G500
Photo- "Break Away" In A Gulfstream-V /C37A
Thu Jan 10, 2013 8:00 pm
Is it wise to do a "break away" fighter jet style in a high-performance commercial jet like a G-V? (Granted it looks like it was during an airshow).. I like the spotter's comments
Photo © Nicholas Peterman
Tugger
Thu Jan 10, 2013 8:07 pm
Well it is not a "Gulfstream V" but rather a C-37A, the difference being the former is a civilian jet and the latter is a "spec'd for the government" version of the jet. It quite likely has additional systems that may allow things like this without problems (not that I actually know).
I guess the real question is what are the differences between a "stock" G-V and the C37A?
Tugg
BMI727
Thu Jan 10, 2013 8:39 pm
Quoting g500 (Thread starter):
No reason not to, especially if the aircraft is lightly loaded. Passengers may not appreciate it and it isn't something you'd probably want to do on a regular basis, but occasionally it's probably just fine.
Quoting tugger (Reply 1):
As far as the airframe goes, nothing I think. The C-37 has some additional avionics and maybe some extra bolt on type equipment, but I don't believe the engines, airframe, etc. are appreciably beefed up over a bone stock G-V.
Rdh3e
Thu Jan 10, 2013 9:03 pm
If a 707 can do a barrel roll, I'm sure this is perfectly acceptable in the Gulfstream.
http://www.youtube.com/watch?v=-vHiYA6Dmws
G500
Thu Jan 10, 2013 9:22 pm
I fly G-V/550s.. Would be great if I could attempt something like that, but I won't (I kind of need my job)
This photo will be on as my screensaver for many days
Tugger
Fri Jan 11, 2013 12:25 am
Quoting BMI727 (Reply 2):
I am thinking it may have different oil and fuel elements that make it safer to do this kind of thing.
Of course probably the real reason this plane can do this is because unlike g500 above, the pilot doesn't worry about not keeping his job because quite frankly the "company" that owns the plane doesn't care that much about doing damage to it. I meant hey can always get another one if they need to.....
Tugg
n53614
Fri Jan 11, 2013 12:58 am
An overhead approach, while awesome-looking, really isn't that big of a deal. I have personally seen a C-5, C-17, two C-130s, a KC-135 and an E-3 do an overhead approach.
B722 B732 B733 B734 B735 B73G B738 B739 B742 B752 B763 B772 A319 A320 A332 CRJ2 DHC8 DH8D E135 E140 E145 MD83
flymia
Fri Jan 11, 2013 1:04 am
Just YouTube airliners at air shows. What an empty 757 or even 747 can do is impressive. Remember these airplanes are made to withstand a lot more than even a horrible flight with terrible turbulence.
Acey559
Fri Jan 11, 2013 1:09 am
I know the chief pilot at John Deere and he mentioned to me one day that the wing on the G-V/550 is so big that you could do an 80-90 degree back and hardly even feel it. I think he was slightly exaggerating but he said the big wing is so comfortable that aggressive maneuvers like that aren't nearly as uncomfortable as you'd think they'd be or like they might be on an airliner or other corporate jet with a smaller wing. As a side note, that's one CLEAN plane! I always appreciate how corporate flight departments take care of their equipment (understandably) compared to the planes I fly.
G500
Fri Jan 11, 2013 1:23 am
Quoting Acey559 (Reply 8):
the G-V/550 wing is pretty darn long..... G-V/550 vref speeds are usually around 115-120, because of the long wing.
Photo © Kevin Scott - Jetwash Images
[Edited 2013-01-10 17:24:53]
Acey559
Fri Jan 11, 2013 2:25 am
Quoting g500 (Reply 9):
It definitely is a beautiful aircraft with some amazing capabilities, that's for sure!
Silver1SWA
Crew
Fri Jan 11, 2013 2:32 am
Quoting RDH3E (Reply 3):
A properly executed barrel roll is a 1G maneuver throughout the roll.
The maneuver seen in the photo in the OP would likely be higher than 1G.
dragon6172
RE: Photo- "Break Away" In A Gulfstream-V /C37A
Fri Jan 11, 2013 2:59 am
Considering there is no reference in the photo to determine the bank angle, it probably was not as steep as is being assumed here. GV/C-37 max bank angle is listed as being 60 degrees, and I am guessing these pilots did not exceed that limit.
Phrogs Phorever
Kiadprthd
Fri Jan 11, 2013 5:08 pm
When I saw this picture, it reminded me when I was down at Norfolk Naval Base for work last summer. We were on one of the piers walking to a morning meeting and I happened to look out over the bay and saw an inbound Navy C-37. I was somewhat surprised to see as it got closer, it still had its gear up and had maybe 5-10 degrees of flaps down, but was going well above 200kts. It flew above us at around 1,000 feet and once they got a little past midfield, the pilot did a carrier break and came around to land. I had never seen that performed by a Gulfstream, and thought it was the coolest thing to see. I want to say the bank angle was between 30-45 degrees, but I may be wrong. A few mintues later after the C-37 landed, an E-2 and a couple F-18s did some breaks and the C-37 was just as smooth and agile as they were in the break.
kc135topboom
Sat Jan 12, 2013 12:53 am
Quoting n53614 (Reply 6):
Quoting Silver1SWA (Reply 11):
An overhead pattern is also just a 1G maneuver. It is no big deal for the airplane.
titanmiller
Sat Jan 12, 2013 5:40 pm
Quoting KC135TopBoom (Reply 14):
A 45º overhead would produce 1.4g (as would any level 45º banked turn). The KC-135 is rated to 2.5g in certain conditions.
Max Q
Sun Jan 13, 2013 3:43 am
Quoting titanmiller (Reply 15):
So is just about every commercial jet Aircraft.
Users browsing this forum: Nean1 and 1 guest
