harrystanhope
Green Stripes On AUS Military Aircraft
Tue Oct 02, 2012 9:31 pm
Hey
I'm from Townsville in Aus, I work as a ground handler for JQ and also a junior flying instructor at the local school.
A few times now whilst working at night I've noticed most of the military aircraft, such as C-17, F/A-18 and tankers, have green stripes along the surfaces. For example the rudder, overhead cargo doors etc.
What exactly are they for?
Is it used by ground handlers or anyone else? The stripes were visible on the F-18's that took off last night.
Look forward to hearing from everyone!
Thanks in advance
AvSafety46
RE: Green Stripes On AUS Military Aircraft
Tue Oct 02, 2012 10:32 pm
I believe those are the formation lights. They are used at night so other Military aircraft can discern the attitude of the aircraft when joining in flight and flying in formation. The green color is used so NVGs will not blackout to the brightness of the light and it is easier for the human eye to see green light and not lose their night vision.
BMI727
Tue Oct 02, 2012 11:51 pm
Quoting AvSafety46 (Reply 1):
Actually I thought red is the color best used to avoid losing night vision, hence why ships will "rig for red" at night. Green is used for NVGs because the eye is most sensitive to it.
Spacepope
Wed Oct 03, 2012 12:58 am
Kinda like the 3 bits on this F-14? On the tail, fuselafe above the word "navy"and on the nose?
Photo © Neil Jones - Angels-20
Those IIRC are formation lights- low voltage lights for night use, that are not readily visible from the ground when at altitude.
harrystanhope
Wed Oct 03, 2012 1:51 am
Yes that looks like them! except they were a bit bigger, newer aircraft I guess.
Very insightful information everyone! Thanks so much for the responses
I'll be sure to put them on our Cessna's
kc135topboom
Wed Oct 03, 2012 9:59 pm
Quoting Spacepope (Reply 3):
Quoting HarryStanhope (Reply 4):
Yes, they are formation lighting. They are used on any airplane that does night formation work, and they are controled by a reostate on most airplanes, so the brightness can be adjusted. We did not have them on the KC-135 while I was flying her, but it was always planned to put them on. I don't know if it ever happened.
They are on the;
KC-10
KC-30/A-330MRTT
KC-767/KC-46
Some C-130/KC/EC-130
all US and most Allied fighter aircraft
C-17
The F/FB-111 had them (they also had to original amber colored formation lights but they were disconnected).
The A-310MRTT/KC-310 may have them, but I don't really know.
They are just thin strips of luminous material covered with fiberglass and not really lights or LEDs.
Scooter01
Thu Oct 04, 2012 6:48 am
Quoting KC135TopBoom (Reply 5):
..and how is that supposed to work -or did I miss something?
Scooter01
dragon6172
Thu Oct 04, 2012 11:42 pm
Quoting Scooter01 (Reply 6):
http://www.astronics.com/products/ai...ighting/formation-lights.asp#green
Link to the manufacturer with a quick description of the lights.
Phrogs Phorever
rfields5421
Fri Oct 05, 2012 1:11 am
The key paragraph
The EL phosphor provides for a solid state device that emits a uniform luminance over its entire surface. Since EL lamps have no filaments or bulbs they do not experience catastrophic failures and are the ideal light source to withstand the extreme shock and vibration common to the rugged environment of military aircraft.
I didn't know this technology existed.
Scooter01
Fri Oct 05, 2012 7:38 am
Quoting dragon6172 (Reply 7):
Quoting rfields5421 (Reply 8):
Neither did I -obviously.
(wondering why the emoticon in my previous post didn't work)
Scooter01
135mech
Thu Oct 18, 2012 6:01 pm
No, they have not put them on our birds, and probably never will with the KC-46 coming now. Would be pretty sweet looking though!
Quoting BMI727 (Reply 2):
I would (safely) assume that with red being thought of as "warning" indicators, especially with most cockpit lights etc... that may be why they did not use red, since there are so many of the lights on each plane.
135Mech
135Mech
rwessel
Thu Oct 18, 2012 10:52 pm
While it's true that for exposure to a given intensity of light, red has the least effect on dark adaptation, the problem is that we're not particularly sensitive to red light, particularly in details, so your ability to read (for example) is significantly reduced under red lights. So people have a tendency to turn up the intensity of the red lights, which increases the negative impact on dark adaptation. The USN, for example, found that there's little benefit to red lights compared to white lightly, when the lights are adjusted for equal ease of *seeing*. So USN submarines switched from red lights to (dim) white lights many years ago, when conducting night operations on or near the surface where night vision might be important.
