Francoflier
Ariane 6 Baseline Config Set
Sat Jul 13, 2013 11:55 pm
The ESA has painted a fairly clear picture of what the next gen Ariane launcher is set to look like.
Ariane 6 is destined to replace Ariane 5 circa 2021 and interestingly, its design aims at a simpler, cheaper rocket with a payload to orbit capability similar to that of the current Arianespace workhorse.
The most interesting design choice is that of the full solid propellant 1st and 2nd stages.
Exit the Vulcain engine, enter 3 solid propellant boosters, closely based on that of the smaller Vega launcher, all in an effort to cut cost. They're also going back to a 3 stages setup, with the 2nd stage also going solid. The third stage (payload container) retains a reignitable liquid propellant engine, for obvious reasons.
Ariane is now becoming, more than ever, a 'light the fuse, step back and enjoy the show' rocket. I like the 'back to basics' approach, but I will miss the beautiful (and beautifully complex) liquid fuel engines. I guess throttling isn't a dire necessity anymore?
I'm not up to date on the issue, but I wonder if there is any other commercial launcher out there that relies so much on solid propellant?
Are the solid fuel boosters steerable?
http://www.flightglobal.com/news/art...-on-solid-fuel-foundations-388069/
rwessel
RE: Ariane 6 Baseline Config Set
Sun Jul 14, 2013 8:37 am
Quoting francoflier (Thread starter):
The Titan IIIC/IIID/IIIE/34D/4 did lift off purely on the solid boosters, and started the liquid core stage during the flight. The Japanese Mus were solids, but are now also retired. Orbital Sciences has several (Minotaur, Pegasus, and Taurus). The Israeli Shavits (although they’ve not done any commercial work). There are several others. A list:
http://en.wikipedia.org/wiki/Compari...lid-fuelled_orbital_launch_systems
There have been several proposals to build a launcher for small satellites out of solid fueled ICBMs, although not too much has actually happened.
Well, you'd better have some sort of steering!
While different techniques are possible, a gimballing nozzle is pretty common. Vanes in the exhaust stream have been done, as well as separate attitude control thrusters. While I've not actual information on what Ariane is planning, given the size I'll be surprised if it isn't a gimballing nozzle.
Francoflier
Sun Jul 14, 2013 12:25 pm
Quoting rwessel (Reply 1):
Thanks. Didn't know that. I thought the liquid fuel engine went off from the start like the current Ariane 5.
As early as the V2, if I'm not mistaken. But yes, gimballed nozzles it will most likely be...
How about thrust control? Thrust pattern can be pre programmed, but is there a need for ad hoc throttling during launch?
rwessel
Mon Jul 15, 2013 5:12 am
Quoting francoflier (Reply 2):
While there are some methods for variably throttling a solid, none are pretty, although variable lateral vents can work to a degree.
But pretty much no. You can fiddle the thrust profile by shaping the fuel in various ways, and mostly it's left at that. You can add some fiddle by flying a non-optimal flight path (one trivial example is that you could fly a bit of an S-curve to scrub off some excess energy), but usually it's mostly left to a liquid upper stage to get rid of any accumulated error. And ballast.
jollo
Thu Aug 01, 2013 7:57 am
Concur. Possibly with electrical actuators pioneered in Vega (actually, electro-hydraulic, but the hyd circuit is self-contained within the actuator unit).
Users browsing this forum: salttee and 1 guest
