Chamonix
Which Fighter Is The Most Automated?
Wed Dec 07, 2011 11:06 am
Which fighters have the most automation in terms of pitch,roll and trim?
Arniepie
RE: Which Fighter Is The Most Automated?
Wed Dec 07, 2011 11:42 am
In use today, I would say Typhoon, it's basically fly and forget, also the F-22 is probably at least at the same level
but less is known about its handling characteristics/automation, so we can only speculate about it.
[edit post]
ebj1248650
Wed Dec 07, 2011 12:29 pm
If we're going to speculate, I have a feeling the F-35 will prove to be the most automated warplane built, up to the present. Given all that it's supposed to be able to do, the pilot will need all the automation he can get to help reduce the workload.
Dare to dream; dream big!
opso1
Thu Dec 08, 2011 9:39 am
I never could get the auto-landing system to work well in the Harrier. The switch brought the wheels down, but always landed with a huge thump when flown hands-off...
autothrust
Thu Dec 08, 2011 12:45 pm
Quoting Arniepie (Reply 1):
   The Typhoon uses a quadruplex digital fly-by-wire control system providing artificial stability. The FBW is fully automated and feature care free handling and envelope protections at all times.
“Faliure is not an option.”
Chamonix
Thu Dec 08, 2011 4:37 pm
Quoting Autothrust (Reply 4):
Must be a dream to fly...the best out there hands down!
"In 2004, United States Air Force Chief of Staff General John P. Jumper said after flying the Eurofighter:
"I have flown all the air force jets. None was as good as the Eurofighter."
chrisco1204
Fri Dec 09, 2011 2:52 pm
Quoting Chamonix (Thread starter):
Fighters typically aren't very automated. Autopilots and fancy avionics cost money and weight, and are typically not very important for the kind of missions fighter aircraft fly. As such, there usually aren't autopilots.
With that said, many fighters (like the F-16) incorporate fly-by-wire flight control systems which are a form of automation, but not an autopilot.
I hope that helps.
Legs
Fri Dec 09, 2011 11:16 pm
Quoting chrisco1204 (Reply 6):
Fighters are probably the most automated planes, down to the simple fact that often a single pilot has to carry out the tasks that not many years ago would have taken a crew of three or four. 'Fancy' avionics are crucial to a modern fighters abiity to fight effectively, incorporating navigation, weapons control, active and passive electronic warfare, active and passive sensors both onboard and offboard, as well as powerful self monitoring and fault diagnosis routines, and are often a significant portion of a fighters development (Look at the software update schedule for the F-35, for instance).
Things like autopilot in modern fighters are (generally, though I'm sure there are exceptions) not separate systems, but are sub-sections of the main flight control system software. I don't know of any that don't have autopilot functions, even the original lightweight F-16.
From my (somewhat limited, I'm not across the Russian designs) knowledge, I'd argue that most of the current 4.5 or 5th generation FBW fighters are all roughly the same level of automation when it comes to handling pitch, roll, yaw and trim. All will have active envelope protection, terrain protection and warnings, high maneuverability, air to air and air to ground modes, as well as advanced fault handling routines and a bajillion other things I've haven't thought of.
flagon
Sat Dec 10, 2011 7:51 am
All modern fighters like F16 use artificial stability, not a big deal at all. As per flight envelope protection, it would be a shame not to have it in todays fighters since in civil aviation I believe it was introduced for the first time on the A320 in the eighties....
Stephane
Chamonix
Sat Dec 10, 2011 11:22 am
Quoting flagon (Reply 8):
Yes.
IIRC,the pre-cursor (semi-automated) was Concorde (in terms of CG inflight weight transfer) who rehashed it from the Vulcan.
I watched a programme with Feldzer who said "Sans le Concorde on n'aurait jamais pu faire l'A320".
flagon
Sat Dec 10, 2011 11:37 am
Quoting Chamonix (Reply 9):
Thats right
I think without the Concorde maybe the whole Airbus GIE would never have existed (at least in its current shape) as on top of the technologic learnings, it's also the lessons learned for organising a multi-national programme in a economical way that have set the fundations of Airbus....
Stephane
autothrust
Sun Dec 11, 2011 1:43 pm
Quoting legs (Reply 7):
Couldn't agree more. The DVI is exactly such a fancy system which reduces highly the workload of the pilot.
I don't deny that, but the question was which fighter is most automated and not if it features artficial stability. It was just explanation.
Wrong, the Typhoon is the first fighter which provides care free handling with envelope protections at all times. It was quite an accomplishment as the plane was built in mind to have the highest instabillity possible. They had to linearisize the effects of unlinear aerodynamics to make the envelope protecions.
By the way the Autopilot features besides basic modes, auto-climb, auto-attack, and auto-approach.
wvsuperhornet
Mon Dec 12, 2011 5:08 am
Quoting Chamonix (Reply 5):
Thats funny he said the same thing about the F-22 and the F-35 also.
autothrust
Mon Dec 12, 2011 10:42 am
Quoting wvsuperhornet (Reply 12):
Source?
wvsuperhornet
Mon Dec 12, 2011 11:25 am
Quoting Autothrust (Reply 13):
Source?
Previous articles posted in these forums.
autothrust
Mon Dec 12, 2011 3:37 pm
Quoting wvsuperhornet (Reply 14):
Great source as always from you.
travelavnut
Mon Dec 12, 2011 3:46 pm
Quoting Autothrust (Reply 11):
auto-attack
Could you possible expand a bit on this one? Is this auto-attack as in automaticaly attacking a target? Or more in the region of auto-AoA?
Live From Amsterdam!
autothrust
Mon Dec 12, 2011 4:27 pm
Quoting travelavnut (Reply 16):
Yes and no the Typhoon's autopilot is part of the tactical systems. It can fly several programmed tactical maneuvers like auto-attack, auto-intercept,auto-escape, auto-patrol, auto-recovery etc.. But it doesn't fire the weapons automaticly.
wvsuperhornet
Tue Dec 13, 2011 12:29 am
Quoting Autothrust (Reply 15):
Sorry I have no intetions on wasting my time arguing with someone who has a closed mind the eurofighter,F-22 are both good aircraft equal to the point until you get into stealth there also was a british pilot who flew the F-22 who comments both are good aircraft but if he went into battle he would prefer the F-22 blah blah its a personal choice live with it Both are good aircraft I doubt if you look at it neither one has a superior technological advantage over the other and will likely never face each other in battle.
autothrust
Tue Dec 13, 2011 12:13 pm
Quoting wvsuperhornet (Reply 18):
Then your claim is worthless, you are not alone arquing with me i guess the other posters also would like to know if there is some truth in your post.If you claim something you should back it up with some sources else it's not credible.
You won't believe it.... i agree fully with this statement.
I never claimed the Typhoon being totally superior then the F-22, but in some things. Likewise the F-22 is superior in some things over the Typhoon.
travelavnut
Tue Dec 13, 2011 3:56 pm
Quoting Autothrust (Reply 17):
That's really cool, so I guess the F-35 will have similar provisions?
Quoting Autothrust (Reply 19):
wvsuperhornet
Wed Dec 14, 2011 5:05 am
Dude your worse than my 10 year old, Relax its just a forum!!!!
We will leave it at that, we agree on something !!!!
[Edited 2011-12-13 21:10:17]
Users browsing this forum: ThePuckster and 1 guest
