tsra
KC-135 Required Runway Length
Wed Jun 26, 2013 1:42 pm
I was wondering if anyone knows what the takeoff/landing requirements for the KC-135 are on a typical training or air show (if that ever happens again) sortie. I think I may of heard 7,000 feet and a shorter amount if permission was granted but was not sure. Do we know the performance difference between a KC-135 and KC-46 yet?
rc135x
RE: KC-135 Required Runway Length
Wed Jun 26, 2013 1:51 pm
7000 feet x 147 feet.
See Section 5, page 48.
http://www.vusaf.org/amwtc/97amw/55%...light%20Guide-%2021%20Aug%2004.pdf
Obviously there are possible variations under special conditions (Cherokee Rose, for example), but these are the operational limits.
KC-135A, A(RT), D, E, E(RT), Q, R, EC-135A, C, G, L, RC-135S, U, V, W, X, TC-135S, W
bigbird
Wed Jun 26, 2013 8:13 pm
I realize that this was a long time ago but when I was stationed at Robins AFB back in the mid-1960s our KC-135A s would use between 11000 and 12000 on T/O. It was closer to the latter on hot days. Sometimes they would return after their missions and still have some pine needles in the intakes from the tops of trees at the end of the runway. Of course these were fully loaded airplanes. If anyone here ever witnessed a fully loaded "water wagon" they were truly something to behold.
bigbird from georgia
KC135Hydraulics
Thu Jun 27, 2013 1:50 am
Quoting bigbird (Reply 2):
The R-models have decidedly better takeoff performance as you may expect.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
Moose135
Thu Jun 27, 2013 2:26 pm
Took off out of Pease, dragging some F-4s to Europe. 285K gross weight, with water, we used better than 10,000 feet of runway to get airborne. Never got to fly an R-model, but from what I've seen, they are much better performers. Of course, kids flying them these days will never experience the sound and fury of a wet takeoff...
We were Gods - we made water burn!
bigbird
Thu Jun 27, 2013 8:42 pm
You had to keep water warm also. When the temperature dropped below a certain point we had to run the MD-3 power units to keep the water on the "alert birds". Also in real cold climates, i.e. Goose Bay, where I was stationed I believe the water was drained. Is this correct? I am not sure as it was a long time ago. I was stationed there in 1965-66.
rc135x
Thu Jun 27, 2013 9:44 pm
Quoting bigbird (Reply 5):
You are indeed correct. As it has been an equally long time, I don't recall the temperature when heat was applied or when the water was drained.
Alert was always hard on the airplanes: heating water, tire rotation, maintenance necessitated by weekly "horns." It was just as hard on the crew chiefs who huddled in alert trucks in the freezing weather.
Moose135
Thu Jun 27, 2013 10:34 pm
Quoting rc135x (Reply 6):
Outside air temp below 40F required heaters, OAT below 20F and we dumped the water. Amazing the stuff that you find rattling around your head...
Ain't that the truth! Always felt for those guys.
bigbird
Fri Jun 28, 2013 8:02 pm
I was one of the APs that was out there along with them. I can really relate.
rc135x
Fri Jun 28, 2013 10:17 pm
Quoting moose135 (Reply 7):
Thanks Moose.
Remember when they would dump the water and it would pool under the airplane and freeze the tires to the ramp? Then it would warm up in the daytime to 30 or so and they would have to reload water, then dump it again. You could play hockey on that ice.
taxpilot
Sat Jun 29, 2013 4:43 pm
Quoting moose135 (Reply 4):
Mine was on a cool fall morning. Routine, but thumping the departure end arresting cable on rotation does get your attention! Our calculated level off was 800' AGL (normal1000'). I accelerated out to climb speed at 500'.
Good memories.
kc135topboom
Sat Jun 29, 2013 11:53 pm
I remember we pulled alert at Goose Bay when I was at Plattsburgh, Pease and Grissom also pulled alert there.
Yeap, been there, done that.
Quoting rc135x (Reply 9):
Actually, you didn't have to reload water after dumping it the night before because temps dropped below 20. The old J-57s were stronger engines than most realized. At EWO weights, usually a KC-135A/Q alert bird could get off the available runway with dry thrust at temps as high as about 38. T/O data was normally computed with a maximum allowable loss of thrust (such as loosing water on one engine), or minimum allowable thrust (dry thrust in cooler weather). IIRC, wet T/O EPR was about 2.85, and maximum dry EPR, in the mid 30 degrees would be up towards 2.65 to 2.70 EPR. I could be a little off on my numbers, it has been 22 years ago. But using reduced thrust take-offs since the 1970s really helped engine reliability.
Revelation
Sat Jun 29, 2013 11:59 pm
Quoting taxpilot (Reply 10):
Good memories.
Maybe for you, not so much for whomever cleaned your underwear!
Thanks to all you cold warriors (see what I did there?) out there!
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
e38
Sun Jun 30, 2013 6:53 pm
quoting moose135 (Reply 4), "Never got to fly an R-model, but from what I've seen, they are much better performers."
John, much better performers? Absolutely 100 percent, and that's quite an understatement! In comparing the KC-135A to the KC-135R, in terms of control, performance, and overall capability, flying the R model was like flying a completely different airplane. In terms of "engine-out" situations, performance was no longer the issue, control was. You would have loved it.
One of the best decisions the Air Force/SAC every made. Nevertheless, glad you had the opportunity to fly a piece of American aviation history (KC-135A) and thank you for your service to our nation.
Thank you also for your service KC135TopBoom and taxpilot.
e38
[Edited 2013-06-30 11:56:01]
windy95
Fri Jul 05, 2013 5:11 pm
Quoting KC135TopBoom (Reply 11):
Dry Thrust when trimming the engine was 1.60 with wet being 1.81.
Moose135
Fri Jul 05, 2013 6:02 pm
Quoting windy95 (Reply 14):
Wet EPR on take off was 2.83. Dry was usually 2.20+ more on colder days, but I'd have to dig out my Dash-1 to look it up...
windy95
Sat Jul 06, 2013 4:57 pm
Yes it is 2.83. Do not know why I put a 1. For the engine trims we put in the dry value and when we engaged the water it needed to come out to the 2.83. Being the fuel control guy and lying underneath the engine during the trim was not fun. Usually called for a 12 pack afterwards back at the dorm.
kc135topboom
Sun Jul 07, 2013 1:30 pm
For wet thrust on the J-57 equipped KC-135 was to set 2.83 EPR initially, then reset to 2.35 once you accelerated though 30 KIAS on the runway. It was similar on dry thrust T/Os, set the EPRs at an initial EPR reading, then reset to a slightly higher value once past 30 KIAS.
rc135x
Mon Jul 08, 2013 1:06 pm
Just to clarify I believe the procedure was to set dry takeoff EPR, start the water, and then set 2.83 EPR (TRT-takeoff rated thrust). This setting remained in use until water runout during the acceleration phase of the initial climb out, at which point climb EPR (normal rated thrust) was set.
For heavy weight water takeoffs, especially those associated with an HHD (higher-headquarters directed, meaning "get it done") mission, we started the water while stopped and didn't start rolling until water had kicked in on all four engines. Sometimes it didn't, and because the actuators were in the throttle quadrant to detect throttle position, you could bang on the quadrant with your fist and sometimes get the water to start if it was lagging on one engine.
Some pilots never did rolling water-injected takeoffs because (1) if water was needed then they wanted to make sure it was working or (2) if they needed to dump the water for some reason it should be done while stationary given the several minute dump time, decreasing the aircraft weight by 5500 or so pounds, IIRC.
Incidentally, the switch to start the water was in front of the co-pilot's left knee. Pushing the switch UP started the water, pushing it DOWN dumped the water. That was a mistake NO copilot ever wanted to make, but it did happen on occasion. Once started, dumping water could not be stopped.
windy95
Mon Jul 08, 2013 2:31 pm
Quoting rc135x (Reply 18):
Correct and this was the same method used when trimming the engine. Set the dry EPR and then turn on the pumps and if it wsa timmed right it would come out to 2.83. We would have to keep adjusting until we could meet that target.
135mech
Thu Jul 11, 2013 5:23 pm
Hey guys, sorry haven't chatted in a while - have missed your knowledge!
WOW, distant memories! As a crew chief, but never actually got to perform "alert" sadly, watching the MITO's on the B-52G's and KC-135A's at Fairchild at the time was "awe"some. Running ground man on water runs was always more "bone-rattling" then the R-models, but both planes always amazed me! For those of you that never got the pleasure of experiencing the hoovers, their spin-up is just inspiring!
Over the years I was priviledged to work all of the engine models due to my first 2 years in England [J-57's, TF-33's - 4 different versions, and the blessed F108/CFM-56-2B].
I was always amazed at the "courage" of the first two jets to go! I remember the LAST EVER KC-135Q take off out of Rhiyad, in 140+F and he took EVERY BIT of that shorter narrow runway next to us and that black smoke lasted forever!
We literally doubled the power with the upgrade, went from 11K thrust to 22K thrust per engine. Each engine is rated individually and a lot of them are around 21,800 but the CFM-562B is a 22K class engine.
[Edited for spelling]
135Mech
[Edited 2013-07-11 10:26:30]
135Mech
