notaxonrotax
Man Loses Life Being Sucked Into Hercules Engine!
Mon Aug 08, 2011 4:51 am
http://www.nu.nl/buitenland/2584328/...n-motor-van-vliegtuig-gezogen.html
Sorry, only in Dutch!
Apparently a mechanic down in Kiwi-land got sucked into the the engine of a Hercules; suffering fatal wounds.
How on earth?? Is the press wrong again??
Anybody has any more info perhaps?
Poor sod……..
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
HaveBlue
RE: Man Loses Life Being Sucked Into Hercules Engine!
Mon Aug 08, 2011 5:18 am
Quoting notaxonrotax (Thread starter):
It's true, a quick Google of 'man sucked into C-130' got many results, one of which was this:
http://www.smh.com.au/travel/travel-...ealand-airport-20110808-1ii1p.html
Here Here for Severe Clear!
B727LVR
Mon Aug 08, 2011 8:31 am
As a mechanic, this is one of my worst fears....
The article said he was "made redundant" which I am assuming meant he was laid-off or let go, is that correct?
Best wishes to his family....
I'm like a kid in a candy store when it comes to planes!
zanl188
Mon Aug 08, 2011 10:43 am
Given the smallish intake on the C-130 engine it's hard to imagine someone getting sucked into the engine. Seems more likely we're talking about the prop...
Stealthz
Mon Aug 08, 2011 11:30 am
Quoting ZANL188 (Reply 3):
I would tend to agree.
In my experience there would be two ways to test a T-56, one with some kind of dynamometer attached to the output shaft and the other,more practical way, with propeller attached.
Assuming, unlikely as it might seem there is no propeller, the intake is a long way from the actual circular turbine air inlet on the engine.
Entirely possible the shock and impact at the outermost inlet could cause fatal injuries but "sucked into the engine" may be journalistic license.
Whilst all is speculation at this point the following quotes ...
The man had reportedly entered the testing enclosure while the engine was running.
and
He said the man had been made redundant last year from SAFE Air, an Air New Zealand subsidiary, but had been taken back on a short-term contract to work on the C-130.
imply this may be more a personal tragedy than a simple industrial accident.
HaveBlue
Mon Aug 08, 2011 2:10 pm
As odd as it would seem, its true... into the engine, not the prop.
An Air New Zealand spokeswoman said the engine was sitting on a stand without propellors attached and was not affixed to a plane at the time of the accident.
Read more: http://www.sacbee.com/2011/08/07/382...cked-into-plane.html#ixzz1URkBhHyO
zanl188
Mon Aug 08, 2011 2:57 pm
Quoting HaveBlue (Reply 5):
Even stranger then...
Must have been a small fella... Isn't there a shaft running out of the front of the engine to the gearbox?
Big version: Width: 462 Height: 300 File size: 17kb
[Edited 2011-08-08 08:03:07]
kingairta
Tue Aug 09, 2011 3:00 pm
Makes me wonder what the heck he was doing. The intake on a T-56 is tiny. I don't think I could dive the duct anymore.
kanban
Tue Aug 09, 2011 3:28 pm
is it possilble he contacted some moving/spinning part with loose clothing and became wrapped up in his work?
Sinlock
Tue Aug 09, 2011 5:56 pm
Quoting ZANL188 (Reply 6):
It dosn't have to be a full ingestion to kill you, just an arm will do the job.
I had a family friend who worked as a butcher for a meat market for many years. He got his arm pulled into a meat grinder and bled out in less than a minute. A turbine will do the same thing and drown out your screams for help.
Sorry about the grusom story, but I hear stuff like this and alot of times it's from great workers who loose the constration for a few moments. I've seen a few close calls myself.
kc135topboom
Tue Aug 09, 2011 9:25 pm
That agrees with what I see in the picture in the story below.
Quoting HaveBlue (Reply 1):
http://www.smh.com.au/travel/travel-....html
This line here indicates he was not fully injested into the engine. But since the RNZAF is tearing the tearing the engine down to recover "human remains" that indicates at least part of him (arm, head, leg, etc.) was injected and he may have bleed out, or had the blood sucked out of him before the engine stalled and shut down.
"Tasman Police communications manager Barbara Dunn said emergency services personnel performed CPR but couldn't revive the man."
Read more: http://www.sacbee.com/2011/08/07/382...cked-into-plane.html#ixzz1UZL3irqD
Read more: http://www.sacbee.com/2011/08/07/382...BhHyO
In any case this is a true tragidy, and may he RIP and his family and friends be comforted.
Users browsing this forum: Woodreau and 1 guest
