g38
Last Flyable Canberra
Sun Dec 23, 2012 2:35 am
For a number of years a group called Classic Aircraft Projects operated the only privately owned Elglish Electric Canberra (G-BVWC, WK163). The last photo of it flying in the data base is dated 2007. I did a quick google search, but could find no evidence that is is still operable. Has it followed the Vulcan an the B-17 (F-AZDX) into early retirment like most large European warbirds seam to do?
Also, I heard a rumor that NASA might be modifying a third B-57. Does anyone know if this is true? How much longer do they plan to operate their current aircraft?
Classic Aircraft Projects Canberra
Photo © Mark Wright
NASA's B-57
Photo © João Toste
kl671
RE: Last Flyable Canberra
Sun Dec 23, 2012 4:20 am
Wikipedia reports that a Martin RB57F (NASA 928) was still active in June 2012.
http://en.wikipedia.org/wiki/Martin_RB-57F_Canberra#NASA
ptrjong
Sun Dec 23, 2012 10:24 am
Another quick Google search:
http://www.airbase-europe.com/canb2.html
G-BVWC suffered an engine failure in 2006 and ever since a worldwide search has been underway to find a replacement Rolls-Royce Avon 109 with the correct paperwork to allow a return to airworthiness.
My guess is that the operating costs are a lot less excessive than those of the Vulcan, not in the same league.
garysted
Sun Dec 23, 2012 3:28 pm
Gents,
As I understand it, NASA currently operate two WB-57s (926 and 928). 926 transited through RAF Mildenhall, here in the UK homeward bound only a couple of weeks ago. Both aircraft have been taking it in turns to support BACN operations in the Middle East. Not sure where, but I've read somwhere in the last couple of weeks that a third (to be 927) is being prepared for flight.
Gary
g38
Sun Dec 23, 2012 6:36 pm
If it had an engine failure in 2006 then explain to me this:
Photo © Mark Wright
ptrjong
Sun Dec 23, 2012 6:55 pm
Quoting g38 (Reply 4):
Apparently a mistake on their website then...
A single date in the database can also easily be wrong, but there are several 2007 flying pictures.
KC135Hydraulics
Sun Dec 23, 2012 8:58 pm
NASA's RB-57 stops by my base every now and then working with some of the big aerospace companies flying test missions. The pilots are usually older gentlemen and are VERY friendly. They let us check out the aircraft, hand out cool patches, and talk about the plane. Right now they said the engines on the aircraft, which I believe are TF-33s scavenged off of KC-135Es, are so powerful, they can only use about 70% thrust for takeoff. He said at full thrust, the minimum control speed is so high they would need to be well airborne before the rudder would have enough authority to counter an engine-out.
Interesting stuff! Typically they are flying around 70,000ft + for their tests too, he said.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
Spacepope
Mon Dec 24, 2012 4:10 am
Quoting kl671 (Reply 1):
Both aircraft have been active this month, they tend to fly wit their tail numbers as call signs, so are pretty easy to track.
http://flightaware.com/live/flight/N...8/history/20121210/1900Z/KLSV/KLSV
mothguy
Mon Dec 24, 2012 6:06 am
There is also a Canberra down here in Oz (VH-ZSQ) which was airworthy and displaying until recently with the Temora Aviation Museum. She is currently undergoing work which I believe will keep her hangar-bound for a year or so before she returns to the skies.
dlednicer
Crew
Mon Dec 24, 2012 6:44 am
Air Platforms used to operate N30UP (WT327) and N40UP (XH567) out of Lakeport California. They are now registered to High Altitude Mapping Missions, Inc. of Spokane, Washington, but I don't know if they are active.
MD11Engineer
Mon Dec 24, 2012 11:57 am
Quoting g38 (Thread starter):
NASA's B-57
I´ve seen this thing in Kandahar airbase, Afghanistan, earlier this summer, but I couldn´t take any pictures ( np picturetaking permittend in this military restricted area).
Jan
garysted
Tue Dec 25, 2012 11:31 am
Quoting MD11Engineer (Reply 10):
Hi,
I'd guess this is the one you probably saw below, routing back to the US earlier this month through Mildenhall on a bright Sunday lunchtime. Must have been about 50 or more of us waiting for it to arrive...
Photo © Ashley Wallace - Touchdown-Aviation
Not my pic, as mine is still in the upload queue. Ash is usually pretty informed about US aircraft, so I'd say a third is on the way.
Gary
wb556
Tue Dec 25, 2012 7:33 pm
There is also a PR.9 at Kemble that should fly soon.
g38
Wed Dec 26, 2012 4:55 am
Quoting WB556 (Reply 12):
Indeed, this is wonderful news!!
After a bit of searching I found that the aircraft is XH134, soon to be G-OMHD.
More information here: http://fightercontrol.co.uk/forum/viewtopic.php?f=322&t=67944
Photo © Mark Broekhans
Users browsing this forum: st21 and 8 guests
