kanban
F-35 Tests Suspended Over System Failure
Thu Aug 04, 2011 12:23 am
per http://www.reuters.com/article/2011/...pe=RSS&feedName=companyNews&rpc=43
"The department acted after the failure on Tuesday of one aircraft's "integrated power package", a turbo-machine that starts the engine and cools the plane, the Pentagon's F-35 Joint Program Office said.
The office said in a statement that the suspension was a precautionary measure until experts understand the root causes of the failure aboard an F-35 conventional takeoff and landing variant at Edwards Air Force Base, California."
the article is long on the usual background PR and short on details... it's impossible to tell whether this is a major or minor hick-up
autothrust
RE: F-35 Tests Suspended Over System Failure
Fri Aug 05, 2011 1:18 pm
The F-35 program is becoming more and more a nightmare, how much it does have to fail and cost to rise until the goverment stops to pay?
I really, really doubt the aquisition costs will be ever justifiable to the capabilities of this unaffordable plane. More costs does not mean the customer gets a more powerful figther.
“Faliure is not an option.”
Powerslide
Fri Aug 05, 2011 5:05 pm
Quoting Autothrust (Reply 1):
You are right, they should just cancel the F35 program and stop building fighters altogether. This is the first project since the Korean war that has gone overbudget and delayed. Right?
ThePointblank
Sat Aug 06, 2011 2:17 am
The last time there was a IPP failure on a test F-35, they determined that the cause of the failure was because someone overfilled the engine with oil.
And also of note, the aircraft involved in this failure was the one that had the earlier IPP failure as well. Either a mechanic screwed up this time, or this particular F-35 happens to be a lemon.
YANQUI67
Mon Aug 08, 2011 8:01 pm
kanban
Tue Aug 09, 2011 2:24 am
Flight Global has an interesting pice on the system that failed in the DEW Line Blog
http://www.flightglobal.com/blogs/th...-short-history-of-the-subsyst.html
it includes two nice pictures and word that there is a media blackout on the subject.
connies4ever
Thu Aug 18, 2011 1:32 pm
Seems like the Aussies may be getting cold feet over the F-35:
http://www.aviationweek.com/aw/gener...Future%20in%202012&channel=defense
I have for quite some time thought a follow-on order for F-18E/Fs and perhaps EF-18Gs was in the cards. Like another 24. And a consequent reduction in F-35 purchases, if not outright dropping the thing altogether. They have committed to 14, but I'm sure these can be cancelled at some cost.
I wonder who will be next to back out, either partly or fully ?
PC12Fan
Fri Aug 19, 2011 5:49 pm
Quoting Powerslide (Reply 2):
I hear what you're saying, but there comes a time when you have to evaluate where we are after all this time and cut your losses. I'm a believer of having the best equipment there is for our forces, but we can't just keep pouring corn down a rat hole like this.
Just when I think you've said the stupidest thing ever, you keep talkin'!
ThePointblank
Sat Aug 20, 2011 1:21 am
Quoting PC12Fan (Reply 7):
The thing is that F-35 has many revolutionary systems that have never been tried before in a fighter aircraft. The IPP system is revolutionary as other fighters never had what is essentially a APU onboard, not to mention the very high level of integration of electrical system verses hydraulics and pneumatics. For example, the X-35's control systems were lifted from the old YF-23 prototypes, and were mostly conventional hydraulic flight control actuators. F-35 uses state-of-the-art self-contained electrohydrostatic actuators for improved long term reliability and serviceability, the first for any combat aircraft, and the second production aircraft in existence to use such systems (the Airbus A380 was the first).
The removal of the old hydrazine system emergency power unit in favour of the IPP means less maintenance in the long run, and less hazards for maintenance crews because hydrazine is highly toxic and dangerously unstable if mishandled.
Not only does the IPP provide emergency power and engine start, the IPP also provides environmental control for the cockpit and various systems. The X-35 used the environmental control system packs from the F/A-18 with heat exchanger scoops on the left side of the fuselage and under the wing. An additional heat exchanger was mounted on the belly of the X-35B during the flight test phase to provide cooling for hydraulic system oil. The demonstrators had ram air scoops that fed cooling air through the heat exchangers in the roll post bays for the X-35 aircraft or centerline heat exchanger for X-35B. The F-35 IPP provides the legacy ECS functionality, providing conditioned air and liquid cooling to aircraft systems. A unique feature of the F-35 cooling system is the integration of the IPP with the engine using engine fan-duct heat exchangers as a cooling source to the hot air side of the IPP.
When you are trying to do so many things for the first time, bugs will develop. The IPP is a leap forward in vehicle sub systems architecture. It combines what used to be three federated systems, which in turn makes it very complex. Once the kinks are worked out, it will pay dividends for the pilot and maintainer, as it will cheaper and easier to maintain and operate.
PC12Fan
Sat Aug 20, 2011 1:44 pm
Quoting ThePointblank (Reply 8):
Question - were these systems ever tested on a "test bed" system before the bid?
ThePointblank
Sat Aug 20, 2011 7:39 pm
Quoting PC12Fan (Reply 9):
Nope. While all of the systems were used before or tested on other platforms, to put them all together in a combat aircraft was something completely new.
JohnM
Sat Aug 20, 2011 8:03 pm
You must be a LockMart public affairs person! Or do you work for them?
Boeing4ever
Sat Aug 20, 2011 9:07 pm
Quoting JohnM (Reply 11):
Line by line, go through his argument and explain why you think he's wrong. Because reading over what TPB has written, he is 100% right.
Since he's Canadian, I doubt he works for Lockheed.
  B4e-Forever New Frontiers
Boeing4ever
Sat Aug 20, 2011 9:09 pm
Oh, it also appears that the F-35s are flying again...
http://www.jsf.mil/news/docs/20110818_FLIGHTOPS.pdf
I remember when the 787 had that in-flight fire during its flight test program. So many A.netters screamed that it meant it was unsafe and shouldn't be certified, willfully unaware that flight test programs are meant to ferret out and fix such issues.
PC12Fan
Sun Aug 21, 2011 12:31 am
Or maybe, just maybe, he's an A.netter that knows what he's talking about.
Quoting Boeing4ever (Reply 13):
Correct me if I'm wrong - and I have eaten crow before - but we tax payers aren't picking up the bill for the 787 program.
I admit, I don't know very much about the F-35 program outside of the basic knowledge. Guess I've been sucked in to the dark side of the media by only hearing about the bad stuff. But when the bad stuff is the majority, somethings gotta give. I hope they figure it out soon. If they don't, a tough decision has to be made.
Boeing4ever
Sun Aug 21, 2011 12:58 am
Quoting PC12Fan (Reply 14):
Technological development doesn't become smoother just because the dollars are coming from a different source. Whether airlines are paying for a flight test program, or the taxpayer, a flight test program is still designed to mete out issues and address them. And that has happened in both cases.
It's no different from the 787 issues. Or the A380 before that when the majority of stories were negative. Good news isn't news. It doesn't make money for journalists. I made a point before in another thread that if the F-14 were being developed today, people would be screaming that it be axed. It crashed after all on its second flight, and suffered numerous issues related to its engines even after IOC. We've come a long way from that era. But the internet tends to facilitate bitching rather than knowledge enhancement.
Powerslide
Sun Aug 21, 2011 3:09 pm
The media only reports on the "bad stuff" when in fact they are nothing more than testing issues. If the headline in your news paper read "F-35 features cutting-edge technology" no one would buy it. Fact is, those who know something about fighters and are actually in aviation, know just how good the JSF is. The mindless sheep trolls who have nothing to do with aviation are usually the ones who get headlines in the media. So called "experts" are nothing more than idiots with big mouths - aka Steven Staples.
spudh
Mon Aug 22, 2011 10:59 am
Quoting Boeing4ever (Reply 15):
BTW there were a whole lot of people looking to have the F14 axed, it only barely made it across the line and then in a castrated form (F14A was only suppose to be an interim model).
A lot of similarities there and it seems that a lot of lessons hard learned on that program have been forgotten. The F14 was born from a failed multi purpose Jack-Of-All-Trades master of none platform- F111B. The F35 is far more ambitious than the F111.
The F-35 seems to be the mother of all JOAT's. So the F35 has to beat a lot of historical concept failures (I don't actually think there has been a single example of a top class fighter designed from the outset as a multi role platform, loads of single concept fighters going on to multi careers but none the other way). With all the talk of abandoning the VTOL model I don't hear anyone asking what compromises its incorporation into the design has foisted on the other two. In every study done in the F14/F15 and F16/F18 debates, just the 'carrierising' of the Land based models made them inferior (ok I should note that Navy politics would have come into play here too) to the ones developed as carrier capable from the outset. Now put VTOL on top of that!!
The next lesson learned was the development of only one engine. There were over 40 F14's lost directly to TF30 engine failure. Imagine what losing 10 F22's to a known engine problem would do to that program today! The cost of 'fixing' the bad engine (not even counting the attrition losses as a direct result of the engine problem) was more than it would have been to continue development of the alternate engine. One would have thought that this would have weighed heavily on the minds of those cancelling the F35 alternate engine. Obviously not heavily enough.
tommytoyz
Mon Aug 22, 2011 5:50 pm
Quoting Boeing4ever (Reply 12):
Even if the technologies mentioned make it cheaper to operate (not knowable at this point), it is still a very expensive plane to operate:
http://www.flightglobal.com/Features...-special/military-programmes/F-35/
"The F-35 is still expected to cost significantly more to operate than the aircraft it replaces. "Sustainment seems like years away," Carter said, "but now is the time to face that bill and begin to get that under control."
Perhaps the most alarming figure yet associated with the Lockheed Martin F-35 programme is in the last line of a 53-page cost estimate prepared in late 2010 by the US Department of Defense.
The figure on the page reads: "1005342.0". Given the million-dollar unit, this translates in rounded figures to $1.01 trillion, and represents what the DoD expects to pay in inflation-adjusted dollars to operate and sustain 2,443 F-35s over a planned 50-year service life.
It is a figure that even Vice Adm David Venlet, F-35 programme chief, has described as rendering his customers in three US armed services "weak in the knees".
ThePointblank
Tue Aug 23, 2011 12:48 am
Quoting tommytoyz (Reply 18):
So, $20 billion dollars a year to operate and sustain 2443 F-35's, or $8.27 million per aircraft, a year, all in (including upgrades, overhauls, plus god know what else)? Sounds reasonable to me. Life cycle costs should be a little more than the purchase costs for 20 years of service according to guidelines for procurement.
The estimated purchase of around purchase 2,400 aircraft is expected to cost around $323 billion. So roughly 2.5 times $323 billion dollars is $807.5 billion, and the $1 trillion dollars thrown around is still very reasonable according to the guidelines.
PC12Fan
Tue Aug 23, 2011 1:29 am
True, but the 787's problems are not being funded by me directly.
Technologically, yes. But the 787's problems were quickly identified and dealt with.
Quoting Powerslide (Reply 16):
Problem is, I've heard a hell of a lot more "bad stuff" than good.
Boeing4ever
Tue Aug 23, 2011 1:51 am
Quoting spudh (Reply 17):
So the non-JOATs F-14 still suffered. The F-111B was a poor attempt at taking a heavy strike aircraft and making it into a carrier based fleet air defense fighter. The F-35 is a different piece of fruit.
Quoting PC12Fan (Reply 20):
Wow, you just totally ignored the "Technical development doesn't change because of where the funding comes from point." I was going to be civil, but you admit you don't know what you are talking about, yet you persist with incorrect statements in spite of being corrected.
For the record, if you ever buy a plane ticket, yes you do fund the 787. We could also open up the tax break/subsidies can of worms if you really want a party. A flight test program is a flight test program, be it civil or government.
The 787's grounding IIRC was longer than the current grounding of the F-35s which was lifted last week. You have no proof that the F-35's problems weren't identified quickly or dealt with. They know what caused the IPP failure. So what exactly are you basing this assertion on?
Then this problem is yours, and a result of a failure to do proper research. No offense, but this is the truth.
The F-35 program isn't perfect, but it certainly is better off in this part of its development than the F-14 was, or even the 787 when you consider the F-35 is a higher performance and far more advanced machine.
That needs to be taken with a grain of salt. I've done aircraft operating cost prediction before and it is really difficult. It's even more difficult for military aircraft since it depends on utilization rate. F-35s will not operate near round-the-clock like 737s, and their missions and deployments will vary almost on a whim. What is also sorely missing in that article is a comparison of the life cycle cost of all the types the F-35 is slated to replace.
PC12Fan
Tue Aug 23, 2011 2:06 am
Quoting Boeing4ever (Reply 21):
(sigh) I said I didn't know much, but I know enough.
Check please..........
wvsuperhornet
Tue Aug 23, 2011 2:14 pm
wow this is a shock (I cant even say it with a straight face anymore) I wonder which congressman is getting rich off this white elephant.
I say screw it cancel it and either build more F-22's or purchase the more advanced F-15 silent eagles and be done with it.
[Edited 2011-08-23 07:15:45]
kanban
Tue Aug 23, 2011 3:30 pm
Quoting wvsuperhornet (Reply 23):
yeh right.. all F-22's have been grounded for 4 months now.... and no report of progress on the problem.
re: bad stuff... how about the computer system software that won't be available for another 3 years...
mffoda
Wed Aug 24, 2011 1:27 am
I'm not picking on you tommytoyz...
But, anyone who really thinks these numbers are an accurate accounting of ANY military program? One should at lest take the time to compare similar development programs... as many have pointed out regarding (F-14/15, 111 etc.).
"DoD expects to pay in inflation-adjusted dollars to operate and sustain 2,443 F-35s over a planned 50-year service life."
50 YEAR SERVICE LIFE!
What do you think the Wright brothers program would cost today using these same metrics?
harder than woodpecker lips...
ThePointblank
Wed Aug 24, 2011 2:42 am
Quoting PC12Fan (Reply 26):
Partly true. A modified silent eagle flew last year and did fire an AMRAAM.
The main thing with F-35 is that it is a totally different aircraft from legacy fighters. The technical changes, especially with the avionics and sensors, means that F-35 will be considerably more effective than 95% of existing fighters today. The major cost drivers are in the avionics and sensors, and unfortunately, that's where the real innovation is for F-35.
F-35 has some very advanced capabilities that current pilots and mission planners that will save lives, increase mission effectiveness, and sortie generation, above that of current platforms. For example, while today's stealth aircraft like the B-2 and the F-22 require advanced route planning prior to the mission to manage their radar signatures, F-35 has the capability for real-time route planning based upon the current threat environment being detected by the sensors, and information being fed by other platforms. Not to mention for example, that F-35 can take a SAR map down to a very fine degree, add that SAR image to its ground moving target indicator and display the difference between fixed and moving, land or maritime using the sensors onboard, and can track anything within its battle space, while today, it would take multiple platforms and ground controllers to do the same thing.
F-35's ability to monitor the surrounding battlespace is unparalleled compared any current fighter in existence. It is the first fighter that has the ability to track its surroundings in every single direction imaginable. The EO DAS system will allow F-35 to cue weapons and other sensors in every single direction, even a rear shot, and provide guidance to the weapon, even if decoys are employed. It can detect missile launches, including SAM launches, and track the missile at all times, allowing for the pilots to take action, and even immediately launch weapons against the launcher. In a close in engagement, it can keep track of who's who in the fight, so pilots can shoot with confidence that he is not shooting at a wingman. Northrop Grumman has a nice promotional video on EO DAS here.
tommytoyz
Wed Aug 24, 2011 8:37 am
Quoting mffoda (Reply 25):
You mean like the KC-135s, B-52s, C-5s, T-38s and probably others that have already been operating for that long? In case none of you have read the article, it concludes with:
This program is a disaster in my opinion? The F-22 covering it overhead, does not even have link 16 data exchange, like Typhoon and Raphael.
Let's face it, the defense department of the US is run by lobbyists and $$, not warriors.
ThePointblank
Thu Aug 25, 2011 1:41 am
Quoting tommytoyz (Reply 27):
50 years is an eternity in cost calculations. A whole lot can change over time that can affect the assumptions made.
tommytoyz
Thu Aug 25, 2011 1:45 am
Quoting ThePointblank (Reply 28):
Rarely cheaper than initial assumptions.
ThePointblank
Thu Aug 25, 2011 7:28 am
Quoting tommytoyz (Reply 29):
It can be; for example, the exchange rate can swing in your favour during delivery, resulting in a net savings. This has happened recently for Canada with a number of previous purchases.
SP90
Thu Aug 25, 2011 3:13 pm
Sounds like the F-35B or C could be on the chopping block.
Navy Official Questions Need For JSF Variants
bennett123
Thu Aug 25, 2011 4:22 pm
My understanding is that the F35B has had more problems and is proposed to be ordered in smaller quantities.
IMO it will be axed, how this will impact on the RN carriers is less clear, (can they operate F35C's.
XT6Wagon
Thu Aug 25, 2011 10:34 pm
yes, so far its looking like a F18 with slightly better range for many times the cost.
Its looking like an A10 thats been neutered for many times the cost.
Its looking like a F16 with less dogfighting ability for many times the cost.
Its looking like a F15 with no ability for many times the cost.
need I go on?
The F4 worked for all branches of the military mostly due to its huge leap in technologies and design methodologies, rather than the concept of a universal fighter being in any way valid. Perhaps if you could point out even one more fighter that was successful across all branches of the US military I might gain a sliver of hope.
ThePointblank
Fri Aug 26, 2011 2:06 am
Quoting XT6Wagon (Reply 33):
Wrong, 600nm range for the A variant (C's have even more range), AND carry 2 AIM-120's, and 2 Mark 84 2,000lb bombs at the same time. For a small range penalty, it will take six Mark 84 bombs, two AIM-120's and two AIM-9's for almost the same range. No other fighter in existence has such weight reserves to take a full tank of gas and 15,000lb of weapons at the same time.
It's not meant to be a low and slow CAS aircraft. It will have similar capabilities once the GBU-53/B comes online. 8 IR/laser/GPS guided SDB's plus 2 AIM-120's in a stealthy configuration; even more with ordinance hanging off the wing. Not to mention the better sensors on F-35.
Not so, according to test pilots, who are saying performance is similar to legacy F/A-18's but with better acceleration, which incidentally, was the best case scenario (F-16 like maneuverability was the minimum standard).
The F/A-18 is more maneuverable at lower speeds (which is a function of the carrier capability requirement). Not to mention the F/A-18 can sustain higher G's at a higher bank turn. Even the USAF acknowledges that the F-16 is less capable than the F/A-18 at low speeds. However, the F-16 is better at achieving higher G's, and is more maneuverable at higher speeds. Not one approach is better than the other, but in general, fighter aircraft are moving towards more Hornet-like performance at high AoA's... so take it as you will.
Once Block 5 rolls out, F-35 will have 6 AIM-120's internally for an air superiority mission, plus it will have superior acceleration (the only thing that can match it is a clean F-16 Block 50 or a F-22), better maneuverability, better sensors and situational awareness, plus better range. Oh, and did I mention it will be more stealthy?
And not only can be a bomb truck and be an air superiority fighter, the advanced electronic warfare suite with the BAE AN/ASQ-239 Barracuda EW suite and the AN/APG-81 AESA radar has the ability to jam some of the most advanced radars available today (including that of the F-22). Block 5 will add DIRCM capability on top of the extensive EW sensor suite. So, in essence, not only is F-35 a bomb truck, and a air superiority fighter, it is also a EW bird.
Powerslide
Fri Aug 26, 2011 3:37 am
It's looking like you need to educate yourself.
spudh
Fri Aug 26, 2011 9:09 am
Quoting ThePointblank (Reply 34):
While I agree with most of what you are saying I'm going to be a little pedantic, and correct you to 'currently flying'. I don't know if all the F14-B's have been shredded yet. Also the F-111 was technically termed a fighter and it could certainly do the lifting/dropping part if not the fighter part.
The F14-B had an empty weight of 41,780lbs and a maximimum take off of 74,349lbs. That gives 32,569lbs of potential fuel/ordnance/Pilot/RIO. Max internal fuel 16,200, leaving 16,369lbs for everything else, more than F-35.
On top of that, IIRC the MTOW was defined by carrier operations rather than the structural limit of the Aircraft.
Opertional history in Iraq 2 and particularly Afghanistan proved how superlative it's range/payload characteristics were. F14-B's could also hold their own Ait to Air with any teen fighter. So until the last F-14 standing gate display is shredded the F35 will be the second best fighter/bomb truck in existance
GST
Fri Aug 26, 2011 9:36 am
Quoting spudh (Reply 36):
Well, one did quite literally fly a pursuing mirage into the ground in the first gulf war.
SP90
Fri Aug 26, 2011 5:14 pm
Quoting Bennett123 (Reply 32):
I thought the RN is going with the F35C and a CTOL carrier with catapults and arrestor cables now.
Boeing4ever
Fri Aug 26, 2011 10:12 pm
need I go on?
Once again, someone already replied point by point.
It has GREATER payload range than the F/A-18.
It has about the same dogfighting capability with ehanced BVR, and LO technologies in comparison to the F-16.
The F-15 is being replaced by the F-22.
A sliver of hope is one thing, but a sliver of actual research beyond some worthless blogs and rants would take you farther.
Boeing4ever
Fri Aug 26, 2011 10:13 pm
Oh, and take up the A-10 issue with the USAF separately. They're not getting rid of that one for awhile anyway if they wish to continue anti-insurgent activity.
Spacepope
Sat Aug 27, 2011 12:55 am
And while everyone here is arguing, the F-35 fleet has been cleared to return to flight.
http://warnerrobinspatriot.com/bookm...but-IPP-problem-still-not-resolved
HaveBlue
Sat Aug 27, 2011 5:05 am
The USAF had the curious habit of categorizing 'tactical' bombers as fighters... ala the F-111 and F-117 while the USN used the A prefix as in the case of the A-3, A-4, A-5 and A-6.
As far as the rest of your post in regards to the F-14, spot on!
Here Here for Severe Clear!
