747classic
Re: KC-46 Production, Testing And Delivery
Mon May 01, 2017 2:13 pm
The first Fully Functional Production KC-46A, (second LRIP aircraft) made her first flight at April 29 2017.
See : http://painefield.blogspot.nl/2017/04/n ... s-air.html
Operating a twin over the ocean, you're always one engine failure from a total emergency.
KarelXWB
Thu May 04, 2017 9:09 am
A 6th test aircraft has joined the flight test program:
http://www.aviation.ca/2017050122124/ne ... st-program
Boeing [NYSE: BA] now has six aircraft in its KC-46 tanker test program, expanding its ability to complete ground and flight-test activities as it progresses
toward first deliveries to the U.S. Air Force.
The newest KC-46 aerial refueling aircraft, the second low-rate initial production plane, completed its first flight April 29. Its test activities will help ensure the KC-46 can safely operate through electromagnetic fields produced by radars, radio towers and other systems.
petera380
Thu May 04, 2017 11:53 am
Anyone know which aircraft joined the test fleet?
747classic
Thu May 04, 2017 2:59 pm
L/N 1092 C/N 41983 B767-2C KC-46A N884BA (VH006) UNITED STATES AIR FORCE (second LRIP aircraft) joined the test fleet, as stated here :
747classic wrote:
The first Fully Functional Production KC-46A, (second LRIP aircraft) made her first flight at April 29 2017. See : http://painefield.blogspot.nl/2017/04/n ... s-air.html
par13del
Fri May 05, 2017 1:54 pm
If those are WARPS they look way out at the extreme ends of the wings, is there a capability or requirement to refuel 3 a/c at once - 2 Navy 1 Air Force?
LMP737
Sat May 06, 2017 5:05 pm
Requirement, probably not. Capability, maybe. What it comes down to is a separation issue in that regard.
LMP737
Sat May 06, 2017 5:08 pm
bikerthai wrote:
The note about Boeing and the supplier not realizing how much documentation needed for the WARP could probably be blamed on lost of experience internal to Boeing (or the right mix of experience people did not get on to the tanker Commercial operation - this mix is important as you need both commercial (FAA) and military (WARP) experience working closely to cover all aspect of the cert), lack of experience from the WARP designer and manufacturer with respect to the FAA cert process. (They probably never had to go through this type of cert before as all their previous cert was through a military modification process that only requires a military cert).
That is my hypothesis.
bt
Boeing in it's infinite wisdom closed their Wichita operation which had lots of tanker experience. That knowledge base was instead spread to teh four winds.
Stitch
Sat May 06, 2017 5:44 pm
Yes, Boeing's original plan was to build them as green commercial airliners and send them to Wichita for conversion (as I believe was done with the KC-767 family), but (rightly, IMO) came to the conclusion that commercial 767-2C sales would probably be zero so by doing the military-related work on the FAL itself would cut down on conversion time and cost. The learning curve has been rough, but over time, it should be the better choice as doing it on the FAL will be easier than tearing the plane apart again to fit everything in.
kc135topboom
Sat May 06, 2017 10:44 pm
So is there 6 KC-46/B-767-2C aircraft now flying with the test flight program?
Does anyone know what the USAF tail number will be for the first KC-46A delivered to the Air Force will be, and when that will happen?
Sorry, I have not been keeping up lately. There is life outside of airliners.net
LMP737
Sun May 07, 2017 5:02 pm
Six airplanes total now in the test program. Not all are flying at the present moment though. As for deliveries your guess is as good as mine.
jarheadk5
Fri May 12, 2017 10:58 pm
Not gonna happen.
In the KC-10, simultaneous boom and WARP receivers are prohibited, due to inadequate receiver separation distance. Different airspeed requirements and emergency separation (breakaway) response times between boom AR and drogue AR are also a factor. Simultaneous centerline drogue and WARP receivers are also prohibited in the KC-10, also due to inadequate receiver separation distance.
-Boom stowed, leaving position.
KarelXWB
Sat May 13, 2017 12:31 pm
Boeing shares a peek inside the EMC:
https://twitter.com/jonostrower
747classic
Mon May 15, 2017 8:39 am
EMC lay-out explanation and details of shown aircraft at above pictures can be found here : http://painefield.blogspot.nl/2017/05/m ... c-46a.html
DanCatchpole
Wed May 17, 2017 11:10 pm
I asked when I toured the program earlier this month (along with Ostrower and others). The answer is maybe for foreign sales of the KC-46.
Three planes at once was not a USAF requirement, b/c there would not be enough wingtip clearance. However, I was told that if a foreign nation wants it, Boeing can provide that capability. I believe the KC-767s delivered to Italy can fuel three planes at once.
Here is the article I wrote: http://www.heraldnet.com/business/testi ... roduction/
- Dan Catchpole, Everett Herald
deputydoright
Mon May 22, 2017 3:56 am
Refueling 2 V-22 Osprey concurrently is a real game changer. I don't think there is large need to refuel 3 aircraft at the same time given the hazards involved.
deputydoright
Mon May 22, 2017 4:03 am
What would one say if suddenly, all of the previous testing were invalidated due to the test aircraft not being representative of the production model? Would this be newsworthy?
WIederling
Mon May 22, 2017 8:41 am
What kind of change do you have in mind?
Murphy is an optimist
7BOEING7
Mon May 22, 2017 3:07 pm
Are you talking about the FAA or Air Force testing? Are you talking about "all" of the testing or just a particular system?
As far as the FAA is concerned most of their testing (on any airplane) is accomplished prior to the airplane being "representative of a production model". When doing certification work their concern is that the specific system/area they are testing and that any related systems/areas are in final production configuration not the whole airplane.
Can't speak to the Air Force.
LMP737
Tue May 23, 2017 5:08 pm
I think there would be a clearance issue with two V-22 refueling from the WARPS.
AeroTyke
Thu May 25, 2017 9:28 pm
The tankers seem to be suffering from fuel temperature issues. I monitor the ground comms at BFI and tanker #1 has had issues for the past 3 days having to hold on the ramp and taxiways for up to 30 mins sometimes for the temp to drop to allow a take off. Today it escalated to the point where Fire Rescue was called to douse the wings with water in an attempt to bring the temperature down. Seemed to work, but by the time he'd taxied to the threshold for take off the temp had risen again. Sat there for 20 mins hoping it would drop but no luck so they've had to cancel the flight and return to the stall.
Anyone know why this is a problem on the tankers and seemingly not on other types? It's hardly blisteringly hot at Seattle today.
7BOEING7
Thu May 25, 2017 10:10 pm
Might be doing "hot fuel" testing, so they're starting with already heated fuel.
jarheadk5
Thu May 25, 2017 11:29 pm
Clearance for the V-22 to HAR from the KC-10 happened after I had left the jet, so I'm not 100% certain... but every picture or video I've seen of KC-10 - V-22 operations has been from the centerline drogue.
V-22 "wingspan" is ~84ft at the outboard tips of the proprotors. For the sake of easy math, we'll call the distance from the AR probe to the proprotor tips 40ft.
KC-46 wingspan is ~158ft. The WARPs are inboard of the wingtips; my brief search for a measurement was unsuccessful. Again, for easy math, we'll call the distance between WARPs 140ft.
Using these simplified (and, admittedly, borderline fictional) numbers, simultaneous V-22s on the KC-46 WARPs gives 60ft lateral separation. I no longer remember what formula USAF uses to determine "safe" receiver separation distance during WARP/MPRS refueling, but I doubt it results in a distance less than one receiver "wingspan" being considered acceptable receiver separation.
747classic
Sat May 27, 2017 10:57 am
More KC-46A pictures are emerging on Flickr by Jon Ostrower.
Everett Modification Center, May12 2017.
Original uploaded by Jon Ostrower, see : http://www.flickr.com/photos/flightblog ... 951497021/
For more pictures, see : http://www.flickr.com/photos/flightblog ... 1951497021
CFMitch56
Sun May 28, 2017 1:56 pm
Correct... the V-22 is only approved to refuel from the centerline drogue on the KC-10. Not sure if it's a spacing/clearance issue or just the CLD is more stable than the WARPs.
par13del
Sun May 28, 2017 2:49 pm
I read somewhere that the big issue with doing probe / drogue on the KC10 was that once the a/c was fitted that was the only thing it could do as the boom was rendered inop, so in effect a speciality mission just for the Navy or Marines...based on military spending criteria, would it have been better to get the KC10 fitted with WARPS or was that not possible?
ZaphodHarkonnen
Sun May 28, 2017 8:06 pm
Pretty sure that's the KC-135. Which requires a boom to drogue adapter to be fitted on the ground. The KC-10 has the boom, and a reel forward of the boom hinge. So it can do both in the same flight.
EDIT:
Yep.
Ozair
Sun May 28, 2017 10:50 pm
EDIT:
Yep.
Aircrew call the KC-135 probe attachment the "iron maiden" and hate refuelling from it compared to a standard WARP arrangement as there are a couple of quirks to the refuelling process that make it difficult and more dangerous.
KarelXWB
Mon May 29, 2017 8:39 am
Short video of the KC-46A undergoing electromagnetic testing in the anechoic chamber at Edwards AFB:
https://twitter.com/BoeingDefense/statu ... 7946658818
mjoelnir
Fri Jun 09, 2017 2:37 pm
https://www.flightglobal.com/news/artic ... ng-438072/
USAF expects delayed KC-46A delivery next spring
are these new delays?
Stitch
Fri Jun 09, 2017 3:16 pm
mjoelnir wrote:
https://www.flightglobal.com/news/articles/usaf-expects-delayed-kc-46a-delivery-next-spring-438072/
Yes.
KarelXWB
Sat Jun 10, 2017 1:35 pm
The previous delay pushed initial delivery to February 2018, so Q2 2018 is definitely another delay.
KarelXWB
Sun Jun 18, 2017 11:05 am
LN 1116 in storage at PAE:
16-46016 USAF Boeing KC-46A Pegasus (767-2LKC) - C/N 41860 / LN 1116 by Woodys Aeroimages, on Flickr
Current aircraft in storage at runway 11/29:
16-46014 USAF Boeing KC-46A Pegasus (767-2LKC) - C/N 34105 / LN 1113
16-46015 USAF Boeing KC-46A Pegasus (767-2LKC) - C/N 34134 / LN 1114
16-46008 USAF Boeing KC-46A Pegasus (767-2LKC) VH008 - C/N 41856 / LN 1100
16-46007 USAF Boeing KC-46A Pegasus (767-2LK) (VH007) - C/N 41855 / LN 1098
16-46012 USAF Boeing KC-46A Pegasus (767-2LKC) - C/N 34107 / LN 1109
16-46013 USAF Boeing KC-46A Pegasus (767-2LKC) - C/N 34109 / LN 1111
KC-46A's Stored on RWY11/29 by Woodys Aeroimages, on Flickr
LMP737
Mon Jun 19, 2017 8:14 pm
Looks like the line up of teenager 787's they used to have parked out on that runway.
jarheadk5
Fri Jul 14, 2017 11:58 pm
Sorry for the late response...
As already noted, the KC-135 with the Boom Drogue Adaptor installed becomes a drogue-only tanker until the BDA is removed by the ground crew after landing. The KC-10 has a centerline drogue installed on every aircraft; nearly every mission I flew during my deployments to the sandbox had both boom and drogue receivers.
IIRC, about 1/3 of the KC-10 fleet is modified for WARPs; there are more WARP-capable -10s then there are sets of pods to install on them. The WARPs, unfortunately, are notoriously unreliable, and the customer who pushed the USAF into buying the mod (the US Navy) almost never uses them. The installed pods inflict a not-insignificant drag penalty in all phases of flight, and also inflict some significant takeoff restrictions WRT weather, winds, and runway length. In the 10 years I was a KC-10 boom operator, I only had one mission where the WARPs were a requirement - a movement of a Marine Harrier squadron from Cherry Point to Iwakuni, then another squadron from Iwakuni to Yuma. We had a pod fail on one of our overnight stops at Wake Island that couldn't be fixed. The other -10 on the mission had a pod fail on the very first leg of the mission. We had to get waivers from both the Air Force and the Marine Corps to continue the mission with the centerline drogues only.
Stitch
Tue Jul 18, 2017 8:16 pm
Was down at the Museum of Flight this morning and caught a KC-46A going up for a flight. There were also four more birds at the Flight Test Center (along with the 787-10 and what I assume is the 737-9).
LMP737
Fri Jul 28, 2017 4:54 pm
They're stacking up like cord wood. ;)
KarelXWB
Mon Jul 31, 2017 12:18 pm
A refueling boom has been installed on one of the customer aircraft.
https://twitter.com/dominicgates/status ... 8737160193
Slug71
Mon Jul 31, 2017 3:12 pm
By the time this bird is certified and ready for delivery, a whole squadron should be ready to go. Maybe 2.
LMP737
Mon Jul 31, 2017 4:59 pm
Probably not. They'll still have planes sitting on the runway waiting to be finished when that happens.
747classic
Fri Aug 11, 2017 10:24 am
The first KC-46A of the third LRIP batch of 15 aircraft is spotted at the Everett Flight line.
L/N 1129, KPAE, August 9th.
Original uploaded by Chris Edwards, see : http://www.flickr.com/photos/woodysaero ... 305470862/
Aircraft data : L/N 1129 C/N 34121 B767-2LKC 17-46024 USAF KC-46A (VH024) LRIP 3, #1/15
Slug71
Fri Aug 11, 2017 3:08 pm
How many frames have been built now?
747classic
Fri Aug 11, 2017 3:55 pm
04x Engineering & Manufacturing Development (EMD) aircraft, all 4 have been used for testing
07x Batch 1 LRIP (Low Rate Initial Production) aircraft,first two have been used for testing
12x Batch 2 LRIP aircraft
01x Batch 3 LRIP aircraft
Total Assembled : 24,
Slug71
Fri Aug 11, 2017 4:18 pm
Damn! Will the first 6 aircraft which have been used for testing go to the USAF once testing and certification is complete?
747classic
Fri Aug 11, 2017 4:46 pm
AFAIK all 6 test aircraft will be refurbished and will be delivered to the USAF.
The first four test aircraft (VH001-VH004) are "real" test wired aircraft and need far more modifications, before delivery to the USAF
VH005 and VH006 are later added to the test program to speed up the test flying to cater for further delays and are LRIP aircraft, locally adapted for specific testing.
Slug71
Fri Aug 11, 2017 5:11 pm
Thanks.
Not sure how many aircraft each base has, but if 12 aircraft make up a squadron, at least 3 squadrons should have a fairly quick transition.
KarelXWB
Tue Aug 29, 2017 6:43 pm
KC-46 may face further delays:
A trick that mutes a blaring horn when the autopilots on all Boeing models—except the 787—are manually disconnected could potentially cause an entry-into-service delay for the company’s KC-46 Pegasus tanker, a derivative of the 767-2C freighter.
http://aviationweek.com/defense/autopil ... uble-kc-46
Stitch
Tue Aug 29, 2017 8:17 pm
Considering the 767-2C is only going to be operated by a single customer (the USAF in the KC-46A configuration) during the exemption period, I would expect the FAA to grant this waiver as it should be easy enough to add this into the training regimen for the smallish pool of USAF pilots who will be flying the plane until the software roll-out is ready.
7BOEING7
Tue Aug 29, 2017 10:37 pm
I don't think this will cause any delays, should be able to fix that rather quickly. Don't know were Boeing came up with their 99%, I did it for years along with most of the people I flew with IIRC..
Stitch
Tue Aug 29, 2017 10:48 pm
That's the key - if you know how to do it, there is a 100% success rate. If you do not know how to do it, then there is a 1% chance (per Boeing's studies) that you will be successful and this is Boeing's argument - the chances for an Air Force pilot not knowing the procedure accidentally triggering it is so low they should be granted the exception. And I imagine if you train them on the procedure so they don't do it, the chance should be 0%.
