ThePointblank
F-35B Reaches 500 Vertical Landings
Wed Aug 07, 2013 8:13 am
500 vertical landings reached by F-35B:
http://aviationtribune.com/military/.../653-f-35b-is-ready-for-sea-trials
The Lockheed Martin F-35B short takeoff/vertical landing (STOVL) aircraft completed its 500th vertical landing August 3.
BF-1, the aircraft which completed this achievement, also accomplished the variant’s first vertical landing in March 2010 at Naval Air Station Patuxent River, Md.
http://www.lockheedmartin.com/content/dam/lockheed/data/aero/photos/press_photos/2013/august/F35_500VLs.jpg
And just in time too; next week, USS Wasp and F-35B will go to sea again for further sea trials. This will be the second sea trial of F-35B out of the three planned sea trials for the F-35B variant.
tommytoyz
RE: F-35B Reaches 500 Vertical Landings
Wed Aug 07, 2013 7:33 pm
When is the trap landing issue going to be fixed? It's not about funds, as the development budget has not been reduced. Nor can it be a lack of aircraft. It must be a technical issue if it is taking so looooong.
Tugger
Wed Aug 07, 2013 8:44 pm
Quoting tommytoyz (Reply 1):
As I understand it the problem relates to the stealth requirements of the aircraft. Basically they need to design it such that it won't reflect but will still catch effectively and do so repeatedly with no increased wear, and designing that has been difficult.
Tugg
tommytoyz
Wed Aug 07, 2013 9:51 pm
Quoting tugger (Reply 2):
That sounds logical.
I assume several problems the F-35 faces has the same issue. For instance transonic roll off. In a non stealth plane that would be easily fixed aerodynamically. However you can't do that easily if you don't want to affect stealth. Or reducing buffeting. Can't change that either unless you also change the aerodynamic shape, which will affect stealth, etc...
ThePointblank
Wed Aug 07, 2013 10:32 pm
1. New, re-profiled hook has been tested last year with land trials, with the hook catching 3 out of 5 landing attempts, and with the last two misses caused by the pilot landing the aircraft too far from the wire for a successful arresting. This was without the dampener.
2. Sea trials are scheduled for next year. That has always been the schedule, assuming availability of an aircraft carrier.
Remember, this entire issue was essentially caused by the USN giving their contractors incorrect information about wire behavior...
kanban
Wed Aug 07, 2013 11:47 pm
Quoting ThePointblank (Reply 4):
we could debate that.. seems to me the manufacturer is equally culpable.. It's not like LM have never build a plane for carrier operation. Plus the error was in the bounce back following the wheels going over the cable.. that's a basic design issue caused by the landing gear placement. .
nice to see 500 landings.. however how many attempts attempts were required? (note: just a percent is bogus without knowing the actual number.. )
Ozair
Thu Aug 08, 2013 12:26 am
Quoting kanban (Reply 5):
Would you like to identify which aircraft from the below link is carrier capable and built within the last 25 years?
http://en.wikipedia.org/wiki/Category:Lockheed_Martin_aircraft
How is the manufacturer equally culpable is they are provided with incorrect data? If you provide a builder with incorrect dimensions for your house is it his problem if he builds it to your spec?
Wouldn't a percentage mean you could do a simple mathematical calculation to determine how many were successful and how many weren't given we know how many have occurred?
Quoting tommytoyz (Reply 3):
Transonic issues on modern fighter aircraft can be managed by changes to the FBW software as was done with Typhoon.
tommytoyz
Thu Aug 08, 2013 12:52 am
Quoting Ozair (Reply 6):
What official source do you base this on? PB is not an official source.
The reason the problem with the hook arose in the first place is because of the inherent constraints of building a stealth fighter, said Burbage. The F-35 is the first naval stealth fighter and as such, Lockheed had the unique challenge of designing the jet with a tail-hook that had to be concealed when it’s not being used.
http://www.defensenews.com/apps/pbcs.dll/article?AID=2012301170010
Nowhere does Lockheed say it was as you claim.
Because the tail-hook has to fit within the outer mold line of the F-35, the device had to be fitted further forward on the jet’s ventral surface than on other naval aircraft, Burbage said. The result is that the hook behaves differently than on previous fighters like the F/A-18.
No, because we only know how many successful landing occurred, not how many attempts.
That avenue has been exhausted.
Buffet and transonic roll-off—wing drop in high-speed turns, associated with asymmetrical movements of shock waves—still affect all variants of the JSF, despite control law changes. The program will conduct flight tests this year to assess the problem, but has now reached a limit on what can be done with control laws, Gilmore reports. Further changes would degrade maneuverability or overload the structure.
http://www.aviationweek.com/Article....l/AW_07_01_2013_p23-592154.xml&p=2
[Edited 2013-08-07 17:54:08]
[Edited 2013-08-07 17:59:48]
ThePointblank
Thu Aug 08, 2013 1:25 am
Quoting tommytoyz (Reply 7):
http://www.flightglobal.com/blogs/th...05/the-day-of-the-unmanned-aircra/
However, the X-47B did not carry out an arrested landing upon returning to Pax River. That could be because the unmanned jet was having difficulty making even that first trap it did the week before where the Navy showed off a video of the aircraft snagging a wire. Sources told the DEW Line, at the time of the earlier trap, the aircraft now had a 10 percent field boarding rate… So hopefully, this isn’t an indication of a major problem. The X-47B guys have had to redesign their tail hook a number of times now due to the same inaccurate Navy-supplied wire dynamics model that was partly responsible for the F-35C’s woes.
See above. And this was Northrop Grumman designing and building a aircraft, a company that is supposed to be 'experienced' in building naval aircraft. Incorrect wire dynamics data sent to both Northrop Grumman and Lockheed Martin equals two aircraft with tailhook issues. And NAVAIR approved the original tailhook designs on both aircraft, as they have oversight here.
As a result, the customer is the one that messed up; supplying incorrect information, and approving a design that turns out to have been faulty.
kanban
Thu Aug 08, 2013 4:40 am
Quoting ThePointblank (Reply 8):
Step out of the box.. LM has engineers and computers fro simulations.. the customer provides a requirement the the hide-able hook must capture a wire normally "x" inches off the flight deck. and the wire is there as stated. The manufacturer places the gear and hook to close to allow the wire to spring back to the normal position. Is that a customer design problem?.. no, it's a manufacturer's engineering and simulation problem...
The customer can only define the at rest configuration.. they have no idea initially what the use condition will be. LM knew that and played dumb. This may end up in court for cost recovery so they will do everything to make it a customer problem.
Now in an earlier thread, you noted that the tests were deferred until 2014 due to sequestration.. now it appears they found the money.
ThePointblank
Thu Aug 08, 2013 9:15 am
Quoting kanban (Reply 9):
And the customer provided incorrect data to design the aircraft and approved the manufacturer's original design. It's not the manufacturer's fault when the customer provides the incorrect model for the engineers, computers and simulations to work off of, and the customer, who's providing oversight, gives approval to the manufacturer to proceed with the design.
If I tell you to build a house with one of the rooms to be 5m wide, you supply drawings that shows the room to be 5m wide and I sign off, you then build the house with the room 5m wide, and I later on find out I can't fit my sofa in that room because it's 5.5m wide, are you, the builder at fault for this mess up? No. The customer is at fault for the incorrect specs.
The issue is that the customer supplied a incorrect wire dynamics model to the builder to work off of, and then approved the design for production and testing. NAVAIR has the ability to independently model and test in simulation designs, and they originally saw no problems with the original tailhook design until actual testing showed that the design was flawed.
So, in short, the hook was built to a spec written by the US government. The government has had daily oversight on virtually everything in the design. Seems we ought to ask the government how they got this one wrong too.
From Gen Bogdan's prepared statement before the SASC this Feb:
"A Critical Design Review was completed in February 2013 on a redesigned arresting hook system and modeling and simulation involving the redesigned hook showed a marked improvement in performance. Ground test of this newly redesigned hook is scheduled at Lakehurst, NJ in the 4th Quarter of 2013, followed by aircraft carrier qualifications in 3rd Quarter of 2014."
http://www.armed-services.senate.gov...013/04%20April/Bogdan_04-24-13.pdf
And on a related note, Lockheed Martin test pilot Billie Flynn is participating in a live Twitter chat August 8th at 2 p.m. EDT/11 a.m. PDT. Lockheed Martin will collect questions tweeted to @LockheedMartin, @thef35 or @BillieFlynn with the hashtag #LMChat now through Aug. 8. Follow the #LMChat hashtag on Aug. 8 to participate and join the conversation with Billie.
tommytoyz
Thu Aug 08, 2013 3:24 pm
Quoting ThePointblank (Reply 10):
That is not what LM itself said the cause is:
- Tom Burbage, Lockheed program manager for the F-35 program
I'll take his statements over yours on this. You may want to stop ignoring facts that are not to your liking as the facts are more stubborn and more persistent than any spin.
You fail to find any quote from any official or any official quote what so ever, to support your assumption that the government supplied bad wire data. Your entire posts are based on this false assumption.
[Edited 2013-08-08 08:31:51]
kanban
Thu Aug 08, 2013 4:41 pm
no wonder LM can only survive by being tethered to the government's trough..
Having worked with military programs with a more competent manufacturer, we simulated and tested before production, and occasionally went back saying "this won't work as envisioned" The Air Force looked at the data and agreed..
It appears you are saying because the military had people on site, LM is excused from stupidity.. Actually I wonder how many LM engineers realized the problem and kept their mouths shut.
Where are the capture simulations? Where are the stealth signature simulations? How many of the military observers have had any experience in what they are supposedly observing?.. Most government auditors I've worked with (commercial and military) only dig far enough to see that the company is following processes and procedures, it's a whole different crew that shows up for accident investigations..
No, regardless of who signs your paycheck.. LM screwed up because they took the word of some 19-25 year old kids with no practical experience over seasoned engineers and the taxpayers will pay.
tommytoyz
Thu Aug 08, 2013 5:53 pm
kanban,
I am sure the specs the government has, is that the hook must work. However, the government does not design the plane, LM does, otherwise.....errr, the government would be designing and developing the plane. But this design is Lockheed's and they are responsible for it and its development.
ThePointblank
Thu Aug 08, 2013 8:08 pm
Quoting tommytoyz (Reply 11):
Considering NAVAIR has admitted that they had to redesign the X-47B's tailhook, and had the Fleet Readiness Center South West redesign and build the replacement tailhook for X-47B, this story is collaborated.
http://lexleader.net/navy-rapidly-re...esigns-x47b-tailhook-test-failure/
http://www.navair.navy.mil/index.cfm...ction=home.NAVAIRNewsStory&id=5114
Consider the fact that the design for the F-35's tailhook had to be approved by NAVAIR and it was, it was also based on NAVAIR numbers, thats how the LM came up with it. The X-47B was also NAVAIR approved based on NAVAIR numbers, and also had the exact same tailhook problems. Add to this that there is a report that the Navy supplied incorrect wire dynamics data to LM and Northrop Grumman. What are the odds? Two separate designs made by two separate companies have the exact same problems?
Quoting kanban (Reply 12):
The problem is that if the supplier is given incorrect data to work with in the beginning, the customer is at fault for the issue. It isn't because LM had 'got the design all wrong' in terms of wheel to hook distance - they designed a hook system that met all the USN design guidelines and requirements (with the active involvement of the USN experts) but, as you correctly point out, it failed on initial tests.
Your simplistic mindset 'it's only a hook and we''ve been building them for years' might be a bit simplistic. First, this is an arresting hook system for use on board ships, not the simple emergency systems fitted to some jets - it's a complex and highly loaded piece of design, and the basic challenge is non-trivial. On top of that, this one has to be fully retractable inside a set of LO doors - that added another layer of challenges. Add in whipping wires and a very variable set of engagement conditions, and you have a complicated problem.
kanban
Thu Aug 08, 2013 9:28 pm
Quoting ThePointblank (Reply 14):
It may be simplistic.. however the first problem was the bulbous leading edge rode over the cable instead of under it.. that is simple hook design. Yes, you can complicate the issue with talking about the whole system.. however the basic arresting principles are the same whether you have a retractable (stealth) system or an open one. The time it takes the cable to rebound after being rolled over should/could have been simulated.. but obviously wasn't.. even though they had to move the gear aft and the hook forward. it's the same kind of OEM error that changed the bulkhead material without checking the new material properties and stress loads. To blame everything on the Pentagon is ludicrous.. LM needs to be accountable for their inattention.
Don't know what you do for LM, however carrying the entire burden for their blunders on your shoulders must be a thankless task.
noticed your profile age went up.. should we have wished you happy birthday?
connies4ever
Thu Aug 08, 2013 9:34 pm
Looking at this statement, I am reminded of Monty Python's "Department of Redundancy Department". But I am not surprised, considering the source.
tommytoyz
Thu Aug 08, 2013 9:48 pm
What official source is this from (I ask for the nth time)? And why do you continue to deny what LM itself publicly said about the cause of the issue? Is ignorance bliss? Your attempt to divest LM from the responsibilities of their blunders only focuses everyone' attention even more on exactly those issues. Your flat earth denials are not credible - to put it kindly.
Quoting kanban (Reply 15):
LOL. That was funny!!
Powerslide
Fri Aug 09, 2013 5:25 am
Why do the same people argue over the same non sense. This F-35 crap is getting tiresome. Do you people know that in the real world no one cares if you are right or wrong. My god....
tommytoyz
Fri Aug 09, 2013 3:50 pm
Quoting Powerslide (Reply 18):
This is a discussion board. But if you are tired of this discussion on the largest military program in history, then don't read these threads and stay off them. Problem solved.
[Edited 2013-08-09 08:53:03]
ThePointblank
Fri Aug 16, 2013 1:36 am
USS Wasp and the F-35B has gone to sea:
http://www.hqmc.marines.mil/News/New...st-f-35b-night-landing-at-sea.aspx
USS WASP, At Sea -- A key milestone on the path to declaring F-35B initial operating capability for the U.S. Marine Corps is underway.
The F-35 Integrated Test Force from NAS Patuxent River, Md. embarked USS Wasp, Aug. 12, for the second at-sea test of the F-35B Lightning II, the short takeoff and vertical landing variant of the Joint Strike Fighter.
Developmental Test Phase Two is the second of three planned tests aimed at expanding the F-35B’s shipboard operating envelope for the U.S. Marine Corps. The first shipboard testing phase was successfully completed in October 2011. A milestone many point to as a turning point in F-35B development.
During the 18-day long ship trials, two F-35Bs will conduct a series of tests to determine the aircraft’s suitability for sea-based operations. Pilots will expand the F-35Bs allowable wind envelope for launch and recovery, conduct first-ever night operations at sea, conduct initial mission systems evaluations at sea, evaluate the dynamic interface associated with aircraft operations on a moving flight deck, and further evaluate shipboard sustainment of the F-35 Joint Strike Fighter.
ThePointblank
Sat Aug 17, 2013 10:14 am
We have some photos while at sea:
http://www.navy.mil/management/photodb/photos/130814-N-ML172-127.JPG
http://www.navy.mil/management/photodb/photos/130814-N-ML172-323.JPG
http://www.navy.mil/management/photodb/photos/130814-N-ML172-317.JPG
http://www.navy.mil/management/photodb/photos/130814-O-ZZ999-050.JPG
http://www.navy.mil/management/photodb/photos/130814-O-ZZ999-390.jpg
sweair
Sun Aug 18, 2013 6:49 am
How does the deck cope with that heat? Its like putting a blow torch to it?!
ThePointblank
Sun Aug 18, 2013 9:35 am
Quoting sweair (Reply 22):
A couple of inches of steel helps dissipate the heat. Coupled with the standard anti-skid that is already heat-resistant, the deck copes. The matter becomes what happens over the long term, and that's where the Navy is doing experiments on new anti-skid coatings, which are more durable anyways. Current anti-skid coatings may last anywhere from 6 months to 3 years, while some of the new coatings are supposed to last under standard usage scenarios up to a decade or more.
The Navy is doing a lot of experimentation and testing in particular with the Thermion coating, which is a aluminum-ceramic coating process. The coating is 54% aluminum and 46% ceramic powder. This makes the substance extremely light, only 0.5 lb/ft², which exceeds Navy's specifications for type I non-skid. Application process by using a 3/16” diameter twin wire arc-spray.
According to Thermion's commercial documentation, projected life expectancy of the material is 50 years(!). That would literally be for the life of a typical Navy vessel. However, due to the high operational tempo of naval surface vessels and their extreme operating environment, the life expectancy will likely be significantly reduced, but even an 80% reduction would exceed the current life expectancy of the current non-skid deck coatings. However, Thermion’s process has only been used commercially during the past decade. As a result, testing data on the useful life of the product are not available to support the contractor’s claim. The contractor recommends a lifespan of 10 years based on the lack of testing data in a harsh naval environment.
Such aluminum-ceramic coatings would also have a number of side benefits as well; the Thermion coating is much lighter, only 0.5 lb/ft² compared the spec'ed Type 1 coating which weights 0.99 lbs/ft². This provides the potential advantage of reducing topside weight and its effects on a ship’s calculated stability. Furthermore, the Thermion coating has a higher coefficient of friction; 1.1 for Thermion compared to Type 1's 0.95 on a dry surface.
Currently, the Navy applies over 100,000 gallons of organic based non-skid deck coatings per year. The Navy spends about $27 Million per year on non-skid deck coating maintenance for East Coast ships alone. Any savings from applying a more durable coating that lasts longer would be of immense interest with the Navy as a effective cost savings measure, and because of the longer intervals between re-applications, means that instead of having the crew reapply the coating every few years, it can be moved to every time a ship enters a major refit, where they would be stripping the deck anyways, and no one will have to reapply the coating until the next refit.
As a sort of a reference point with the costings, I saw one example of how much it costs. The weather decks of an Arleigh Burke destroyer require 23,000 square feet of surface area to be coated with non-skid. During the current 18-month operational cycle of an Burke destroyer, portions of the weather decks are completely stripped and resurfaced. (It is very rare when all surface areas requiring non-skid get resurfaced all at once). This process can be accomplished one of two ways.
First, the job could be accomplished solely by using ship’s force personnel, for which no cost data exist. Second, the job may be performed during a three-month Ship Refit Availability (SRA) at which point the job can be accomplished by contractors or the Intermediate Maintenance Activity (IMA). The contract price includes a full- application cost of $11 per square foot. This price includes all of the associated material and labour costs to remove existing non-skid and install new non-skid. By comparison, Thermion coating's total cost is estimated to be around $13.50, and it includes all equipment, labour and preparation.
As a result, the per application costings is as follows: for the current standard anti-skid on a Burke destroyer, it would cost around $253,000 per application, and that would last anywhere from 6 months to 2 years. Thermion's per application costs is around $310,500 and that is expected to last 10 years. Over a 10 year time span, the standard anti-skid would cost $1,265,000, compared to Thermion's $310,500, which equals to a almost 77% decrease in costs for anti-skid coatings on board a Burke for 10 years. Expand that out to something as large as an aircraft carrier, which has 196,020 square feet of surface area to be coated with non-skid, the cost savings is enormous. And if Thermion's claims of a 50 year durability life is anyway remotely close to being realistic in a typical Navy use scenario, then the Navy is stupid to NOT be investigating a more durable anti-skid coating.
KarelXWB
Crew
Thu Aug 22, 2013 6:51 pm
Quoting ThePointblank (Reply 20):
Videos of the landing can be found here:
http://www.aviationweek.com/Blogs.as...bd941d-a8dc-4721-a112-017dc6147728
Close, but no cigar http://vine.co/v/OjqeYWWpVWK
ThePointblank
Sat Aug 31, 2013 4:05 am
Recent update:
http://www.aviationweek.com/Blogs.as...4de239-0201-4cd6-afd9-21344c382ecb
But the basic bits are as follows:
1. 90% availability for the 2 F-35B's per the USMC. As of the morning of Aug. 29, the BF-1 and BF-5 had conducted 94 short takeoffs (STOs) and 95 vertical landings (VLs). They also conducted 19 night sorties, including STOs and VLs. Over a period of 17 days, that's on average 5.5 take-offs and landings for the two F-35's, or roughly 2.76 take-offs and landings each day for each F-35.
2. VL landing has been tested from four headings, each 90-deg. apart. The testing validates the aircraft can conduct VLs at any heading on the ship.
3. Extensive thermal testing was conducted while landing with the nose off toward the port side of the deck and its engine and hot nozzle exhaust on the port side. During this test, the engine nozzle was just at the demarcation on the deck between the Thermion and baseline anti-skid coatings on the deck. The anti-skid coating is brown as a result of the intense heat, while the Thermion appears unaffected. The regular anti-skid coating can handle the heat, but service life may be degraded. Navy is studying how much Thermion to apply to the decks of their ships. Picture from Av Week below:
http://sitelife.aviationweek.com/ver1.0/Content/images/store/13/7/cd47c8c2-8d81-497c-a7bb-a9c2207e3b5b.Full.jpg
4. Heat output for the MV-22's is also a concern as noted, so how much Thermion to apply to the decks will also factor in MV-22 usage as well.
5. Inert weapons testing was also conducted. F-35B's were flown with various internal weapons loads. Flight testing revealed no changes in handling characteristics.
ALTF4
Thu Sep 05, 2013 7:35 pm
Quoting KarelXWB (Reply 24):
Hmm. Those landings are a bit more, uhh, hearty than I would have expected. Pretty cool!
The above post is my opinion. Don't like it? Don't read it.
Users browsing this forum: Nicoeddf and 1 guest
