KRIC777
Do Fighters Have Autopilot Like Commercial Planes
Sun May 05, 2013 6:33 pm
Probably a stupid question, but I was wondering if air-to-air combat fighters have autopilot packages that will control the aircraft to the extent that commercial planes do (i.e. basically takeoff to landing) ? On one hand, it would stand to reason that there would be an advantage for an F-15 / MiG-29 driver to be able to plug in an altitude, speed, and heading to get them to within a certain distance of the "hot zone", and then take over the controls before the s##t hits the fan. In the meantime, they can be more carefully monitoring the radar and radio traffic to get a feel for what's going on in the battle zone. Then, once mission completed and flying home, and the driver is jacked-up on adrenaline, the plane could fly itself back to within a few miles of home-base.
Legs
RE: Do Fighters Have Autopilot Like Commercial Planes
Sun May 05, 2013 8:20 pm
The autopilot in most fighters is very similar to commercial planes, if not arguably slightly more powerful. Just like a commercial plane, a fighter will dutifully follow the preprogrammed flight plan the pilots have loaded, which on most current models includes altitude and mach/airspeed.
The pilot can also manually program the autopilot to hold a set mach, set altitude, set attitude and often best cruise speed and best range.
A fully automated takeoff isn't part of any military autopilot I know of, but modern carrier based jets certainly have a full auto-land routine.
kc135topboom
Sun May 05, 2013 9:17 pm
Carrier borne aircraft have a sort of autopilot T/O mode from the CV. The pilot sets the power and then grabs the hand rails on the canopy so the cat operator can see his hands are clear. A cat T/O has several G forces and if the pilot was holding the stick, he would point the jet almost straight up as he inadvertently pulls the stick back due to Gs.
autothrust
Mon May 06, 2013 11:13 am
There are fighter planes like the Typhoon which have much more extensive autopilot capabilities like :
Auto-Climb, Auto-Take Off, Auto-Approach, Auto-Attack, Auto-CAP, Auto-Attackformation, Auto-Intercept, Panic Mode etc.. some of these Modes can be activated by Voice command.
The autopilot is an integrated part of the pilot's tactical control.
“Faliure is not an option.”
KC135Hydraulics
Mon May 06, 2013 11:44 pm
Quoting autothrust (Reply 3):
I'm curious what the panic mode does!
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
tommytoyz
Tue May 07, 2013 4:03 am
Quoting KC135Hydraulics (Reply 4):
Pinches you so that you wake up and realize it was all just a dream....
Francoflier
Tue May 07, 2013 6:27 am
New gen fighters are all FBW anyhow. An elaborate autopilot is just a matter of software these days.
autothrust
Tue May 07, 2013 11:46 am
In the case the pilot looses orientation, he can push a button wich executes a emergency stabilisation of the plane.
That means the FCS takes full control of the engines and flying controls, and automatically stabilises the aircraft in a wings level, gentle climbing attitude at 300 knots, until the pilot is ready to re-take control.
When the safe speed envelope has been reached the autopilot executes a Auto Low Speed Recovery.
mig21umd
Tue May 07, 2013 12:02 pm
Looks like the new generation of fighter planes have a pretty good auto pilot system but I do not think that was entirely true with 4th generation fighters. Talking with a RAAF FA 18 pilot about this he told me that all they had in terms of auto pilot was heading and attitude (not altitude) hold.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you long to return
autothrust
Tue May 07, 2013 1:54 pm
Quoting mig21umd (Reply 8):
The autopilot capabilities i've posted are alone from the Eurofighter Typhoon.
Still many "experts" here think its a outdated 4th generation fighter.
sprout5199
Tue May 07, 2013 2:19 pm
Quoting KC135TopBoom (Reply 2):
IIRC the only jet that has it is the F-18 family, all the others are manual T/O. And also IIRC it can land itself, not that any pilot will let it.
Dan in Jupiter
RussianJet
Tue May 07, 2013 9:38 pm
Quoting autothrust (Reply 7):
That makes good sense. Initially it sounded like setting 'panic mode' would send the plane hurtling round in circles for no good reason, rather than doing anything constructive!
✈ Every strike of the hammer is a blow against the enemy. ✈
autothrust
Wed May 08, 2013 9:12 am
That's true for many planes, inclusive the A-10C Warthog. Really a rudimentary autopilot functions.
The sophisticated auto-pilot functions i posted, are there to reduce the pilot workload as much as possible.
For example when you enable Auto-Intercept the computer calculates the best heading and speed(also with EMCON and best kinetic energy) for the target, at the same time it selects the best suited weapon.
kc135topboom
Wed May 08, 2013 10:29 pm
Quoting sprout5199 (Reply 10):
Quoting KC135TopBoom (Reply 2):A cat T/O has several G forces and if the pilot was holding the stick, he would point the jet almost straight up as he inadvertently pulls the stick back due to Gs.
Dan in Jupiter
Thanks Dan, I didn't know the F/A-18 also had an auto-land. I would have thought the F-14 also has some for of T/O mode from a cat-shoot. I know the F-4 did not.
Users browsing this forum: Planeflyer and 1 guest
