columbia crew should have been told about the possible severity of the foam strike.
Quoting ZANL188 (Reply 10):
Yep. Can only be used in stable flight, too, and takes over 1 min for everyone to bail out.
It will be a mighty shame to watch them go, however.
Roger roger, what's our vector, victor?
B727LVR
Mon May 16, 2011 3:19 am
Quoting bueb0g (Reply 11):
Quoting eksath (Reply 5):$10,000 per pound of payload into space is not good economics.
Hopefully we can create a vehicle or craft that we can use to take our own cargo and personel into space withh sooner rather than later. At the rates other agencies will charge us, those 10k and 60k dollar values will look pretty good! I dont mean any disrespect to those agencies, but I'm sure every country would rather move their own stuff around.
I would also much perfer this new craft to be able to both cargo and personel together. Some of the new designs I have seen proposed justy dont seem feasable with the needs of the mission.
I'm like a kid in a candy store when it comes to planes!
NoUFO
Mon May 16, 2011 12:43 pm
Challenger wasn't the first mission were bad O-rings caused trouble. There had been previous missions during which one of the inner O-rings (there are one inner and one outer ring sealing each joint) eroded to some extend or even completely. Challenger's last flight was the 64th Shuttle mission. The first mission that caused an O-ring to erode was the 9th mission, I believe. Hence, STS-9 should have rendered the Shuttle inoperable until a solution would be found. Instead NASA said 'they made it back so why bother'?
As for foam strikes: When NASA introduced the Shuttle concept, they did not have foam strikes on their radar - nor the eroding of rubber rings, but NASA allowed both 'normalizations of deviance' to happen. Against this background it is secondary whether the Shuttle could still make some 75 flights before a disaster would occur.
MadameConcorde
Mon May 16, 2011 11:51 pm
Quite shocked to see such a comment coming from you.
 Wow!
Just wait and see how many years you will have to wait until a replacement comes up.
You can go to Kazakhstan in the mean time. I am sure Roscosmos will be happy to have you there.
DiamondFlyer
Tue May 17, 2011 2:30 am
Quoting NoUFO (Reply 13):
I've always wondered if the foam would have came off (or if it would come off in as large of chunks) had we still been painting the tanks. Yes, the paint did seem to fall off the tank at times, but perhaps that would have kept the foam intact beneath it.
Quoting MadameConcorde (Reply 14):
So what. It's better than throwing billions of dollars at a program that has never performed on cost, never will, and has serious issues to overcome if the country desired to continue flying the craft. You don't have to pay for the thing, so I understand why you like it so much (as I like it too), but at some point, the costs become simply too great. Hopefully SpaceX can get some funding to get the crewed Dragon up and running quickly, as it seems they've got the best booster at this point to move on.
-DiamondFlyer
From my cold, dead hands
NoUFO
Tue May 17, 2011 5:12 pm
Quoting DiamondFlyer (Reply 15):
Good point but the fact that NASA didn't go back to paint the external fuel tank shows they think otherwise.
Why so snappy? NASA is more than just the Shuttle program, and the ideology driven rooster fight between east and west, which seems to speak through your comment, has ended quite a while ago.
328JET
Tue May 17, 2011 6:07 pm
I am not sure if i can agree.
The US only had two complete losses in the whole time and that is a very high saftety rate.
We are not talking about transatlantic flights here...
NoUFO
Tue May 17, 2011 7:38 pm
Quoting 328JET (Reply 17):
No, that was luck - and a whole busload of it.
DiamondFlyer
Tue May 17, 2011 9:48 pm
Quoting NoUFO (Reply 16):
It's not only that, but the weight penalty is significant for painting the tank. IIRC, its in the neighborhood of 500 pounds.
-DiamondFlyer
eksath
Crew
Thu May 19, 2011 2:23 am
Frankly, I am not concerned. There was a 7 year gap between Apollo and the STS (1974 to 1981). The Russian are actually taking the the heat off NASA by keeping the US astronaut core active and occupied in the interim while an appropriate launch vehicle rises. The relationship is not based on 60 era Cold War politics but mature modern reality. I recommend you read and comprehend what Charlie Bolden (NASA boss) said recently:
"A & S: You weren’t completely positive about participating in STS-60 at first.
Bolden: (Laughs) When I was told that I was going to be assigned to fly one more time, and I said, okay, what is it, and I was told it was the first joint Russian-American mission, I told 'em right away, I said, “Forget it. I’m a Marine. I trained all my life to kill those guys. They’d have done the same thing to me, and I don’t want to fly with them.” A mentor of mine told me to relax a little, and said that these two [cosmonauts] were in town, have dinner with them tonight and talk to them, and then let me know what you think. And I had dinner with Sergei Krikalev and Vladimir Titov that evening here in Washington, and we talked about families, kids, and things we wanted in life. And by the time the dinner was over, I was sold. Even a Marine can change.
http://www.airspacemag.com/space-exp...iew-Charles-Bolden.html?c=y&page=3
I also have to point out the ISS would not be possible without the Russian components and joint support.
What the use of Russian metal to fly US astronauts to the ISS does is that allows the US to pursue all options and mae the next design or designs far more robust and SAFE compared to the STS program.
At the end of the day, the STS program is not safe as promised (originally a 1 in 7000 failure estimate but now it may 1 in 100 or higher) and not flexible (barely et 5 mission a year versus estimates of 40-52 per year). You can stick a fork in the turkey now
wn700driver
Fri May 20, 2011 9:58 am
Except for that one that launched Buran...
25th. Though it was listed as STS 51L...
Realistically, neither do we. I don't know what the breakdown actually is, but I would be willing to bet that less than a nickel out every hundred of your tax dollars supports the Program. We spend far more on far more ridiculous things, IMHO...
Not saying we shouldn't be cost conscious, but just that the STS Program is not the nightmare some make it out to be. I'm sure sure we could fly that "turkey" all the way to Epsilon Erudani and back for what the first year of the Iraq war cost, and what did that get us, right?
Quoting NoUFO (Reply 18):
Yup. Lucky for NASA they had vendors who knew how to make and maintain (for a price, of course) better than world class equipment. Lucky they were able to round up some of what are literally the best dynamic engineers to walk the Earth to design said equipment.
If that's what you meant, then yes, they had a few busloads. But if you're trying to imply that it was a bunch of school kids blundering their way through space atop shoddy death machines, then I must tell you that you are quite mistaken.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
474218
Fri May 20, 2011 2:41 pm
Quoting wn700driver (Reply 21):
Yes the "Buran" was a one of the greatest technological marvels of all time, as proven by that one (1) "unmanned" orbital flight.
zanl188
Fri May 20, 2011 8:49 pm
If the foam is not adhering properly to the hull all you gain with paint (net, emebdded fibers, etc) is the added risk of an ENLARGED area of foam coming off. Not good.
eksath
Crew
Tue May 31, 2011 4:37 am
i think what he means is that Challenger was preventable and so was Columbia. Each one had one or more engineers trying to warn NASA MMT. On Challenger it was prior to launch and it was an engineer on the SRB team. On Columbia, it was an engineer who predicted the mode of failure upon reentry from day 1 of mission. Both were ignored..repeatedly!
In retrospect, these types of failure had been staring NASA in the face but completely ignored hence the luck to get to 51L and 107.
As Rumsfeld said: "
There are known knowns; there are things we know we know.
We also know there are known unknowns; that is to say we know there are some things we do not know.
But there are also unknown unknowns – the ones we don't know we don't know. ”
—Former United States Secretary of Defense Donald Rumsfeld
In case of STS program, when you add all the knowns and unknowns, continued operation becomes a liability to NASA and the US gov. hence the retirement choice by two US administrations (Bush + Obama).
wn700driver
Tue May 31, 2011 6:02 am
Quoting 474218 (Reply 22):
And don't you forget it!
Quoting eksath (Reply 24):
Sure I understand that. But I was just saying that there was a lot more than luck behind the piles of successes that the NASA did enjoy. In truth there were probably whole other failure modes that never really had a chance to surface in the STS program too, the machines being as complex as they are. I think it's clear that the fact that there weren't more wrecks is testimony to the talent at hand.
