ryu2
Who Does Flight Planning In The Military?
Wed Jul 03, 2013 8:28 pm
Is there a equivalent of a dispatcher that plans the routes, files flight plans, etc like the airlines do? Or do the pilots have to do it themselves?
Woodreau
RE: Who Does Flight Planning In The Military?
Fri Jul 05, 2013 1:10 pm
No there is no one single person who does flight planning, filing the flight plan, and flight following in a sense of an airline aircraft dispatcher. In the military the functions are separated and while they could be all done by the same person, it's not.
So it "depends."
rfields5421
Fri Jul 05, 2013 1:55 pm
My experience is Navy, and it has been 20+ years since I was on active duty. Plus some experience with a friend who went through USAF pilot training from start to C-17 about 2000-2002.
Aircraft squadrons has an Operations Department (USAF Wings might have an Operations Squadron for the function). That department plans missions to meet tasking requirements, training requirements, etc. There are a set of enlisted men who keep track of flight hours of pilots, crew members and aircraft. Who needs to do what kind of flight to maintain qualifications, etc.
They also turn mission requirements into routes for the aircraft and air crew, and do many of the functions of the dispatcher. However, in a long mission, especially overseas - the navigator for the crew, and likely the pilots, will be involved in the mission planning. The route, the fuel stops, the RON stops, etc.
The loadmaster, flight engineer or aircraft captain (the enlisted man responsible for 'his' airplane - no matter who flies the bird) will be involved in detail in the load, weight and balance, etc.
When the aircraft deparrts on a mission such as KNZY-PHNG-PGUA-RJTA-PGUA-PHNG-KNZY - http://www.gcmap.com/mapui?P=KNZY-PH...GUA-PHNG-KNZY&DU=nm&SU=kts&RS=best
The route basics have been completed. One key factor in flight planning is making sure arrangements for the crew RON stops, meals, etc. Depending upon the aircraft size and squadron policy - many of these tasks will be delegated to certain members of the crew.
Prior to flying each leg, the pilots, navigator, radio operator if there is one, and flight engineer will meet at base operations and receive various briefs from weather, the ATC manager, etc. To each get his/her specific information.
The loadmaster will verify fuel and payload information. Nothing goes on or off the aircraft without his/her approval.
However, the training starts early. In Navy pilot training in 1977 when I was involved in it a bit, and in USAF pilot training in 2000 - the trainee pilot plans every detail under the supervision of his instructor. The trainee pilot has to learn how to brief the entire route. How many approaches of which type will be flown on each leg, waypoints, ATC frequencies, alternates, weather, etc.
In that respect - it is not a lot different than a student working on his PPL has to do with his instructor for his training cross country flights. Just much more intense and many more flights than a civilian student.
I am sure there are people in big transport, and probably bomber, squadrons who function much as an airline dispatcher. I would be shocked if the 89th Airlift Wing doesn't have full-time dispatchers who plan every segment of every PAG flight working alongside the Secret Service.
But the need for flexibility due to changing mission requirements demands that regular military aircraft crews be able to complete all those functions and planning.
kingairta
Sun Jul 07, 2013 4:26 pm
In my time in VR flying as a loadmaster in both C130s and C12s the pilots for the mission did all the flight planning. All the operatioms guys did was to acquire dip clearances, PPRs, lodging etc. They also kept track of individual flight times. The NATOPS depth would notify operations who needed what training and or check rides. As for the fuel the pilots would determine how much fuel was needed for each leg and would let the crew know. It was up to me to make it work. Not only did I have to worry about take off weight but if we had an extremely heavy load we had to ensure we landed with enough fuel weight in the wings for structural reasons.
TWA772LR
Tue Jul 09, 2013 5:13 am
Slightly OT, but I heard that military pilots use different maps, charts, and other flight planning techniques versus their commercial counter-parts. Which leads to a relatively not-so-smooth transition to the commercial world. Is this true?
"It's not getting to the land of the nonrev that's the problem, it's getting back." ~~Captain Hector Barbossa
The thoughts and opinions shared under this username are mine and don't necessarily reflect those of my employer.
j.mo
Wed Jul 10, 2013 4:42 pm
Quoting TWA772LR (Reply 4):
They have some additional charts and maps but for the most part they use that same Hi and Low charts as well as approach plates.
I work as a civilian in Base Operations at a military base and we file all the flight plans, help with flight planning, create and file NOTAMS and do flight following, among other things. We are very similar to a flight service staion with the exception of weather. Our base has it's own weather department.
JM
skywaymanaz
Tue Aug 06, 2013 10:38 am
I think this came up at the court martial for the Marine Corp pilots over the Cavalese cable car disaster. The pilots had charts prepared for them by NACO/FAA. Allegedly the chart neglected to include the cable car and others in the area. The charts an Italian pilot would use (JAA prepared?) included them. Wish I had something less sensitive than this incident to source that but it was a key point I recall the defense pointing to. Hopefully that doesn't spin this thread out of control in a flame war over that incident. The verdict was and continues to be controversial but hopefully that can be a separate thread.
rfields5421
Tue Aug 06, 2013 12:36 pm
Quoting skywaymanaz (Reply 6):
I would find it unusual for US military pilots to have local nation charts in many countries.
Even commercial pilots seldom have local nation approach charts in many countries - relying on Jeppsen charts which should be English language duplicates of the local charts.
However, as you mention, something could be possibly left out of the adapted chart.
jcxp15
Thu Aug 08, 2013 4:32 am
Answer to the original question: It depends....
AMC aircrew on a TACC mission will have a flight manager (similar to a dispatcher except they are not licensed and/or do not share responsibility with the PIC if anything is screwed up or goes wrong).
The flight managers are all at Scott AFB in IL and communicate with the aircrew much in the same way dispatchers would with airlines (i.e. via phone, data link or ACARS) and are "responsible" for that flight before and during flight.
Much like an airline, the flight managers get cargo weight/passenger numbers etc... from ATOC or the appropriate agencies prior to the flight and then build the flight plan IAW with the proper diplomatic clearances (i.e. routing and/or FIR entry/exit times) and usually will electronically file the flight plan for the crew. The crew, upon showing usually just has to print off their mission package (which includes flight plan, weather, NOTAMS and other pertinent info) review it, and then touch base with the flight manager for any last many updates and/or concerns (i.e. if the pilots feel they need extra gas for something they will discuss with the FM).
For most local training missions or "non-TACC" missions are planned by the flight crew prior to execution.
