Max Q
The Kawasaki P1
Thu Jun 06, 2013 5:29 am
So the Japanese develop, by themselves what appears to be a superb replacement for the P3 and a rather unique Aircraft.
A four engine design with a maximum take off weight similar to a B727.
Good for them, but why the total lack of interest in this design from other countries ?
ThePointblank
RE: The Kawasaki P1
Thu Jun 06, 2013 8:36 am
Quoting Max Q (Thread starter):
The Japanese don't export their military hardware.
bigjku
RE: The Kawasaki P1
Thu Jun 06, 2013 1:35 pm
Very few nations are really buying Maritime Patrol Aircraft right now, particularly new ones. Those that are are doing so on the cheap either with P-3 reconditions or they are buying modular kits to stick in transport aircraft and then pretending those are MPA's.
For those that are buying new MPA's the P-8 is simply a better bet. It is a bit cheaper ($200 million vs $270 million in flyaway cost). The airframe has thousands of examples worldwide and a huge spares base to draw from. Performance wise they give you almost exactly the same thing but the 737 based airframe is probably seen as lower risk. Early P-1's have already had some cracking. It is probably nothing but if you are looking to drop a lot of money you are comparing a new airframe with no track record that uses unique engines to one of the most flown airframe and engine combinations in world history. One is more predictable than the other.
There is the additional benefit for nations like Australia that the P-8 shares a fair deal in common with their other militarized 737's. It just makes things simpler and I think that will be its other big selling point (the first being the thousands of 737's already out there). The 737 is likely to be the follow on platform for lots of 707 based electronic warfare platforms in the US so if you want an ELINT aircraft of an AWACS aircraft it makes sense to combine that with the P-8 provided you also want an MPA.
Ozair
RE: The Kawasaki P1
Thu Jun 06, 2013 2:07 pm
Quoting ThePointblank (Reply 1):
I am not sure if don't or can't is the right word? The Japanese constitution apparently denies them the ability to export military weapons or systems.
The test case is the new Japanese float-plane, the SU-2. The Japanese and the Indians have apparently reached agreement on its purchase, http://www.hindustantimes.com/ViewsS...-s-blessings/Article1-1068447.aspx
L-188
RE: The Kawasaki P1
Thu Jun 06, 2013 5:10 pm
I would say cant is the right word.
The only time I have heard of a forgiven air force flying Japanese equipment that wasn't WWII captures is the two YS-11's the Turkish Airforce uses as Navaid check aircraft.
But I don't think they where bought new from NAMC.
GDB
RE: The Kawasaki P1
Thu Jun 06, 2013 5:31 pm
Not only are they seriously restricted in exporting military products, the Japanese Defence Forces rather like the specialised, built for them and no one else products that often follow from it.
Of course there is a high financial cost to this, which they seem to accept.
It's rather a back to the future thing, these highly specialised, often uniquely configured aircraft.
The other aspect to paying this cost is that it preserves the Japanese design and industrial base, beyond just licence building foreign types. They do a lot of that too of course but again, they seem to think it worthwhile.
britjap
RE: The Kawasaki P1
Thu Jun 06, 2013 9:49 pm
Quoting Ozair (Reply 3):
Quoting L-188 (Reply 4):
Not quite.
"Don't" is indeed the right word. The constitution does not prohibit arms exports. It does not make any explicit judgement on the issue. Technically, I believe it is not even illegal to export arms as there is no law to prevent this. It is however Japanese government policy not to allow arms exports, and so it is in all practicality, *illegal*. The government (ie. METI) would come down hard on any company that flouts this policy.
Quoting GDB (Reply 5):
Another key point is that in years gone by it was often not even possible to purchase equipment from overseas as sending specifications/requirements to foreign suppliers in the form of RFQs etc would be classified as an arms export. So whenever a suitable product was not commercially available off the shelf, that meant designing and developing a domestic solution.
   This is the primary driver for such programmes.
The test case is the new Japanese float-plane, the SU-2. The Japanese and the Indians have apparently reached agreement on its purchase, http://www.hindustantimes.com/ViewsS....aspx
Things are slowly changing. The US-2 deal with India has been in the works for some years now. It is nice to see some movement on this. I for one hope that this deal eventually gets done.
dlednicer
Editor
RE: The Kawasaki P1
Fri Jun 07, 2013 1:02 am
Also, the Republic of China (Taiwan) Air Force was supplied with some Mitsubishi-built Lockheed F-104J Starfighters:
Photo © S.L. Tsai
Photo © S.L. Tsai
Max Q
RE: The Kawasaki P1
Fri Jun 07, 2013 2:42 am
Good info but it is a fascinating Aircraft.
I wonder if, like the Nimrod and P3 it is designed to shut down two engines during long patrols for greater endurance.
Incidentally what kind of engines are they ?
ThePointblank
RE: The Kawasaki P1
Fri Jun 07, 2013 6:43 am
Quoting Max Q (Reply 8):
A Japanese designed engine, the IHI F7. IHI has a lot of experience license building and building parts for jet engines and gas turbines, and they have worked with Rolls Royce and GE on a variety of engines. I believe this is their first indigenous engine, though they had a lot of help from GE on various components.
moo
RE: The Kawasaki P1
Fri Jun 07, 2013 11:25 am
Is the P-1 a fully new aircraft design or is it based on another airframe? Wikipedia doesn't say, but surely the costs would be prohibitive for Japan to design a completely new airframe for this job?
ThePointblank
RE: The Kawasaki P1
Fri Jun 07, 2013 11:34 am
Quoting moo (Reply 10):
All new design, but shares some development resources with the Kawasaki C-2.
Ozair
RE: The Kawasaki P1
Fri Jun 07, 2013 11:44 am
Quoting britjap (Reply 6):
Not quite.
Thanks for the info.
Japan and prohibitive costs go very well together. They paid twice the value of an F-16 to domestically produce the F-2.
bikerthai
RE: The Kawasaki P1
Fri Jun 07, 2013 1:01 pm
Quoting ThePointblank (Reply 11):
One thing about new design is that you have a better shot at configuring the internal layout the way you wanted. With a pre-existing airframe, you have less flexibility.
Any photos of the interior configuration?
bt
moo
RE: The Kawasaki P1
Fri Jun 07, 2013 1:41 pm
Quoting bikerthai (Reply 13):
Yes,that might be true, but surely it can't be worth it if you are only looking at a few dozen airframes?
bigjku
RE: The Kawasaki P1
Fri Jun 07, 2013 1:59 pm
This is a fairly simple and complicated question all at once. The technical answer is going to be yes. Even a 2 engine aircraft can fly around on one engine. The question is if that can really increase endurance and that depends a lot on flight profile. Big turbofan engines don't do it as well as the old prop-engines did.
I think that what you will see, since the P-1 and P-8 will share a lot of warfare systems, is that they will generally operate at high altitude almost exclusively where they can most efficiently cruise and reduce airframe stress. This gives the best coverage perspective for their radars (important if you are hunting SSK's that occasionally have to snort) and with the planned modifications to torpedoes and buoys to operate efficiently from cruise altitudes should let them cover more area in a given amount of time.
About the only thing you lose at altitude is your MAD capability and I honestly am not sure MAD has a ton of utility going forward for a few reasons. First there are a lot of measures one can take to minimize a magnetic signature and these seem to be moving towards systems installed on each submarine. At depth MAD is generally not going to work even without these measures. Second there is renewed talk of SAM's being able to be fired from subs.
http://www.diehl.com/fileadmin/diehl...user_upload/flyer/IDAS_07_2008.pdf
I don't really have a ton of faith in those systems being all that practical but I do know that flying low will bring them into play.
At cruise altitude I think that you would probably see a lot less benefit from operating with engines shut down than you do at lower altitude. I think the P-1 can certainly do it, but I don't think it will be really common.
Kiwirob
RE: The Kawasaki P1
Fri Jun 07, 2013 6:11 pm
That's a myth. The ban was instigated in 1967 and tightened up in 1976, but was not constitutional, it was self imposed, in 2011 the Japanese dropped the ban.
Here's a nice article about it. Top
Kiwirob
RE: The Kawasaki P1
Fri Jun 07, 2013 6:12 pm
Ok something went wrong in my post above, here's the article.
Top
Newark727
RE: The Kawasaki P1
Fri Jun 07, 2013 7:03 pm
Hearing that the engines are indigenous to Japan leads me to believe that this is a really key factor. Although doesn't the XC-2 use CF-6s?
Max Q
RE: The Kawasaki P1
Mon Jun 10, 2013 3:57 am
Quoting BigJKU (Reply 15):
I understand the theory, was trying to find out if anyone really knew !
GDB
RE: The Kawasaki P1
Tue Jun 11, 2013 7:05 pm
Quoting Newark727 (Reply 18):
Japan has been involved in various engine programs, in the mid sized civil turbofan range, going right back to work with Rolls Royce 30 years ago. Leading to some work on production engines in collaborative programs.
It might be that the P1's engines are a means at using that experience on an indigenous engine.
Yes, the C.2 has CF-6's.
RussianJet
RE: The Kawasaki P1
Tue Jun 11, 2013 7:20 pm
One thing's for sure - that's one cool-looking aircraft. Four engines on a small airframe is always going to look tremendous.
✈ Every strike of the hammer is a blow against the enemy. ✈
Aaron747
RE: The Kawasaki P1
Thu Jun 13, 2013 2:30 pm
Agreed. It was developed at Kawasaki Heavy's aerospace R&D works at the Gifu Air Base, about an hour north of here (Nagoya). You should try to come out here in late November when that base has their annual JASDF Air Show and Open House - typically the entire Kawasaki flight line is opened to the public with the requisite aerial performances.
http://www.milavia.net/airshows/calendar/showdates-2013-world-JP.html
Quoting ThePointblank (Reply 9):
To my knowledge, this is the first domestically produced turbofan of this size and design in Japan.
Aaron747
RE: The Kawasaki P1
Thu Jun 13, 2013 2:37 pm
Incidentally, by searching in Japanese I was also able to find these:
This is the common cockpit design for both the P-1 and C-2:
And this page has several photos of the prototype P-1 delivery ceremony:
http://www1a.biglobe.ne.jp/mediaeye/index/13-0326_news.html
bikerthai
RE: The Kawasaki P1
Thu Jun 13, 2013 2:59 pm
Quoting aaron747 (Reply 23):
Couple of observation.
Looks like the cockpit crew has larger windows than the P-8 (one benefit of building from scratch).
There are more observation windows on the P1, but the P-8 has the largest observation window.
The sonobuoy launchers are the cluster type where as the P-8 have the rotary launcher.
bt
Aaron747
RE: The Kawasaki P1
Fri Jun 21, 2013 10:05 am
News story out of this week about JMSDF grounding of the P-1 over the last month as investigations continue into reliability issues with the IHI engines.
http://newsonjapan.com/html/newsdesk/article/103221.php
bigjku
RE: The Kawasaki P1
Fri Jun 21, 2013 1:19 pm
Quoting Aaron747 (Reply 25):
This was/is the big risk with the program. The main thing you want from a MPA in my view is dispatch reliability and reasonable operating cost. Hope they sort the engines out because it will be a good platform but that is why I have been onboard with the 737 MPA solution for the US for a while now. Whatever minor operational drawbacks a 2 jet engine MPA has it seems like a small trade for having very high rates of dispatch and an large and affordable spare pool to draw from.
bikerthai
RE: The Kawasaki P1
Fri Jun 21, 2013 4:32 pm
Quoting BigjKU (Reply 26):
The P-8 may have it's own dispatch reliability issues. But it will not come from the engines. Those 737 CFM's have proven themselves through all the years of commercial service.
Also, Boeing is trying to pitch the P-8 to Japan in case the P-1 program falters.
bt
[Edited 2013-06-21 09:35:09]
bigjku
RE: The Kawasaki P1
Fri Jun 21, 2013 5:17 pm
Quoting bikerthai (Reply 27):
Yeah, that is kind of what I am getting at. A lot of spares will be on hand just about anywhere in the world. Not for the mission systems but basic stuff for the airframe to get by with should be easy to scrounge up. If you for example wanted to deploy a squadron to some airport in East Africa it is likely that that place operates some 737's. Mission systems are going to fail from time to time but if I have an airframe that is flyable better than 90% of the time as an airplane I am going to be pretty happy.
Kiwirob
RE: The Kawasaki P1
Wed Dec 17, 2014 11:43 am
Any further updates to this aircraft.
tommy1808
RE: The Kawasaki P1
Wed Dec 17, 2014 1:42 pm
Quoting Ozair (Reply 12):
They also got to do more of the work in Japan and got an Aircraft better suited to its mission, so while it may have been expensive, bang for the buck wise it probably wasn´t that bad. Compared to a 2014 all bells and whistles F16 the F2 may not be that impressive, but in the year 2000 it was a pretty advanced fighter. Its not like they just license produced some expensive F16...
best regards
Thomas
Times are changing: 70 years ago the USA went to war to defeat the Nazis, now they elect them to run their country.
Kiwirob
RE: The Kawasaki P1
Wed Dec 17, 2014 2:36 pm
Since the C2 and P1 share a common cockpit does that also mean the pilots of both aircraft will be type rated for both aircraft?
Aaron747
RE: The Kawasaki P1
Thu Dec 18, 2014 2:47 pm
Sorry, I have no idea how the JASDF runs its type assignments or certification.
bikerthai
RE: The Kawasaki P1
Thu Dec 18, 2014 2:59 pm
Quoting BigjKU (Reply 28):
Word back from the first P-8 deployment was that the dispatch reliability was superb.
As for the P-1, there seems not to be much rumors on Japan buying the P-8, so it seems that they will continue on with their P-1 deployment for now.
bt
Users browsing this forum: zaphod42 and 11 guests
