JayinKitsap
Air Force One & Marine One
Fri Aug 10, 2012 8:54 pm
Bloomberg has posted this article
http://www.bloomberg.com/news/2012-0...ir-force-one-presidential-jet.html
As much as I love to see new metal, with our current economy does it make sense to charge into this.
PC12Fan
RE: Air Force One & Marine One
Fri Aug 10, 2012 11:59 pm
Quoting JayinKitsap (Thread starter):
Yes from the planning aspect. The article states an entry date of 2019. With 3 to 4 years between from time of purchase. Looks like we could be looking at a Sikorsky S-92 based Marine One and a 747-8i for Air Force One suggested by this article, but it's still a long ways out.
On a side note, I wonder if the "attic space" would be used on the 747-8i if it is chosen.
Just when I think you've said the stupidest thing ever, you keep talkin'!
rfields5421
Sat Aug 11, 2012 1:29 am
That's just the point - they are not charging into this.
The plan for the procurement has been around for years, and the planned new metal is near a decade away.
This is part of a very long process, the only impact on the 'current economy' is that some workers might get to keep their jobs because the procurement keeps on going with the planning.
Stopping the procurement process will have to effects. One is that a lot of people would lose their jobs, and the other is that the eventual replacement aircraft would cost a lot more.
USAF336TFS
Sat Aug 11, 2012 12:50 pm
Procuring new Presidential aircraft will have negligible impact on our budget woes. Our problems have much more to do with entitlement spending, as is the case with most Western nations. Quite frankly, to me this isn't even a blip on the radar screen when compared to other budget challenges. The VC-25As are fast approaching the end of their service life and will need to be replaced, just as the Marine One aircraft will also need to be. I'm much more concerned that enough KC-46As are built to support our military goals. 179 seems a bit too low a number, but that's another debate...
The article has mentioned sole-sourcing Air Force One from Boeing, and that to me suggests that the 747-8i is the clear favorite. Marine One replacement will be interesting. I'd love to see at least two VH-22s procured for that mission.
Quoting PC12Fan (Reply 1):
Count on it. Avionics and communications equipment on-board existing VC-25A's are state-of-the-art and use every available nook and cranny. The same will be true of the new 747 replacement aircraft.
[Edited 2012-08-11 05:57:30]
336th Tactical Fighter Squadron, 4th Fighter Wing, Seymour Johnson AFB
LMP737
Sun Aug 12, 2012 1:46 am
Quoting USAF336TFS (Reply 3):
What's the daily utilization rate of Air Force One? It's going to be a lot lower than your average 747 in airline use. You could keep those things going for another fifteen years easy.
gigneil
Sun Aug 12, 2012 1:49 am
They can keep it flying - but it is beyond maxed out on its infrastructure use.
Simply put, they need more electricity, and they cannot generate it on those 742s.
NS
ssteve
Sun Aug 12, 2012 2:04 am
Quoting gigneil (Reply 5):
You put it that way and someone will have the brilliant idea of re-engining them for a mere $1 billion each.
kc135topboom
Sun Aug 12, 2012 2:02 pm
The failure of the VH-71 program was as much a fault of the Secret Service and the White House as it was the USN (who would have bought the Marine-1 helios). So, before we start the program we have to set rules as to what all these entities can input into the program. If we don't do that, then we learned nothing from the VH-71 program.
The USAF has a pretty good grasp of what is needed by an Air Force-1 in the way of aircraft defenses, so let them run with that. The same can be said for the USMC in defending Marine-1.
Don't forget, these will be the first of a series of new VIP aircraft purchases. Soon after the new AF-1s are inplace it will be time to replace the C-32A/Bs, and just after those the C-40B/Cs and C-37A/Bs.
Revelation
Sun Aug 12, 2012 2:31 pm
Quoting KC135TopBoom (Reply 7):
As for the helos, I think they need to put in the rule that they need to stay within the lifting capacity on the commercial spec sheet, minus 10% for growth, and same for its cabin volume. The problem with VH-71 was they kept adding more stuff to it to the point where we were paying to develop what was in essence a new model of helo bit by bit, which is what led to the massive cost overruns.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
par13del
Sun Aug 12, 2012 4:59 pm
The Marines already have the Osprey in service, I thinkg the odds are good that a couple will be assigned to the unit who provides / flies the Presidential Fleet, whether POTUS will actually ride in one is another story, but the odds of them being there in a support capacity are high, support meaning they will ferry troops and other VIP but not be a part of the Official Fleet.
Rose Garden upgrades are not prudent during this fiscal crisis .
LMP737
Tue Aug 14, 2012 4:54 pm
If that's the actual case then all I can say is that's what mods are for.
bikerthai
Tue Aug 14, 2012 6:27 pm
Quoting SSTeve (Reply 6):
Quoting LMP737 (Reply 10):
What is inferred is that the need for more electricity comes from the need for more equipment to be installed.
If you figure the additional cost of the new equipment, new engines (modified from existing engines) and all the associated wiring needed to be routed (new power cables from the engines and all the internal wiring from the new equipment, the cost of the airframes would not be a major driver. And by the way, what would POTUS be flying the 2 years or so required to do the mod?
bt
ikramerica
Wed Aug 15, 2012 6:26 am
The current AF1 aircraft have already been in service as the primary aircraft longer than any previous examples and with 6-7 more years, will be past 25 years as primary aircraft. SAM2600 acted as the primary aircraft for 10 years, then took on aback up role through 1998. SAM2700 spent 18 years as the primary aircraft, then some years as AF2, then time as a backup until 2001.
It's hardly wasteful to replace a mission critical aircraft as it approaches 30 years old. We are talking maybe $50M a year amortized cost, or 50 cents per taxpayer per year. The yearly cost to operate them is far more than the cost to buy them.
LMP737
Wed Aug 15, 2012 3:51 pm
Quoting bikerthai (Reply 11):
You don't need new engines in order to get more power.
bikerthai
Wed Aug 15, 2012 4:37 pm
Quoting LMP737 (Reply 13):
True,
There are a variety of ways to get more electrical power. What came to my mind was adding generators to the engines or APU's.
bt
Cadet985
Fri Aug 17, 2012 2:52 am
Quoting LMP737 (Reply 4):
From what I understand and I could be misinformed, even when not flying POTUS, they fly a few times a week, usually practicing approaches into Harrisburg IAP.
I have a friend in the PA ANG who's stationed there...I'll see if he can tell me anything.
dragon6172
Sat Aug 18, 2012 9:11 pm
Quoting par13del (Reply 9):
Last Marine aviation plan I saw had Ospreys coming to HMX-1 between FY 17-18. Only as the support aircraft of course.
Phrogs Phorever
AirRyan
Sat Aug 18, 2012 11:47 pm
The Osprey's interior dimensions are considered unfavorable for POTUS use; fine for the press corps, just not the POTUS. The USAF is open to any and all serious bidders, even if they don't go with Boeing as the prime. And keep in mind, the VC-25's may not have a whole lot of flight time relative to their age, (they do have an above average for the flight time and age,) but they do have an well above average number of cycles considering most 747's don't takeoff and land an hour later for a political rally or dinner.
checksixx
Sun Aug 19, 2012 6:02 pm
Quoting Cadet985 (Reply 15):
Yes, they keep up on hours training....they fly into Newport News, VA, often.
USAF336TFS
Mon Aug 20, 2012 7:36 am
Quoting AirRyan (Reply 17):
And exactly who else would bid? Airbus obviously read the writing on the wall and has already announced they will not participate in the VC-25A replacement program.
bikerthai
Mon Aug 20, 2012 1:12 pm
Quoting USAF336TFS (Reply 19):
AirRyan was talking about being prime. Even though the -8i may be the leading candidate, Boeing is not guaranteed of being prime. NG is a possibility. They have plenty of mod experience. The list of qualified prime may be small, but not limited to 1.
bt
USAF336TFS
Mon Aug 20, 2012 6:47 pm
Quoting bikerthai (Reply 20):
In this situation, especially with Boeing's long history with the Air Force, there's little chance they wouldn't be the prime contractor. Yes, is it possible that NG or LM would be prime? Of course, but this contract has Boeing written all over it IMHO.
bikerthai
Mon Aug 20, 2012 9:02 pm
Quoting USAF336TFS (Reply 21):
I hope you are right . . . I would love to get on that project.
bt
kc135topboom
Thu Aug 23, 2012 10:00 pm
Neither NG, nor LM have an airplane already flying they could develope the VC-X from, Boeing does and Airbus does, but Airbus backed out.
bikerthai
Fri Aug 24, 2012 1:04 pm
Quoting KC135TopBoom (Reply 23):
No but the option is for the Air Force to buy the 747-8 BBJ from Boeing and fly it to NG or LM for mod.
Since only 3 or 4 frames are involved, it's hard to say who can do the work for the least amount of money or who has the most congressional political clout. I would assume the USAF and SS already have wthat electronic suite to be installed in mind.
bt
rfields5421
Fri Aug 24, 2012 1:31 pm
Quoting bikerthai (Reply 24):
In broad concepts - yes. In details - no.
One of the lessons learned from 9/11 is that holding the AF1 electronics suite static causes the US President to fall behind available technology and unable to communicate efficiently. AF1 didn't even have a live TV capability on 9/11, and no video conferencing.
kanban
Fri Aug 24, 2012 4:03 pm
Quoting bikerthai (Reply 22):
I was on the both the 747a and the 757s.. count on long hours, headaches, and unreasonable senior managers with zip experience. Hopefully the P-8 'plug and play' will incorporated to make upgrades easier.
Next week we should start a new livery design contest
bikerthai
Fri Aug 24, 2012 6:29 pm
Quoting rfields5421 (Reply 25):
But if you don't have the stuff pre-defined, you run the risk of mission creep (AKA Presidential Helicopter) or long development cycle.
I can see an open architecture for computing processing, but many of the other systems Communications, Datalink etc. . . should be already available on other Military aircraft.
bt
135mech
Fri Aug 24, 2012 8:10 pm
It's been said a few times on here that there will be 3 or 4 frames...I don't think there will be more than 2. The current fleet is two and the USAF would have to revamp it's spendy hangars that they made just for the current ones (they are NICE too). Plus after all of the TONS of $$$ spent on the now moth-balled YL-1A, that might be a factor on reaching for 2 at most. The YL-1A was a good "idea" but sadly it was just to costly.
135Mech
135Mech
AirRyan
Fri Aug 24, 2012 8:36 pm
Exactly. The scenario where two new 747-8i's are taken off the line at KPAE and flown bare metal somewhere else for mod is indeed very possible, and the USAF would have zero problems with it that should Boeing not be the prime.
Boeing would be very unwise to take the USAF for granted, they already got a big bone with the KC-X award and USAF owes them nothing. Besides, Of course, Boeing can play it down by saying that at least it's their aircraft flying the President around. I readily expect Boeing to win the VXX bid next time around, even if they will be the prime on a European designed helicopter. (H-101)
kanban
Sat Aug 25, 2012 1:00 am
Quoting AirRyan (Reply 29):
this has been discussed several times (threads) before. These planes are significantly different from the very beginning.. unlike a BBJ makeover, all the wiring would be stripped and replaced, a significant amount of structure removed and replaced, provisions for air-stairs require removing structure around the for and aft doors, revised floor beams, .. They only look like the production article. So why not make the changes during the production process? OK you could argue that some supplier could specify Boeing build it to USAF specs and then they would put in the interiors... Boeing would price the bird out of sight. So Boeing will build, outfit, maintain and upgrade just as it does today.
So why in several threads do you keep wanting to rehash this.. seems to me there was quite a bit of ill feeling toward Boeing in some posts...
The only way a company could convert a production unit cheaper than Boeing would be to buy all the components, skins, ribs, etc everything in kit form and try to assemble without tools or experience and make all the changes as they go... trouble is they could not get a production or airworthiness certificate.
On the other hand there was very little structural difference with the 757's.. the entire interior went in within the standard production flow. The communications gear was plug and play..
dw747400
Sat Aug 25, 2012 1:53 am
Quoting 135mech (Reply 28):
Based on what I've read and a few folks I've spoken with, it sounds line the Air Force wants at least three. That way when one goes into extended heavy maintenance there is still a primary and backup available. Of course, in this fiscal climate it may be difficult to justify the cost, especially if the the VC-25As are kept active and available as backups.
CFI--Certfied Freakin Idiot
gigneil
Sun Aug 26, 2012 7:24 am
It cannot be done. That aircraft is totally maxed out.
The infrastructure of the plane would need to be ripped and replaced and they would still be out of space for the gear they want.
Quoting bikerthai (Reply 14):
Both of which very obviously have them already.
I am right on this guys.
NS
AirRyan
Sun Aug 26, 2012 1:37 pm
Quoting kanban (Reply 30):
You're arguing the same thing Boeing is to the USAF, that there is no other way. But there is, the USAF would not be opposed to certain other companies taking the prime - sort of like NG on the KC-30 in an Airbus. Three aircraft? no problem. For starters, look for vendors who have experience with 747 VIP mods.
"How much for one rib?"
http://sedislogistic.files.wordpress.com/2011/04/zwischenablage021.png
rfields5421
Sun Aug 26, 2012 4:39 pm
Quoting dw747400 (Reply 31):
Currently there are the two VC-25. There are also four E-4B aircraft which can be used as backup when one of the VC-25 is unavailable.
The E-4B are planned to stay in service to near 2015-2017. When they are gone there will not be a third aircraft for backup on overseas trips if one of the new AF-1 aircraft is down for major maintenance.
The VC-25 will be retired soon after the new aircraft come on line. They are not reconfigurable for other usage, and they will be too expensive to maintain as ready use backups.
While the planes are costly, it would be much more cost efficient to procure three in the initial order than just two, and determine late that a third is needed.
Also, as far as fiscal climate - we are talking about spending the majority of the money in 4 to 7 years. These procurements put millions of dollars into the pockets of workers in the United States.
Frankly, I find that a better use of government money than a lot of current projects, even in DOD.
kc135topboom
Wed Aug 29, 2012 1:38 pm
Even if that happens, the public will know these as Boeing built airplanes if they are B-747s. The public really never knows, or cares who puts in the interior fixtures.
Even if Boeing only builds the bare bones airframes, I believe they will have many of the unique features the VC-25s have, such as duel APUs, and left and right side cargo doors with air stairs and an air refueling capability
bikerthai
Wed Sep 05, 2012 4:44 pm
Quoting KC135TopBoom (Reply 35):
You haven't seen what Boeing charge for Engineering hours.
bt
citationjet
Wed Sep 05, 2012 7:37 pm
such as duel APUs
Not sure about "duel" APU's (do they not get along?), but AF1 does have "dual" APUs.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Users browsing this forum: Baidu [Spider] and 1 guest
