Bluewave 707
Missile Defense Fleet @ Civilian Airports
Mon Oct 10, 2011 7:56 am
Has anyone seen the Missile Defense Agency fleet park at civilian airports? They often do at HNL ...
Why arenʻt they parking at HIK?
"The best use of your life will be to so live your life, that the use of your life will outlive your life" -- D Severn
ThePointblank
RE: Missile Defense Fleet @ Civilian Airports
Mon Oct 10, 2011 9:24 am
Quoting Bluewave 707 (Thread starter):
If you are talking about Hickam AFB, it's the same plot of land as HNL.
bennett123
Mon Oct 10, 2011 9:41 am
What aircraft do they use?.
rfields5421
Mon Oct 10, 2011 12:40 pm
There are a couple secured ramps on the HNL side of the airport which can be used for US government / DOD aircraft when parking on the HIK ramps is not available.
Sometimes the US govt aircraft use the HNL ramps because they get the same parking spots all the time, while at HIK they would be transient aircraft and park at different locations.
Which aircraft are you seeing? The Kwajalein support aircraft, or the ALTB?
bennett123
Mon Oct 10, 2011 2:21 pm
iirc, there was an Air india B747-200, which was converted into a test bed.
Does it still exist, or was it scrapped.
zanl188
Mon Oct 10, 2011 4:10 pm
Quoting bennett123 (Reply 4):
Never flyable as a testbed. Used as part of ground lab. Test completed, airframe disposed of.
bennett123
Mon Oct 10, 2011 6:33 pm
Many thanks.
More research revealed this.
http://uk.ask.com/wiki/Boeing_YAL-1
Bluewave 707
Tue Oct 11, 2011 6:10 am
They were 2 G-IIIs (N74A and N178B) and a DC-10 (N910SF) that were here for the last test at Barking Sands ...
ha763
Wed Oct 12, 2011 7:05 am
Quoting rfields5421 (Reply 3):
There are no restricted access ramp areas on the HNL side. All the hard stands have access roads that everyone needs to drive through to reach other areas of the airport or common use facilities.
If you are talking about the ramp area by the golf course, that is still part of HIK.
Bluewave 707
Thu Oct 13, 2011 1:50 am
The MDA birds used FedEx GPUs and a local FBO for their ground handling ...
Is it because they have US N-numbers and not military registrations?
Users browsing this forum: MrHMSH and 1 guest
