j.mo
A-10 To Be Used For Atmospheric Research
Wed Jun 06, 2012 5:14 pm
I thought it was interesting and certainly the right airplane to fly the mission.
http://blog.ametsoc.org/uncategorize...-combative-attitude-toward-storms/
JM
g38
RE: A-10 To Be Used For Atmospheric Research
Thu Jun 07, 2012 5:01 am
Very interesting. I'd love to see a shot of the "new" Thunderbolt.
Devilfish
Thu Jun 07, 2012 5:10 pm
Quoting g38 (Reply 1):
"new" Thunderbolt
Finally, the name matches the mission.....or is it the other way around?
Slcpilot
Thu Jun 07, 2012 8:57 pm
Some friends of mine are doing the modification. I am not sure if it's in the public domain yet. I'll ask and share if it is. It will almost certainly be at some point.
That being said, it would take some serious hazard pay for me to fly those missions. OK, you snap a wing, no problem, you've got a hot seat and a canopy. Well, it seems you've just ejected into 3" hail and a 5,000 fpm updraft. When they recover your body three states downwind it will be frozen solid from it's journey to 60,000'.
That's not my idea of fun.
Cheers!
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
j.mo
Fri Jun 08, 2012 4:04 pm
Quoting SLCPilot (Reply 3):
I will tell you though, I would rather do it in an A-10 than that T-28 the article mentions.
JM
Slcpilot
Sat Jun 09, 2012 11:55 am
While it will eventually come out, my buddy was concerned advertising the project will lead to visitors stopping by the shop to see the plane. If I'm able to share pics of the progress I will.
I went through a cell in a Falcon 20 once and experienced a nearly instantaneous 50kt speed increase. I don't like cells Sam I am.
Cheers!
SLCPilot
HaveBlue
Sun Jun 10, 2012 5:14 am
Very cool. I've always been a big fan of the A-10 and have been happy every time it escaped those who wanted it gone. Like a jet version of the A-1 Skyraider.
SLCPilot that is awesome that you have friends working on it. When you can share what they are doing I'll be glad to see it! And I'm with you on passing on that kind of mission... brave souls that volunteer for that. Remember the NASA F-106 lightning catcher?
On a side note I thought this sentence from the OP's linked article was interesting.. "It can also fly lower than the T-28, making it ideal for air-sea interaction studies, and its heavy payload will support lidar, radar, and other imaging systems."
Lower?
Here Here for Severe Clear!
L-188
Sun Jun 10, 2012 5:47 am
Quoting HaveBlue (Reply 6):
Yes, did you ever see the videos from some of those flights?
HaveBlue
Sun Jun 10, 2012 7:02 am
Quoting L-188 (Reply 7):
Just tonight after replying to this thread... but impressive stuff! I had read about it back in middle school but the videos were new to me.
GST
Sun Jun 10, 2012 8:42 am
Lower?
I guess having a higher thrust:weight (and higher wing loading???) than the T-28 may give it the performance advantage to batter withstand the turbulence and escape downdraughts when flying closer to cumulogranitus or cumuloocianicus.
Just a guess though.
MD-90
Mon Jun 11, 2012 8:44 am
Quoting j.mo (Reply 4):
The T-28 was pretty tough, at least until too much ice started accumulating on the airframe.
http://www.avweb.com/news/profiles/184369-1.html
We took a T-28-A model, which is the small -- 1200 horsepower -- engine Air Force trainer, and we put the Navy engine in it -- 1,425 horsepower. It's a Lycoming-built Pratt & Whitney 1820-86B and we swing a big three-bladed prop that the Navy uses. We had to go to the big engine to get up to altitude, because the airplane was built originally to max out at about 8,000 pounds, and we're flying it at around 9,000 pounds-- which is legal because our airplane is registered in the restricted category.
Paul MacCready [aeronautical engineer, weather researcher and Founder of Aerovironment, Inc.] was presented with the problem, 'Could you reinforce, do something, modify an airplane to get it through a thunderstorm and endure primarily the hail, lightening, and the turbulence?' and he took the task on, and what he came up with was modifications to this aircraft. What we did is we put about .0060- to .0070-thick armor plating on the leading edge of the wings, on the leading edges of the horizontal stabilizer and the vertical stabilizer, and around the cowl. The canopy is armor-plated on the top and the sides. We use a 3/4" Lexan windshield with a slant to it -- like a fighter windshield. I've had the hail pounding off the windshield so loud I couldn't even hear, so I'm not concerned about the windshield giving any ground.
We have a laser on the left wing which has a six-inch laser beam between two big pylons. I can count, sort, and evaluate hail going by, and it runs all that through the computer. When I start hearing hail impacts the laser will pick it up and my controller on the ground says, 'You're getting hail,' and I say, 'I'll confirm that.' We have smaller lasers which pick up smaller particles, right on down to the micros, and we have good temperature sensors.
We have two G-meter devices that pick up pitch and roll, so attitude data gets fed back to ground. We carry a camera on board on the right wing, and it's kind of in its infancy. It works good except when it gets iced over, and we're working on a de-icing system to keep it a little clearer.
[Edited 2012-06-11 01:46:45]
tommytoyz
Wed Jun 13, 2012 5:57 am
Quoting MD-90 (Reply 10):
Paul MacCready
Had dinner with him and a few other pioneers once........I can't really put it in words.
checksixx
Wed Jun 13, 2012 11:03 am
Yes! You can still see it at the Virginia Air and Space Center in Hampton, VA.
http://www.vasc.org/exhibits/aircraft/convair.html
fridgmus
Thu Jun 21, 2012 6:37 pm
Quoting j.mo (Thread starter):
This aircraft does so much and does it well, why does the Air Force keep trying to get rid of it?
And IMHO, it will still do a better job than the F-35 in the CAS role!
The Lockheed Super Constellation, the REAL Queen of the Skies!
bigjku
Thu Jun 21, 2012 7:25 pm
Quoting fridgmus (Reply 13):
The Air Force is not trying to get rid of it. They will fly the things until they can't fly anymore. They are going to right size the force to get the longest life they can out of the number they need for A-10 specific missions. It is not really comparable to the F-35. What they mean when they say the F-35 will "replace" the A-10 is that they won't be buying a new version of the A-10.
What will most likely happen is they will curtail the A-10 force in the post-Afghanistan future and use the ones they can stuff in the boneyard to keep the active ones flying for a very long time.
wvsuperhornet
Sat Jun 23, 2012 7:52 am
Quoting BigJKU (Reply 14):
But what we are reading the F-35 is an over priced piece of junk and can't replace the A-10 for the role it provides!!!
wvsuperhornet
Sat Jun 23, 2012 7:53 am
Because they love spending our money.
checksixx
Mon Jun 25, 2012 7:04 am
They're not trying at all to get rid of it. You might have some bad info.
See: http://boeing.mediaroom.com/index.php?s=43&item=2134
sweair
Mon Jun 25, 2012 7:17 am
Would they sell if some allies wanted to buy some? There is not many planes like it in the market.
bigjku
Mon Jun 25, 2012 1:14 pm
Quoting sweair (Reply 18):
There is a reason the A-10 never sold to any other nation. It is a pretty mission specific platform that only really appeals to a nation that can afford a niche aircraft. The current incarnation, the A-10C, is much more flexible but is still at its best in a very permissive air defense environment. If you can afford to keep an aircraft type flying that will mostly be useful for COIN operations and CAS against pretty old or badly degraded air defense systems then it is great. Most nations can't so they do without and go for more multi-role aircraft.
Quoting wvsuperhornet (Reply 15):
That is the Air Force's way of saying two things.
1. For the set of missions the A-10 fly's really well that other planes can't do there is not a better replacement.
2. When the A-10 airframes run out of life we are basically going to lose some of that capability because it would be too expensive to build a new airframe with that capability given the environment right now.
It is best to think of the A-10 in the same way as the F-14. They were fairly specialized aircraft that as the Cold War went away are giving way to more generalist aircraft. The F-14 was in a much worse way than the A-10, which is a very valuable aircraft in a place like Afghanistan but it is hard to start a development program that will be very expensive for something like a new A-10, just like it would be hard to get funds to make a new F-14 (ie build a large, missile heavy interceptor).
spudh
Wed Jun 27, 2012 12:16 am
Quoting BigJKU (Reply 19):
I don't quite agree with you BigJKU.
They are similar in the sense that they were maybe 'too much' of an aircraft for what remained of their cold war roles as originally conceived. The F-14's most powerful weapon, the phoenix, became largely irrelevant when ROE's demanded visual aquisition before firing reducing engagement range down to less than the Amraam, a cheaper, smaller weapon deployable across multiple platforms. However the flying qualities of the F-14 which enabled it to employ the Phoenix from a carrier are more in demand now than ever. The Tomcat had a combination of speed, loiter, payload and endurance capabilities that no other fast jet could match. Its deployed role was very specialised but the jet itself was a better generalist than any other. Where it became outdated was on the technological and budget side of things. The A and B models were largely analog and would have required far too much work/money to integrate any new weapons onto airframes running out of hours. The digital D's represented too small a force to contenance putting up with the maintenace cost when newer more 'efficient' alternatives were waiting in the wings. But the F-14 had a big part to play in the early years of Afghanistan and funnily enough it was in the FAC role that it excelled.
A bit like saying that a Rolls Royce is excellent at towing a caravan, very true but so is an F150.
With the A-10 there is no better single weapon to engage a hoard of invading tanks than the GAU-8 in an A-10 but in any other scenario stand-off weapons offer a lower risk option for engaging less numerous enemy. The conundrum for military planners in the CAS/COIN role is that a 30mm cannon shell is a much cheaper way of taking out a 50cal machine gun in the back of a 20 year old toyota pick up than a €100,000+ smart weapon. But employing that 30mm cannon brings your $30million A-10 in range of black market stinger missile. I think you'll find that in WW2 more T34's and Shermans fell to panzerfausts and mines than to Tiger tanks. To protect against MANPADS the A-10's had to operate at an altitude unsuitable to employment of the GAU-8. But again the A-10 has highly sought after flying qualities of loiter, payload and endurance particularly suited to CAS/COIN
So if you want to compare them, they both lost the use of their primary weapon because of ROE's. Other USN airframe types were capable of filling the remainder of the F-14's role to an acceptable level. No other USAF airframe types can do the remaining A-10 roles to an acceptable level. The F-14 is confined to history (at least in US hands), the A-10 will fly on until 2028 at least by some accounts.
[Edited 2012-06-26 17:31:50]
bigjku
Wed Jun 27, 2012 2:10 am
Quoting spudh (Reply 20):
I would largely agree here that the A-10 will be around for a while because it is an effective COIN aircraft. I think the main reason it survives and the F-14 didn't is that while both were adaptable the A-10 is an affordable platform for the roles needed for it and the F-14 really wasn't in any incarnation.
I would and do disagree with this. At the time of inception this might have made sense but at this point the role the A-10 would have played against a large, advancing mechanized force would be played by fast aircraft using CBU-97/105's which would be far more effective in that role. In its original role I think the A-10 is pretty much done. But like you said, it will be around for a long while because it can be cheaply operated as a persistent presence in a low threat air environment.
spudh
Thu Jun 28, 2012 10:25 am
Quoting BigJKU (Reply 21):
Fair point, in my own head I was thinking of when it first entered service but thats not the way I wrote it. The A-10 probably still serves as a deterent but you are right that sensor fuzed weapons are a much lower risk solution to a large scale deployment of tanks in modern warfare.
sweair
Fri Jun 29, 2012 11:02 am
I just looked at some A-10 clips from YouTube, damn that sound the cannon makes is scary, there is one clip where British soldiers are a bit too close for comfort, they must have soiled their pants..scary killing machine, brutal.
