tsugambler
KC-10 Max Range?
Wed May 25, 2011 7:58 pm
I know a regular DC-10-30 has a range of about 10,000km (6200 miles)... but what about the KC-10? I've read that , as a tanker, it can draw on internal fuel stores, which makes it the longest-range production aircraft ever. What would its theoretical range be if it used all the fuel from all of its tanks?
n53614
RE: KC-10 Max Range?
Wed May 25, 2011 9:49 pm
I did a quick Google search and found that the unrefueled, zero cargo range of a KC-10 is 11500 SM. Of course, the KC-10 can be refueled inflight so the only limitation to range would be engine oil quantity.
B722 B732 B733 B734 B735 B73G B738 B739 B742 B752 B763 B772 A319 A320 A332 CRJ2 DHC8 DH8D E135 E140 E145 MD83
Cadet985
Thu May 26, 2011 3:23 am
Quoting n53614 (Reply 1):
...and crew endurance.
tsugambler
Thu May 26, 2011 7:29 pm
11,500 miles, huh? That's one heck of a long flight... almost 20 hours by my calculations!
Max Q
Fri May 27, 2011 2:17 am
More importantly, for those of us dealing in Nautical Miles (as all mileage in Aviation is measured) it is 10000 NM !
tsugambler
Fri May 27, 2011 3:14 pm
What's the difference? Why are there different types of miles?
Max Q
Sat May 28, 2011 4:15 am
Quoting tsugambler (Reply 5):
It's just a unit of measurement tsugambler.
A statute mile is what you are most familiar with in the US, it amounts to 5280 feet, if you see a speed limit of 70 mph
it is 70 statute miles in an hour.
A Nautical mile is considerably more, at 6076 feet it is the standard unit of speed and distance measurement for Aircraft
and ships.
If travelling at 70 nautical miles per hour in An Aircraft or a ship you are moving at 70 Knots.
Sometimes, when an article is written about how far or fast an Aircraft can fly the writer will convert this value to Statute Miles to make it sound even more impressive (it will be larger)
747400sp
Mon Jun 20, 2011 4:32 am
Quoting tsugambler (Thread starter):
I have read that a 77L, has a longer range than a KC-10.
kc135topboom
Mon Jun 20, 2011 1:58 pm
The KC-10 can fly half way around the world, meaning it can go anywhere on Earth (great circle) on just one hop, depending on the direction it flies. The B-777-200LR actually has more range because it has to fly ETOPS to get from point A to point B, making nearly capable of flying anywhere on Earth, depending on the direction it takes. The closest ranged aircraft to the KC-10 would be the A-340-500 as it does not have to fly ETOPS routes, but it takes more than one sortie to fly anywhere on Earth.
Flighty
Mon Jun 20, 2011 7:22 pm
Last yr I met an older man in Oregon who was KC-10 master pilot instructor (or something?) for many years, and KC-135 before that, and so on since the 1950s. I asked him about crew rest and other stuff. Great old fellow, working at a tourist lighthouse selling magnets. He was wearing a KC-10 hat. He said he really enjoyed his career over those many years.
gigneil
Mon Jun 20, 2011 8:00 pm
Quoting Max Q (Reply 6):
and ships.
It's also precisely 1 minute of latitude.
NS
kc135topboom
Tue Jun 21, 2011 11:17 pm
Quoting Flighty (Reply 9):
He was probibly a Command Pilot (star and wreath on top of his wings) who was also an Instructor Pilot. I wore Command Aircrew Wings and was also an Instructor Boom Operator.
wn700driver
Wed Jun 22, 2011 5:56 am
Yeah, I thought I noticed that in the back of DL's in-flight mag where it lists their 77L's as having over 10,000mi range.
Quoting KC135TopBoom (Reply 11):
Ah, hence the name then? That makes sense. That must have been a really cool AFSC, 1A081, or something... In another life I think that would have been a great thing to do...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
PolymerPlane
Wed Jun 22, 2011 8:36 am
Quoting tsugambler (Reply 3):
The 777-200LR has much longer leg, 11,664 NM, or 13,400 miles, in 22 hr 40 min, with 35 souls on board.
http://www.boeing.com/Features/2010/11/bca_777-200lr_11_23_10.html
One day there will be 100% polymer plane
Max Q
Thu Jun 23, 2011 5:40 am
Quoting PolymerPlane (Reply 13):
Kind of meaningless, it was a specially planned flight with next to no payload and all three auxiliary fuel tanks were installed (which no Airline customer uses as it cuts into freight payload)
The KC10 on the other hand can fly nearly as far with no special modifications or planning.
PolymerPlane
Thu Jun 23, 2011 6:16 pm
Quoting Max Q (Reply 14):
How do you think KC-10 stores its extra fuel? it's actually in the under floor cargo hold. The most DC-10 can carry was 240klbs, while the KC-10 can carry 356klbs. I would argue that the 772LR record breaking flight did not need "special" modification. Fact is that the aux tank is an OEM option, which means it is commercially available, not "special" as you'd call. If your car has the optional navigation system, does it mean it needs "special" modification?
I'm not arguing whether the 777 flight was or was not meaningless, but the OP's concern was the maximum zero payload range.
Max Q
Fri Jun 24, 2011 4:07 am
Quoting PolymerPlane (Reply 15):
Good points.
I guess my point was / is the KC10 rolls out of the factory with this capability, the extra fuel tanks are built in, in commercial service, no 77L operator uses them so it's a realistic range.
Users browsing this forum: LightningZ71, UltraAmps and 16 guests
