Max Q
Why Did The US Navy Retire The S3B?
Tue Jul 17, 2012 2:15 am
That Aircraft and it's role as a long range, high speed sub hunter seemed invaluable.
Apart from the obvious wish just to save money by operating less types it's retirement seemed to leave a huge gap in the Carriers defensive capability.
Thoughts, opinions ?
bigjku
RE: Why Did The US Navy Retire The S3B?
Tue Jul 17, 2012 2:38 am
Because they were no longer faced with a few hundred Soviet submarines chasing after them essentially.
The S-3 offered a valuable capability but it just was not needed as much in the post Cold-War environment. Some will argue with the emerging Diesel-Electric threats out there that you need it but in my view those are far more likely to be used as an area denial weapon and the biggest problem is they may well be operating in an area where you could not operate your aircraft with impunity.
The US pretty clearly intends to hunt for those kind of threats with its own submarines and submersible UAV's, at least when it is pressing forward in offensive operations. Defensively they will use the P-8 and UAV's for area work and helicopters for close in work.
rwessel
Tue Jul 17, 2012 3:06 am
To expand on what BigJKU said, their ASW capability was actually eliminated from the aircraft (MAD booms removed, sonobuoy chutes faired over, etc.), well before the aircraft were actually retired - that's how little the USN thought of that particular mission at that time. At the time they retired, their primary role was anti-surface, and tanker.
And at the end of the day, these were 30+ year old airframes. I suspect the USN will want to reacquire some organic ASW asset for carriers as the submarine threat reemerges, but the S-3s would be in a world of trouble performing those missions at age 40-50.
bigjku
Tue Jul 17, 2012 3:14 am
Yeah, it just would not be that hard to put together a new S-3 really (well, the government could screw up buying sewage but anyway). Honestly all you need is a couple of small commercial, low consumption turbofans on a high-wing aircraft that can carry a few people onboard, a lot of fuel, a couple of torpedoes and a bunch of sonar buoy's. All the tech will be there from the P-3 really. You would just carry less of all of it on a different airframe.
I honestly don't think there will be huge interest in it though unless a new blue-water submarine threat emerges.
rfields5421
Tue Jul 17, 2012 3:43 am
The primary method of finding submarines was and still is via acoustic arrays.
Once the arrays find a submarine - aircraft go out to localize the boat and verify the individual identity.
The S-3 mission was one to sweep the area near a carrier battle group beyond the reach of the small ships and helicopters. When there were several hundred Soviet attack and guided missile submarines in commission - it could be reasonably presumed that a couple were following every US CBG. The S-3 was designed to localize those.
Now with less than 50 Russian attack submarines today, and limited numbers of attack submarines of other nations - there isn't such an intense need for daily active ASW search. That need declined rapidly in the mid-90s.
Technology of the larger airborne aircraft has improved - and carrier deck space is always at a premium.
By the late 90s - the S-3s on active duty were no longer ASW aircraft - mainly used as tankers and anti-surface warfare with AGM-65 Maverick and AGM-84 SLAM/ER missiles. In the 1991 Gulf War - the S-3B did a lot of work - but almost no ASW role. All the ASW stuff was removed to make the plane lighter and better able to do the tanker and ASuW roles.
In the end - it came down to 30 year old aircraft no longer doing their primary misson.
But the size, patrol range and hardpoint capability keep the aircraft flying. NASA operates one, and VX-30 still has three supporting the Pacific Missile Test Range.
Max Q
Tue Jul 17, 2012 8:30 am
Interesting. I always just thought it was a cool looking Aircraft.
Not very scientific, i just like it.
Revelation
Tue Jul 17, 2012 11:44 am
Quoting BigJKU (Reply 3):
It seems the USN bought more C-2 frames in the mid 80s and all the earlier ones have been retired.
In the same time period it also bought more E-2 frames and USAF bought more U-2Rs.
And Uncle Ronnie decided to dust off the Wisconsin class BBs as well!
So, nothing is impossible, including seeing some newly minted S-3s.
Quoting rfields5421 (Reply 4):
Are you thinking stationary, towed, dropped, or all of the above?
Quoting Max Q (Reply 5):
No requirement to be scientific. It's a cool airplane.
Funny, one of my earliest memories in my career was a co-worker bitching about having to work with "ancient" stuff on the S-3 program, and that was in the mid 80s!
The gun is NOT a precious symbol of freedom
It is a deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence
par13del
Tue Jul 17, 2012 11:59 am
Makes you wonder why the US Navy is using high end a/c like the F-18E/F to act as a tanker which is required on almost all blue water operations, I think we need to look beyond the actual a/c and focus on the multi-purpose missions it was capable of performing, which have all been transferred to the Hornet other than anti-sub which have gone to the helicopters, lets hope the computers keep up.
We have an a/c which with a flick of a switch can go from air to air, air to ground (land and sea), weasel (being replaced with a dedicated frame), buddy stores, hopefully pilot training is sufficient to have the pilots work in sync with the computer modes.
The problem that the Navy faces is the same as the Air Force and the Army, the military industrial complex has decided that each new item must be a weapons platform which advances technology, so good luck trying to get them to produce a small commercial low consumption turbofan on a high wing a/c, if it was that simple a new and improved S3 would have been on the decks years ago rather than them continuing to operate 20 year old frames. Imagine such a frame being built a couple decades ago which would have served the tanker role, AEW role, surface patrol and possibly assist in COD missions.
Today, a RFP for such an a/c to relieve the burden on the Hornets, P8's, Hawkeyes (2D) and allow the carriers to operate further out to sea would probably cost in the billions and necessitate the retirement of the cruiser force (RAM on the carrier makes them redundant) and probably half the destroyer force (the subs are multi-mission) to afford the development and deployment, no different than what was killed / eliminated / made redundant to get the F-22 built in massive numbers
AirRyan
Tue Jul 17, 2012 12:29 pm
But I seriously doubt that to continue to be the trend. Russia is said to begin investing billions back into their Navy over the next decade, so along with they and China, ASW should still be a very important threat to consider for any CVBG.
par13del
Tue Jul 17, 2012 1:21 pm
Quoting AirRyan (Reply 8):
I think the mantra is when we need it we will build it, or to put it another way, if we attempt to get it when the need for it is evident, it will be funded to the hilt, whatever the cost, an ounce of prevention is not always worth a pound of cure
connies4ever
Tue Jul 17, 2012 1:26 pm
The original (at least) ASW suite on the Canadian CP-140 Auroras (nee P-3 Orion) was lifted from the Viking. I am fairly sure improved during one of the MLUs.
Putin's investments in defense will only be funded, IMHO, as long as the energy revenue continues to flow.
rfields5421
Tue Jul 17, 2012 1:27 pm
Quoting Revelation (Reply 6):
Stationary are the best and cover a lot of the operational areas. There is no longer a need for dedicated shore stations for each array. Such data is not consolidated and better analysis is available.
Strategic towed arrays can focus on operational areas not under stationary coverage. But again - there needs to be some indication from a stationary array as to where a towed array should be looking for subs.
Once a general location is determined, futher localization can be done with tactical level towed arrays and droppable sonobouys if desired.
bigjku
Tue Jul 17, 2012 2:08 pm
I will believe it when I see it. And I doubt it would ever be at the volume it was during the Cold War. A good part of the Russian threat was the fact that they never threw anything away. There were huge numbers of subs because they had been building them for 30 plus years and never getting rid of any of them. They dumped a ton of that crap in their down period and they still have nothing like the budget they had years ago.
China is an interesting case but they are a very long way from doing blue water operations with submarines at this point. They can buy them from the Russians but the Russians are going to be a bit cautious about selling them top end stuff anymore.
sprout5199
Tue Jul 17, 2012 3:18 pm
Quoting par13del (Reply 7):
I wouldnt put too much faith in the RAM. As I was an FFG sailor, one of the "missions" we had was to catch a Soviet missle instead of it hitting a carrier when the missle mag was empty. Same goes for the CG/DDG force. Also the CG/DDGs carry Tomahawks.
I bet the biggest reason they were killed was they arent "Sexy". Why spend less money on a plain jane multirole non-high-tech airframe when you can spend four times the price on a stud-muffin F/A 18 E/F/G/H all the way to Z?
Same goes for the AF when it comes to the A-10.
Same goes for the littoral combat ships, why do they need to be steathy? where is the big gun needed for NGFS? Do they really need to go 50kts? Sorry for that, being a real tin can sailor (the Burke class are CG size ships, the last "destroyer" that was a "tin-can" was the Adams class DDG) sometimes you just need something small, quick(say 30-40 kts) with a decent sized gun (no less than 5 inch, the 76mm on the Perrys were nice but..) and able to defend its self (maybe an 8 or 16 cell Mk-41 VLS). END RANT
Dan in Jupiter
bigjku
Tue Jul 17, 2012 4:27 pm
Quoting sprout5199 (Reply 13):
First I think that post you are replying too was made very tongue in cheek. Second, everything I have read states that RAM is a very good anti-missile system. It has achieved very high kill rates and is often doing so by achieving skin to skin hits of its targets. If it comes to that things are not going well in the first place though as it really ought to be dealt with by the CAP, SM-2's, SM-6's and ESSM's the fleet is carrying around in large numbers.
That being said I would much rather have RAM as my goalkeeper on the backline than Phalanx or Goalkeeper. It would do fairly well in that emergency role and fits in as part of the overall system.
I like the presumptions that the military is stupid. They are the ones who ordered the S-3 in the first place. The fact of the matter is that the USN had a dedicated ASW aircraft for a long time. When the threat went away, so did the aircraft. If it comes back (in a blue rather than brown water arena) then you will likely see ASW aircraft back on carriers. It is not like the US abandoned the field (they are building the P-8 which has all the tech you need for the mission after all) and they continue to invest in ASW helicopters.
It is not a case of them wanting something "sexy". It is a case of them prioritizing funds properly as there is nothing for the S-3 to hunt anymore and you really can't justify keeping it around without the ASW role for a long time and in this case you have a capability that can go on a pretty simple airframe with pretty simple engines and tech that will be continually developed for the P-8/P-3 families. Of all the aircraft you could lose from the Cold War toolbox the S-3 is probably the easiest to regenerate in short order.
I get so sick of seeing this complaint. Can anyone show me where the Air Force is trying to get rid of the A-10? Because they are not. They will wind down the force a bit to extend the service life of the other frames. If they get no other funding they won't replace it because the mission it is designed for is no longer necessary (we have other far more efficient ways of dealing with tanks now) and you can't justify all new R&D cost for a new COIN aircraft. The Air Force is supportive and has upgraded its A-10's. It will fly them until they can't fly anymore. This complaint is just silly.
I won't defend the LCS (I think the speed requirements are absurd) but I do find it telling that your solution for the LCS problem is a ship that would cost at least as much as the LCS if not more. As soon as you put a VLS on it that means you need radars to match and a combat system to manage it all and it very quickly ceases to be cheap in any sense of the word. Not that LCS is with its stupid speed requirements but I would much rather have seen the USN supplement with something that was basically a Brandenburg class ship. Though I would trade the VLS there for the ability to carry two helicopters (the SH-60 is about twice as heavy as the Lynx) if push came to shove.
par13del
Tue Jul 17, 2012 10:42 pm
Quoting BigJKU (Reply 14):
I would like to see the RAM and the Phalanx deployed together, to me the Phalanx is the last line of defence, it carries enough rounds to be used multiple times. To me the RAM was a solution to a problem of having space to locate launchers, it is easier to deploy and can be placed on ships where little to no custom installation is required.
I also think they need a frigate, my opinion the LCS is a target waiting to be hit, imagine deploying a ship of war with the arms not yet designed or fully designed.
I still have not heard much that have said that the Perry Class was a mistake, a cheap and I mean cheap ship is required to do littoral work, I'm not saying rebuild Perry's but a frigate is required. Other nations have frigates as their primary ship so it has much more sensors and weapons than the USA would need on theirs, after all, when the Perry's go the Burkes are the low end ships and they cost a billion dollars a piece, the LCS right now is a whole different story. Where are the mission modules and where did the idea come from that they could / would be ready when the ship was built.
sprout5199
Wed Jul 18, 2012 2:31 am
Well it is.
That being said. the CIWS was 1970's tech, I would hope that RAM is much better. RAM is a sea sparrow replacement. thats all. The phalanx was designed as a "last ditch' weapon, within a mile. RAM/Sea Sparrow was for further out.
I disagree. The "threat" went away in 1989/90. They were up graded it for ASuW, Land attack, refueling etc. in the mid-eighties. They became a "sea-control" aircraft. Do you really think a SH-60 can perform the ASW role for a CVN? by the time a sub is within a seahawks range, its too late. An you really want a supersonic fighter/attack aircraft doing refueling? how about loitering over a given area for hours looking for a go-fast with pirates on it? P-3/P-8 would work, if you have an airbase near-by. See a lot of them near Somalia?
I take it you were not alive in the late 80's. I was, serving in the Navy at the time, and do remember a lot of articles in the AF Times and such about how they wanted to kill the A-10 and replace it with the F-16. If you want me to dig up articles I will. They have tried to kill it ever since but have shut up since 2002.
Really? Have a UAV come in hot and you TRUST IT? Can a UAV tell the difference between a good guy and a bad guy? The controller is 6000 miles away. Nothing like a real human on the trigger. Why do you think the Marine aviators have camo helmets? Because they are MARINES first.
I do disagree. The Mk-92 FCS on the FFG was a good system, and IIRC we could hand off weapons to a Aegis system. No need for anything more, beyond 50 miles, you would have a CG/DDG.
The Adelaide Class FFG has the Mk-41 VLS and the capability to carry two helos. Not that a FFG carries two, I spent 4 years on one and never seen two onboard(the second hangar was a weight room).
Quoting par13del (Reply 15):
I hear ya. The Perry's were the low of the HI/LO thought. But they have shown how tough they are(due to the crew). That also show what "minimum manning" does for a ship. Both the Stark and the Roberts needed relief form other ships to fight fires when they were hit. A computer can control a turbine, but CANT fight the fire when something goes wrong. 20 to 30 minutes is all you get per man when fighting a class "B" fire in a MER, that comes from experience,.
Ok, this went on a tangent real quick. The Navy decided that it needed more SuperHornets at the cost of the S-3. That was a mistake as they did not have a suitable replacement for the Viking. I will argue all day long that a supersonic FIGHTER can not perform the duties of tanker, and be worth the money. Let alone the ASW role, which if it was "gone" why did they get the P-8? Lets not mention the SEAD mission that the EA-6 did(which the MARINES are now doing for the AF) and a F/A 18 is going to do?
Sorry I am a "Cold War" warrior that hates to see my tax dollars spent on billion dollar crap that cant do the job, or that somebody won't risk on doing the job. Just realized that is the 64,000 dollar question. Why spend 100 when you can spend 1,000,000 and never send it into harms way. My Navy's slogan was "Into Harm's Way", now its a "A Global Force For Good". What BS.
Dan in Jupiter
Edited to put E in front of "EA-6"
[Edited 2012-07-17 19:37:22]
DarkSnowyNight
Wed Jul 18, 2012 5:41 am
Good lord how? Don't incoming vampires move about 30 times faster than an FFG?
Or 79^16th times more on a set of prototypes stuck in development hell for over a decade. Did I read right that the F-35 program is now literally past the $400 Billion point?
In any case, if it makes us feel any better, on a drive past Davis Monthan last week I'm pretty sure I saw at least a few dozen S-3s that looked (condition wise) like they could probably be put back to work inside 90 days, should the need arise...
Much like a GE90, I'm a huge fan of Big Twins...
bigjku
Wed Jul 18, 2012 2:20 pm
Quoting sprout5199 (Reply 16):
Sorry but this is not right. Sea Sparrow (RIM-7) was replaced by Evolved Sea Sparrow Missile (RIM-162). On the carriers the ESSM replaced the Sea Sparrow in the box launchers as basically a direct replacement on aircraft carriers. It offers expanded range (out to around 30 miles now) and is significantly faster.
RAM (RIM-116) is generally fitted as a supplement to CIWS on US carriers in a trainable box launcher. In a different form as SeaRAM it can be directly fitted into the space previously allocated to a CIWS unit as basically a direct replacement for that weapon if one wishes.
No, they did not immediately pitch the things over the side as that would have been stupid. What they didn't do was start a new aircraft program to replace them and they didn't buy more. They let them run their natural course with the fleet, numbers were gradually reduced on the flight decks and eventually they all went away. But the upgrades referenced were really nothing more than giving them something to do as they played out their lives.
And yes, they have useful capabilities that were not replaced. But that is nothing more than a budget decision. I am sure given unlimited resources the USN would be flying the A-12, an S-3 replacement, an F-14 replacement and then using the F-35 to replace legacy F-18's. But that is not the world we live in. They consolidated naval aviation into the best platform we could reasonable get that could do the most missions in the F-18 because that is what made the most sense at the time.
I am fully aware they wanted to do it in the 1980's. It is a debate for another time and thread about if they were right in regards to that mission (let's just say I harbor doubts about the ability of the A-10 to survive over the central front in Germany by the mid-80's due to advances in mobile SAM's capable against low altitude targets and their terrifying density among Soviet forces by that point) but essentially since the Gulf War the Air Force has been firmly behind the A-10. At this point the complaint that they are trying to get rid of it is kind of silly. They aren't and they won't.
I am not really sure what you are getting at here. In a close contact situation the A-10 and any other aircraft or UAV is going to use the same weapons (Hellfire, Maverick, SDB, Paveway ect) and procedures so really one is not safer than another. Personally in a danger close situation I would prefer the help of an attack helicopter personally.
But what I was really referring to is the A-10's primary reason for creation which was to destroy large quantities of Soviet tanks well beyond the reach of direct fire weapons. There is new technology for dealing with a large advancing armored force at this point. You don't need A-10's with cluster bombs, Mavericks and cannons to do it at this point. You can perform the mission far more efficiently and with less risk using other weapons and aircraft.
This also kind of proves my point that things will continue to get bigger over time. They are being replaced with ships that will be North of 6,200 tons. The program that upgraded those frigate was also not thought about terribly favorably by anyone. It is telling that the upgrades were completed starting in 2008-10 time frame and and they will be replaced by the larger ships in 2014-2017 time frame. I don't think the small ships were satisfactory at all for Australia.
rfields5421
Wed Jul 18, 2012 2:32 pm
The French base in Djibouti seems to be work well for the US. We've had troops stationed ashore there since 2003, and P-3 aircraft most of the time since.
We also have access to airport in Kenya for anti-piracy aircraft.
747400sp
Wed Jul 18, 2012 11:49 pm
You mean the Super Hornet.
par13del
Thu Jul 19, 2012 1:18 am
Quoting rfields5421 (Reply 19):
Quoting BigJKU (Reply 18):
So here's the two questions:
1. Does it cost the US government more money to pay these nations to use their facilities to base a/c to do missions that could have been done by replacement a/c on the US carriers? Is the military able to get additional funding via the State Department budget but it can only be used in conjunction with foreign nations getting a "piece" of the action?
2. Does the use of these bases give these foreign nations any undue influenece over the actions that the USA may deem appropriate, and if so, is there factions within the US hierarchy who do not trust themselves and use this as a counterweight?
bigjku
Thu Jul 19, 2012 2:15 am
I think you are over-thinking it. A P-3 operating out of Diego Garcia can cover most of the Indian Ocean. The thing has a huge combat radius. More than that you are not going to cost justify sitting a carrier with 70-90 combat aircraft somewhere to stage S-3's on low priority missions. Operating a carrier cost far more than parking a few P-3's at a friendly base for these sort of missions. The P-8 would need refueling to get the range but could easily do the same thing with refueling support as well. In the future the persistent presence missions will be fulfilled by MQ-4C as well.
rfields5421
Thu Jul 19, 2012 3:46 am
Quoting par13del (Reply 21):
Using a land based aircraft is always cheaper than using a carrier. and
Quoting BigJKU (Reply 22):
The anti-piracy effort off Somalia is a multi-national program. NATO is heavily involved, as is France. The French have taken the lead role in several events. It is not a US only effort.
The nations in the area - especially Kenya and Djibouti - see the lawless nature of the region where the pirates are based as a great threat to their internal security, and citizens. The international effort to make shipping and the seas safe is something they want and support.
BTW another nation with troops based in Djibouti is Japan. Nations who have used their ships and/or troops against pirates include Russia, South Korea, India in addition to France and the US.
An average of 20 different nations keep warships in those waters at this time.
Kenya is emerging as the nation willing to put captured pirates on trial and punish them. Though Yemen did convict several in a trial a couple years ago.
[Edited 2012-07-18 20:51:55]
par13del
Thu Jul 19, 2012 10:16 am
Quoting DarkSnowyNight (Reply 17):
Yes, but planning for combat situations means that even though the nuke carrier is the fastest surface ship a formation will be entered to provide max protection, the Fig's attempt to catch a missile intented for the carrier means it put itself between the inbound threats line of attack and the carrier, usually the carrier has ships on all sides, the lucky / unlucky fig will be on the right / wrong side once the attack starts.
connies4ever
Thu Jul 19, 2012 1:46 pm
Quoting par13del (Reply 24):
Not willing to be a b*stard, but I have a hard time following that line of thinking. If you could clear for me, I'd appreciate it.
rfields5421
Thu Jul 19, 2012 2:02 pm
Quoting connies4ever (Reply 25):
The concept of placing a smaller "less valuable" ship in the line of attack to protect the bigger "more valuable" ships is a long tradition in the navy of various nations. The old four stack destroyers did it in the world wars to protect convoy ships from torpedos.
Yes, it can result in loss of life and even destruction of the smaller ship. That is their design job, and the men (and in some cases women) on those ships know their role and take pride in being prepared to do that job if necessary.
It is the essence of military forces throughout history - being willing to do everything necessary, maybe even at the cost of your own life, to protect your fellow sailors.
Frigates aren't just targets. They have some powerful missile defences and gear to try to scramble the missle's tracking. They fight hard, and if a frigate can isolate on a missile, it has a fair chance to survive without an actual hit.
sprout5199
Fri Jul 20, 2012 12:21 am
My bad, as we didn't have the SeaSparrow so I don't know the range of it. Did some looking, the RAM is between the CIWS and ESSM is range.
Until they start getting the F-35, them all bets are off, even though the A-10 will run circles around the F-35 for CAS.
Except for the cannon. And I trust a pilot diving in using the Mk-1 eyeball for the shoot/no shoot decision vs the UAV at 10,000 feet with a camera firing a missile. Maybe thats just me.
On that I agree, but for CAS, give me an A-10, AH-1, AH-64, AV-8B or a AC-130. Something with a human actually pointing the gun. Again maybe thats just me.
Because those in charge want the big sexy weapons, all or nothing. Who cares if it is too costly to use. See the B-1 and B-2. I remember stories about not using them as it would be "too costly" if we lost one "just "supporting" the troops in Dessert Storm. Warships and Combat Aircraft are made to go into harms way, no matter the cost.
I stand corrected. And Djibouti is such a $hit-hole. I pity those guys.
Quoting rfields5421 (Reply 26):
Yep. 100%. We knew that if the $hit hit the fan, we would be the outer layer of the muliti-layered CVBG or a Marine assault group against ASMs and Subs.We would take the hit instead of the carrier or gator-feighter. As I joke to my Army brothers at work, they were bullet stops, and we were missile stops.
We could hold our own, if the R.O.E. allowed it, see the Stark. Side note on that, in 1989 we were up at vacapes taking part in a VANDAL EX. A whole line of ships were there, CG's(most non-AEGIS), some Adams Class DDGs and us the only FFG. We shot the first VANDAL as it was just for us. Then they fired another one, we could track, but not fire as it was for the "big boys". So it came towards the line, and we waited and waited for the other ships to fire, no joy. So the TACCO released us to fire. We made an "over the shoulder" shot and hit it. None of the ships could fire, either no track or launcher malfunction. Our CO had me make a bunch of copies of the video tape(yes we had TAPE) and he personally delivered them to each CO in the after action brief the next day, just to show those guys what a missile launch looked like. Was a GREAT moral booster for use.
Dan in Jupiter
Added the AV-8B in my edit
[Edited 2012-07-19 17:31:12]
bigjku
Fri Jul 20, 2012 2:13 am
Quoting sprout5199 (Reply 27):
The A-10 is last on the list to be replaced so they are leaving all the wiggle room they can. The A-10 will also be out of service life at that point. Again, it is the last thing on the list to be replaced and the USAF just finished upgrading them. There is no agenda against the A-10.
All these aircraft are great as long as you are working in a permissive air environment. It can get pretty dicey if you are being opposed in any of those aircraft or operating in a high SAM threat environment.
Frankly that is just kind of insulting to everyone who works to put together weapons systems and requirements not to mention the people who command the forces in the field.
Your memory betrays you about the B-1 and B-2 as well. The B-1 did not go through the CMUP program (the one that let it drop conventional bombs) until 1993. The B-2 did not put the first operational unit into service until 1993 and did not hit IOC until 1997. So unless you wanted B-1's to drop nukes on the enemy or just scatter dumb bombs without any hope of hitting anything I am not sure what you are complaining about. Never mind that the Cold War was only sort of over at that point and the B-1 was a major part of the nuclear triad. Never mind that the B-52 was better equipped at that point to drop the bombs you wanted dropped to the support the troops. Clearly the USAF just flat said supporting the troops are not important and then sodded off to rub another coat of wax on their new sexy bomber. It seems very much that you have a conclusion already in mind and you are either misunderstanding facts or just flat imagining them to support it.
And this sort of goes to my larger point. It is easy to say that the people running the military are morons. And then it is easy to say they just like sexy, big weapons projects so that is why my personal Cold War favorite is not around anymore. This is almost always wrong but it is very easy to say. It is much more difficult to say that the people running the military have a lot of demands they are trying to meet and are people who are genuinely trying to do the best job they can and then try to examine the logic behind what they did. You can certainly disagree with what they did but coming to some level of understanding takes some work. It is much simpler to just say "they are morons" and they "like big sexy toys".
rfields5421
Fri Jul 20, 2012 2:09 pm
Quoting BigJKU (Reply 28):
I gave up decades ago trying to explain to civilian morons about how complicated development of new systems is in the military.
Yes, there are competing priorities within any large organization - the military isn't any different than most very large companies. They have limited resources and have to make their procurement dollars stretch to cover as many needs as possible.
(Actually after 20 years in the US Navy, and 20 years in the corporate world including 10 with a huge multi-national company - I find the military has a clearer thought process and goal definition than most successful companies. And smaller egos.)
It was cheaper once to design a new aircraft for every mission niche. It isn't any longer. And the Navy (USAF, USA, USMC, USCG) don't have that level of funding today.
As far as "big sexy toys" - sure we're all little boys at heart and want the best, fanciest toys possible. But that doesn't make it into the military procurement process.
Though I might agree it is a factor in the US Congress oversight role that heavily influences the US military procurement process. Though there the focus is usually "how many jobs can I get moved to my district for this system".
Revelation
Fri Jul 20, 2012 3:13 pm
My $0.02: The term military industrial complex should be written military-industrial complex to emphasize it's both sides that are the problem. No captain wanting to be admiral is too likely to get ahead by championing a new S3. Now, if it's a drone, you've got something there, at least for the next few years, when something else will be the sexy new toy.
Quoting BigJKU (Reply 12):
Max Q
Fri Jul 20, 2012 8:56 pm
Quoting rfields5421 (Reply 29):
With all due respect to your service we 'Civilian morons' pay your salary while you are serving.
And this civilian has a son currently serving in harms way.
Your Condescending attitude shows you have a lot to learn.
DarkSnowyNight
Sat Jul 21, 2012 8:08 am
I cannot imagine what kind of private sector enterprise would somehow be less organized than our military. If that has somehow actually been your experience, you have my condolences.
I do agree with that in principle, but it really doesn't excuse the disasters that the F-35 & the KC-46 programs have been, WRT development & procurement, respectively. It's difficult to imagine that the F-35 will really cost less over the long run than simply developing different (if somewhat similar even) types across the branches and for foreign customers.
smittyone
Sat Jul 21, 2012 12:47 pm
LOL, exactly.
What a disaster the military acquisitions process has become. And the Northrup Grummans and Lockheed Martins are laughing all the way to the bank, along with the army of contract powerpoint generators filling the corridors of the various HQs.
I think part of it is that every acquisition is entered with the dream that "this is our BIG chance to do something earth shattering that will give us the edge for the next 50 years". So everyone and their brother has an operational requirement for it and you end up with a Swiss Army knife that you can only afford a few of.
Thinking strategically, the tactical advantage provided by a superior weapons system is of no use if you go bankrupt producing it. To me it is more sensible to make more frequent incremental improvements that have a dramatically shorter and less expensive development cycle than the current paradigm of betting the house on projects that take forever to come to fruition at great risk of failure.
rfields5421
Sat Jul 21, 2012 3:22 pm
Quoting DarkSnowyNight (Reply 32):
My working theory is that it is a function of organization size.
One a base level, battalion level, a ship level - the US military is usually as efficient and organized as any small company of similar size.
On a major division level, publicly owned companies have just as many prima-donna's, egos, stupid rules, stupid processes, etc - as large government organizations.
sprout5199
Sat Jul 21, 2012 11:35 pm
Quoting rfields5421 (Reply 34):
I agree, and if the CO or CEO is a moron said organization will fail. Many CO's have been relieved for loss of confidence in their ability to command by higher ups.
Yep and since they are higher in the food chain, most survive as their subordinates "cover" for them so their careers don't go in the $hitter with the bosses.
Quoting Max Q (Reply 31):
Now boys, play nice.
It may be insulting but it is true. IMHO
I think the biggest problem is that the DOD doesn't require the "military industrial complex" to pay for any prototypes. You build it on your dime, if we dont choose you, bad luck for you, if we do thats great. If you dont like it, dont get involved. Also, we should have Navy designers for ships, Army ones for tanks, AF for airplanes, and well Marines for bullets(Joking you Jarheads). None of this here is want we want design it for us we'll pay you. We should have a set of planes, and have the "military industrial complex" build it to spec. That way you know what you are getting, and if the plans change mid stream, then its all on the DOD, not the builder changing stuff to in crease profits. Buildings are done this way and most are on budget and on time.
But alas, we will never go back to the days of a "hand shake" contract, designs on napkins, and both sides actually shooting for the same thing, a product that both are happy with.
Still think they should have never tried to make a jack of all trades master of none concerning F/A-18 and what they have tried to do with it. A fighter as a tanker, really? I digress again.
Dan in Jupiter
Flighty
Sun Jul 22, 2012 12:12 am
Can't agree, at least not yet. I've worked in some US govt and some megacorps. The megacorps do have bureaucracy, sometimes crazy amounts, but the bureaucrats are subordinate to the idea of making money. Government bureaucrats are kings. Literally nobody can question them. They are funded directly by Congress and answer to nobody.
At least that is my (probably less extensive) exper.
bigjku
Sun Jul 22, 2012 7:16 pm
Quoting sprout5199 (Reply 35):
I am sure this will come across as harsh but it seems exceptionally presumptuous of a person who has been factually wrong all across this thread with their criticisms of the military to call someone else. Your point you cited to support this (non-use of the B-1's and B-2's in the Gulf War) was complete garbage and I pointed out to you exactly why this was so. You implied that the Air Force refused to support troops on the ground when in fact they supported them robustly and with all the latest weapons (and appropriate) for the theater. To say this...
is ignorant. Either you are making it up or you heard it from someone similarly poorly informed and never bothered to educate yourself on what actually occurred. The facts are posted in this thread for you to view.
Again, the fact of the matter is that the S-3 was basically retired without replacement. The F-18 does as many of those duties as it can and as the Navy deems necessary. They did not retire the S-3 to buy more F-18's. They bought more F-18's because they elected not to replace the S-3 as it came to the end of its service life and had they gone to congress to get a new plane specialized for ASW work they would have been rejected very quickly. Take away the ASW capabilities from the S-3 and it is a nice airplane to have around, but does very few things that aren't otherwise being done by a different platform now.
747400sp
Thu Jul 26, 2012 7:00 pm
It is sad to see both the F-14 and S-3 go. S-3's, was still in heavy use at NAS North Island in 2004.
par13del
Thu Jul 26, 2012 8:38 pm
Personally, I think the Gulf Wars I and II showed how valuable the A-10 was that the Air Force had no choice but to stop trying to convert the politicians to their point of view that other fast jet could do the job just as good, my opinion only, no problem with us disagreeing on that point.
Correct me if I'm wrong but is that not one of the Air Force mantra when it comes to battle plans, they will establish Air Supremacy over the battle field first, then offensive operations could take place? Sgt. York aside, do we really believe that the Army cannot develop a true AAA gun system along with a medium range SAM system to protect troops in the FEBA?
One thing I will add, it does appear as if that philosophy pervaded the entire western forces, sure is strange that only the Eastern side could design and deploy something like the Shilkas.
Quoting Revelation (Reply 30):
I always thought the term referred to both sides, the Military folks and the Industralist who built the "stuff", hence my use of the term, if it should be used with the hyphen that's my bad.
No worries, we are both on the same page as to who is to blame, its a twofor
bigjku
Thu Jul 26, 2012 8:58 pm
Quoting par13del (Reply 39):
Yes, but it is far easier to deal with the systems that can reach up into the higher altitudes (which almost all have radar's involved at some point in the firing chain) than it is to deal with a bunch of IR based SAM's that are a huge threat when you go down low.
Air Superiority is not really achieved. Just because you have it does not mean you can now do whatever you want with impunity. I might have wiped out the enemy Air Force and crippled his radar guided SAM capability but it could still be very dangerous to operate below 10,000 feet due to IR SAM's. It is far easier to achieve enough control of the air and suppress the more robust higher altitude defenses so long as you can effectively engage your targets from that altitude.
par13del
Thu Jul 26, 2012 11:16 pm
Quoting bigjku (Reply 40):
Which really is an Air Force issue not the Army, they want to close with the enemy and engage, however, they cannot do so until the Air Forces says its 'Safe'.
Folks talk about the Air Force not being interested in CAS support, but based on the battle plans they have no choice, even the attrition of enemy artillery has to be accomplished by air as the US artillery pieces may be accurate but are not the longest range.
To western forces yes, as the number of AAA and MANPAD's deployed by say Soviet bloc forces during the cold war were quite high. The air defense bubble created over western forces were more based on air supremacy verus self protection mobile air defense which could travel with the troops.
In the US Army what assets do they have to project an air defense bubble over troops other than a/c, does the Army control the Patriots or the Air Force, I know of the Avenger and the Stingers including those as MANPAD's.
Users browsing this forum: zanl188 and 6 guests
