CHS787
"Suicide Circle" In Charleston S.C.
Fri Aug 02, 2013 9:59 am
I saw a video years back that had a C-17 on approach in Charleston, South Carolina, to rwy15, they went down to minimums on the ILS and broke off of the approach to "circle and land" on rwy21.. They called it the "Suicide Circle" and I imagine banking a C-17 over 60 degrees at 1/2KM out and 200AGL from the airport is quiet an accomplishment but I have tried and tried but the footage is gone from the internet.. Can anyone tell me how to find that footage again?
It was cockpit footage, and in the background was the annoying, "TERRAIN TERRAIN, PULL UP, PULL UP"
The whole time you could see that these pilots were the master's of the aircraft, I was impressed by the calmness they showed in a deliberate situation they brought upon themselves..
Much appreciation from this guy!!
This is my very first post after reading for better than (well since airliners.net started) I finally had to break the silence..
HaveBlue
RE: "Suicide Circle" In Charleston S.C.
Sat Aug 03, 2013 8:37 pm
I haven't seen the video, but it sounds impressive for sure.
Oh, and Welcome to (posting) on A.net!
Here Here for Severe Clear!
petera380
Sun Aug 04, 2013 11:12 am
I've seen C130's, C141's and C5's do this, I believe this is what they call a combat landing, that is staying as high as possible for as long as possible and then get down as fast as possible. Fun to watch.
kc135topboom
Sun Aug 04, 2013 4:13 pm
A circle to land approach is not dangerous, as long as the airplane stays within its performance specs and does not get below MDA. We did these from time to time at PSM in the KC-135A, no big deal.
4holer
Mon Aug 05, 2013 4:01 am
Had to look up the airport diagram.
http://flightaware.com/resources/airport/CHS/APD/AIRPORT+DIAGRAM/pdf
Trying to picture it... Did they circle with a right or left bank?
Ghosts appear and fade away.....................
kc135topboom
Tue Aug 06, 2013 11:59 pm
Quoting 4holer (Reply 4):
Seems to me the circle would be to the east of the airport.
CHS787
Sat Aug 10, 2013 9:12 am
This approach I haven't seen since the main runway went down for re-construction and I know these are training flights. There was an awesome video of it, it is not a combat approach i.e. full flaps/spoilers/engines in reverse on approach kinda of thing with a 6+ degree approach path.. They make a normal ILS into KCHS on RWY15, break at minimums, make a hard left turn better than 60 degrees of bank, go wings level, make another hard right turn to land on RWY21.. It is fun to watch these guys and gals perform this maneuver but I wanted to see if any of you guys could remember/find that cockpit footage..
vikkyvik
Tue Aug 13, 2013 1:49 am
Quoting CHS787 (Thread starter):
I don't know if there's anything different in a military circling approach, but I was on a B6 A320 that did one into LGB in July. Basically, we did the ILS to runway 30. Once we broke out of the clouds, and I could see out of the window (prob. around 700-1000 feet), we had swung around to the left of the airport. We went a bit past it, then did a tight 180 to land on runway 12. We finished the 180 only about 5 seconds before passing the fence - I'm guessing we were at about 150 feet. Landing proceeded normally, with touchdown about 1500 feet down the runway.
Granted, you won't do a 60-degree bank in normal commercial ops with passengers. But it was still awesome!
