ThePointblank
Lrasm Testing To Start This Year
Sat May 18, 2013 8:26 am
So what is LRASM (Long Range Anti-Ship Missile)? It's a new anti-ship missile, being built by Lockheed Martin in cooperation with the USN and DARPA designed to replace the current Harpoon missiles onboard surface ships and aircraft. Defense Industry Daily has a long article with timeline available for those who want to read it:
http://www.defenseindustrydaily.com/...hing-for-a-long-reach-punch-06752/
Originally, there were two missiles under the LRASM program, one being LRASM A and the second, LRASM B. LRASM A's development contract was awarded to Lockheed Martin, and the missile is a derivative of the LM's AGM-158 JASSM-ER missile. It is a subsonic, low-observable anti-ship missile, with considerably greater range (500nm vs 170nm of the current Harpoon missile), and will be capable of conducting autonomous targeting, relying on on-board targeting systems to independently acquire the target without the presence of prior, precision intelligence, or supporting services like GPS navigation and data-links, unlike the current Harpoon missile in service. In addition, as it is based off of JASSM-ER, it will share a similar warhead size, which means that LRASM will have over double the size of the current warhead compared to Harpoon.
A quick overview of LRASM A in video format is below:
http://www.youtube.com/watch?v=LvHlW1h_0XQ
Originally, LRASM A was supposed to be a air-launched missile only, however, Lockheed Martin is modifying the design for shipboard compatibility being fired from the Mk 41 VLS on company funds through the use of a booster separation system and development of a hybrid canister. The first MK 41 "push-through" testing occurred 3 days ago and the video is here:
http://www.youtube.com/watch?v=pP8pOtuo4Bo
LRASM B was envisioned as a ramjet-powered supersonic ship-launched missile. However, due to high technical risks, DARPA has focused on development of LRASM A instead.
DARPA is planning on testing LRASM early 2013 with 3 airborne test flights, with the first live-fire exercise this summer. In addition, two surface launches have also been budgeted and planned for by DARPA for 2014.
ThePointblank
RE: Lrasm Testing To Start This Year
Wed Jul 17, 2013 3:45 am
Captive carrying tests on a B-1B completed:
http://www.navyrecognition.com/index...us-air-force-and-navy-missile.html
The captive carry missions were flown aboard a U.S. Air Force B-1B from the 337th Test and Evaluation Squadron at Dyess Air Force Base, Texas. The primary mission objectives were to collect telemetry for post-flight analysis, verify proper control room telemetry displays and simulate all the test activities that will occur in later air-launched flight tests. All test objectives were met.
“Collecting telemetry data while flying in the B-1B bomb bay significantly reduces risk ahead of the first launch,” said Mike Fleming, LRASM air launch program manager at Lockheed Martin Missiles and Fire Control. “Initial assessments indicate the missile performed as expected.”
ThePointblank
Sun Sep 08, 2013 9:11 am
More DARPA research on LRASM, including a solo test flight, and hitting a target:
http://www.darpa.mil/NewsEvents/Releases/2013/09/06.aspx
Designed for both surface and air launch,LRASM seeks to develop an autonomous, precision-guided anti-ship standoff missile based on the successful Joint Air to Surface Standoff Missile Extended Range (JASSM-ER) system. LRASM aims to incorporate sensors and systems to create a stealthy and survivable subsonic cruise missile with reduced dependence on intelligence, surveillance and reconnaissance (ISR) platforms, network links and GPS navigation in electronic warfare environments. The program also focuses on precision lethality in the face of advanced countermeasures.
“This fully functional test is a significant step in providing the U.S. Navy and U.S. Air Force with a next-generation anti-ship missile capability,” said Artie Mabbett, DARPA program manager for LRASM. “This test is the culmination of the five-year development and integration of advanced sensors in an All-Up-Round (AUR) missile. It also represents the first time we’ve integrated advanced sensors and demonstrated the entire system, resulting in performance that substantially exceeds our current capabilities.”
DARPA designed the free-flight transition test (FFTT) demonstration to verify the missile’s flight characteristics and assess subsystem and sensor performance. Beyond the primary objectives of the free-flight transition, the test vehicle also detected, engaged and hit an unmanned 260-foot Mobile Ship Target (MST) with an inert warhead.
A B-1 bomber from the 337th Test and Evaluation Squadron conducted the mission from Dyess AFB, Tex., to the Point Mugu Sea Test Range off the coast of southern California. Once in position, the B-1 released the LRASM, which followed a pre-planned route towards the target. Approximately halfway to its destination, the weapon switched to autonomous guidance, in which it autonomously detected the moving MST and guided itself to hit the desired location on the target. A F/A-18 fighter from the Air Test and Evaluation Squadron (VX) 31 in China Lake, Calif., followed the weapon during the flight.
A picture of the target after the missile struck the target:
http://www.darpa.mil/uploadedImages/Content/NewsEvents/Releases/2013/LRASM.jpg
cjg225
Sun Sep 08, 2013 12:34 pm
"Target Ship - Stay Clear"
LOL
Ya think?
Interesting; I've never seen a target ship made out of containers.
Restoring Penn State's transportation heritage...
spink
Sun Sep 08, 2013 1:26 pm
Quoting cjg225 (Reply 3):
Seems pretty common. Most of the NSM tests were done with containers setup on the deck.
Its a pretty cost effective way of giving effectively a barge any given signature shape that you want. Both NSM and LRASM rely to some extent on image recognition for final targeting.
kc135topboom
Sun Sep 08, 2013 9:08 pm
Was the MST just drifting out there in the ocean, or was it steaming under remote control from a mother ship in the area? The picture seems to show a small wake behind the MST and the bow breaking water. Why is the freeboard of the MST so low?
Looking at the container the LRASM-A hit has a hole through both sides, indicating the missile went completely through the target.
ThePointblank
Sat Sep 21, 2013 7:26 am
First vertical launch out of a MK 41 VLS:
http://www.al.com/business/index.ssf...ockheed_martins_launches_firs.html
Lockheed Martin successfully launched the first Long Range Anti-Ship Missile, Boosted Test Vehicle from a MK 41 Vertical Launch System canister at White Sands Missile Range on Tuesday.
The test, funded by the company, included a successful launch of the LRASM BTV from the MK 41 VLS. The test vehicle, which includes a Vertical Launch Anti-Submarine Rocket Mk-114 rocket motor ignited successfully, penetrated and exited through the canister cover before performing a guided flight similar to that it would undergo in a tactical operation.
The vertical launch tests were, as mentioned in the article, funded by Lockheed Martin outside of their contract scope with DARPA.
rlwynn
Sat Sep 21, 2013 8:44 pm
Quoting KC135TopBoom (Reply 5):
MST 9301 target craft
Displacement: 850 tons full load
Dimensions: 260 x 26 x 7 feet/79.25 x 7.92 x 2.13 meters
Propulsion: 2 diesels, 2 shafts, 15 knots
Crew: unmanned
Notes: Purpose-built remote-controlled target ship, used for live-fire exercises.
Builders: Maritime Contractors, Bellingham, WA.
Number Name Year FLT Homeport Group Notes
MST 9301 (none) 1994 PAC Port Hueneme NAWC
I can drive faster than you
ThePointblank
Fri Nov 15, 2013 4:01 am
Another successful test of LRASM, this time against a moving target:
http://www.navyrecognition.com/index...tion=com_content&task=view&id=1359
Lockheed Martin’s Long Range Anti-Ship Missile (LRASM) recently achieved another successful flight test, with the missile scoring a direct hit on a moving maritime target. The test was conducted in support of the Defense Advanced Research Projects Agency (DARPA) and Office of Naval Research (ONR) program.
Flying over the Sea Range at Point Mugu, Calif., a U.S. Air Force B-1B bomber from the 337th Test and Evaluation Squadron at Dyess Air Force Base, Texas, released the LRASM, which navigated through all planned waypoints receiving in-flight targeting updates from the Weapon Data Link. After transitioning to autonomous guidance, LRASM identified the target using inputs from the onboard sensors. The missile then descended for final approach, verified and impacted the target.
“This test, combined with the success of the first flight test in August, further demonstrates the capabilities and maturity of LRASM,” said Mike Fleming, LRASM air launch program manager at Lockheed Martin Missiles and Fire Control. “The new sensors and legacy JASSM-ER components all performed well during the flight and the missile impacted the target as planned.”
ThePointblank
Tue Mar 25, 2014 2:05 am
DARPA has rejected Kongsberg and Raytheon's bids under LRASM, and has approved Lockheed Martin’s LRASM for a major follow-on development contract to prepare it for production in FY17. As a result, Kongsberg and Raytheon have filed a protest:
http://insidedefense.com/index.php?o...FjdC1hd2FyZC9tZW51LWlkLTYxLmh0bWw=
cjg225
Wed Mar 26, 2014 12:24 am
Quoting ThePointblank (Reply 9):
Interesting.
I am in an LL.M. class right now entitled "Fundamentals of Contracting with the Department of Defense." We just covered protests last week. Pretty timely. I'll forward this to my professor. Maybe we'll cover it.
ThePointblank
Fri Mar 28, 2014 10:58 am
Numbers being bandied about for this contract is 90-110 LRASM's, to be fitted on the B-1B (which has JASSM integrated) and F/A-18 Super Hornet. After that, there will be a competition, but only after 2019:
http://www.reuters.com/article/2014/...avy-missiles-idUSBREA2Q07620140327
Pretty much the only other alternative to LRASM for the second competition for the USN ship-borne anti-ship missiles is Raytheon with an upgraded version of the Tomahawk.
ThePointblank
Sun Aug 23, 2015 9:32 am
USN is beginning integration work with LRASM on the F/A-18 E/F's:
http://www.flightglobal.com/news/art...anti-ship-missile-on-super-415970/
The US Navy has begun integrating Lockheed Martin’s new Long-Range Anti-Ship Missile (LRASM) with its Boeing F/A-18E/F Super Hornet and airworthiness flights are due to start next month.
The service says its test and evaluation team at Naval Air Station Patuxent River in Maryland conducted the first load and fit checks with the weapon 12 August using a “mass simulator vehicle” – all in preparation for first phase of airworthiness certification.
LRASM has already been integrated with the US Air Force’s Boeing B-1B bomber, and now pictures released by the navy show the weight-representative payload attached to a Super Hornet’s pylon.
First flight is expected next month on the Super Hornets, with expected fielding date in 2019. The B-1B fleet will get LRASM earlier in 2018.
Users browsing this forum: LMP737 and 1 guest
