Max Q
Speed Limits On 747 Space Shuttle Carrier
Fri Apr 20, 2012 12:29 am
Trying to find out what the speed / mach and altitude limits are on the Nasa 747SCA with a space shuttle attached for ferry flights.
Also, are there any speed / mach / altitude limits on the SCA when it is not carrying the Shuttle ?
Just wondered if those struts and different vertical tail set up might affect it.
rwessel
RE: Speed Limits On 747 Space Shuttle Carrier
Fri Apr 20, 2012 1:24 am
NASA says 250kts/.60M with or without a Shuttle on top. They don't list a maximum altitude, but mention "typical" cruise altitudes of 13-15,000ft (mated) and 24-36,000ft (unmated). I'd expect that with the huge drag of the Orbiter, and the significant fall-off in engine performance with increasing altitude, the maximum achievable altitude (mated) is not that far beyond the 15,000ft listed.
http://www.nasa.gov/centers/dryden/news/FactSheets/FS-013-DFRC.html
Max Q
Fri Apr 20, 2012 1:51 am
I knew they had some pretty restrictive limits while carrying the Shuttle i'm just surprised the restriction remains when
it is not carrying it.
Sinlock
Fri Apr 20, 2012 12:19 pm
Quoting Max Q (Reply 2):
From reading http://www.nasa.gov/centers/dryden/news/FactSheets/FS-013-DFRC.html
I'd venture a guess that the speed restriction relates to the two extra vertical stabilizers and the altitude restriction related to the tempature limit of 15F(-9C) degs.
Dreadnought
Fri Apr 20, 2012 5:40 pm
Quoting rwessel (Reply 1):
http://en.wikipedia.org/wiki/Approach_and_Landing_Tests
During the early tests with Enterprise, the mated pair got up to above 30,000 feet, and 474 mph. The highest altitude the Enterprise was released at was 26,000 feet.
You have enemies? Good. That means you've stood up for something, sometime in your life. - W. Churchill
Francoflier
Fri Apr 20, 2012 8:35 pm
Quoting Max Q (Thread starter):
I would say around 7 Miles/second and around 250 mi high...
I'm also guessing the limiting factors are all the appendages added to the SCA to carry the orbiter and stabilize the airflow around the 'assembly'. I doubt either airframe would mind going higher or faster, especially the one on top.
Users browsing this forum: Google [Bot], meecrob and 12 guests
