Mortyman
Not a good start for AW101 in Norway
Fri Nov 24, 2017 3:33 pm
One week old !
First New helicopter receaved just a week ago
Not a good start for AW101 in Norway, AW101 0268 has just rolled outside the hangar at Sola outside Stavanger. The accident happened in connection with ground testing, the engines and the rotors were running when the accident occured.The helicopter has suffered significant damage, fortunately this happened without any of the crew being injured.
https://www.aftenbladet.no/lokalt/i/qnp ... adene-gikk
WIederling
Re: Not a good start for AW101 in Norway
Fri Nov 24, 2017 4:23 pm
That'll buff right out.
Murphy is an optimist
Mortyman
Fri Nov 24, 2017 4:51 pm
Damage to the rotor
How could this happen ? The helicopter was on ground, taxiing ... Just Incredible !
It's gonna be interesting to hear what the accident report says
WIederling
Fri Nov 24, 2017 6:35 pm
Mortyman wrote:
Damage to the rotor
Boss, I had an accident with the truck. But the left mirror is still intact.
what about the right one?
Can't say, still under the truck.
JetBuddy
Fri Nov 24, 2017 7:13 pm
Mortyman wrote:
Damage to the rotor
Really weird accident. The spinning rotor provides stability... how does it tip over like that? Massive wind gust? Damaged rotor causing imbalance?
Glad that nobody were hurt. The crew are really well trained and should be top notch. Will be interesting to find out what caused this.
AirlineCritic
Fri Nov 24, 2017 7:21 pm
What, more exactly, is the damage? Rotors.... and what else?
SeaKing4
Fri Nov 24, 2017 7:41 pm
All engines, all the transmission including all gearboxes, - all will be removed because of shock loading - airframe plus more. It’s lying on its side relatively intact, however all the main rotor blades are gone. I have 3 photos. Will try to upload them later.
par13del
Fri Nov 24, 2017 7:53 pm
Well gives more meaning to HARD RIGHT......
salttee
Fri Nov 24, 2017 9:02 pm
I know it's an expensive option, but I always figured that as long as you're buying a brand new helicopter, you might as well get the factory auto-pilot.
That bunji cord work around has some serious drawbacks.
Mortyman
Sat Nov 25, 2017 7:21 pm
Photos Jarle Aasland
breiz
Sun Nov 26, 2017 10:34 am
Considering that the undercarriage has not collapsed or been retracted by mistake, and that there was no gale side wind at the time, one can only speculate about a faulty pilot's command inducing lift and bank. It seems.
A helicopter, particularly of that size and weight, does not simply tip-over on its own.
Andre3K
Sun Nov 26, 2017 9:11 pm
Dynamic Rollover will most likely be the culprit. Just a guess though.
Per wiki:
A helicopter is susceptible to a rolling tendency, called dynamic rollover, when close to the ground, especially when taking off or landing. For dynamic rollover to occur, some factor has to first cause the helicopter to roll or pivot around a skid, or landing gear wheel, until its critical rollover angle is reached. Then, beyond this point, main rotor thrust continues the roll and recovery is impossible. If the critical rollover angle is exceeded, the helicopter rolls on its side regardless of the cyclic control corrections made.
SeaKing4
Sun Nov 26, 2017 9:54 pm
You are simply speculating about something none of us know the answer too. I know people are entitled to an opinion, but I would rather people don’t speculate. Please wait for the accident report.
SeaKing4
Sun Nov 26, 2017 9:56 pm
Per wiki:
As this happened during an engaged ground run, dynamic rollover will not be the culprit, unless collective input occurred and the helicopter started to lift off. However I have my doubts.
SeaKing4
Sun Nov 26, 2017 10:34 pm
Per wiki:
As this happened during an engaged ground run, dynamic rollover will not be the culprit, unless collective input occurred and the helicopter started to lift off which I would say was highly unsightly. However I have seen a Seaking engage it’s rotors with AFCS selected & this resulted in all 5 main rotor blades hitting the tarmac. A change of pants was needed for all ground crew.
SeaKing4
Sun Nov 26, 2017 10:39 pm
Can a Mod please delete post No. 15 & this post please. TY
Tugger
Sun Nov 26, 2017 10:41 pm
"Engaged ground run"? "AFCS"?
Can you define or explain these terms better, I am not very fluent in rotorcraft terminology.
Thanks.
Tugg
prebennorholm
Mon Nov 27, 2017 3:04 am
Thanks.
Tugg
AFCS = Automatic Flight Control System.
In some ways it does the same thing as a fixed wing autopilot.
But due to gyro forces and other strange asymmetric dynamics on a chopper it is in many ways a much more complicated thing.
If you force me to jump to conclusions, then faulty crew programming of the AFCS will be high on my list.
prebennorholm
Mon Nov 27, 2017 3:32 am
Nah, it was doing a "ground run".
A ground run will normally be a stationary run. Possibly testing rotor balance, vibrations, or blade tracking, blade tracking at different lift settings or angle of attack, possibly also blade tracking with various lateral or pitch control inputs, or other such things.
It fits the fact that only the two flight crew members were on board. While four people (mechanics?) were around outside, possibly operating high speed cameras and other instruments to monitor the rotor dynamics.
Of course a chopper is also "running on the ground" while taxiing by own power, but any competent source would call that "taxiing", not "ground run".
Should this turn out to be a crew error, then repair costs will be subtracted from their salaries. They will be debt free in about ten thousand years.
ThePointblank
Mon Nov 27, 2017 3:54 am
Kiwirob wrote:
I guess this one becomes the spare parts frame. Like one of the 5 frigates.
I actually see this as repairable. The main rotor, blades, and maybe the transmission are probably the main parts to fix or replace. The rest of the structure will need inspection and repair/replacement as needed. I've personally seen helicopters banged up even worst that were repaired in the end.
SeaKing4
Mon Nov 27, 2017 6:20 am
Thanks.
Tugg
Engaged ground run - Engines running & rotor turning.
AFCS - automatic flight control system.
breiz
Mon Nov 27, 2017 3:40 pm
Now, who's speculating :wink2:
It looks we are in accordance in our speculations
breiz
Mon Nov 27, 2017 8:24 pm
Other AW101 roll over accidents:
2014.10.12 : One of Denmark’s AgustaWestland AW101 transport helicopters has been damaged in a landing incident in Afghanistan, the nation’s defence ministry has confirmed.
An aircraft operating from Mazar-e-Sharif air base ended up on its side after a landing incident away from the site, the defence ministry said in a 12 October statement. The crew and personnel aboard the aircraft escaped without suffering serious injury, but the aircraft was seriously damaged, it adds.
https://www.flightglobal.com/news/artic ... ap-404684/
2016.11.23: One of the Nigerian Air Force’s two recently acquired AW101 helicopters has been damaged in an incident that saw the aircraft roll over on the ground.
The accident happened at Nigerian Air Force Base Makurdi on 23 November. Reports indicate the incident happened after the aircraft had landed. A flight engineer was apparently taxiing the aircraft to a hangar when it lifted up and rolled over onto its side.
The flight engineer, who was apparently the only crewmember still on board, suffered minor injuries while the AW101’s rotors were destroyed and it suffered other major damage.
http://www.defenceweb.co.za/index.php?o ... elicopters
prebennorholm
Tue Nov 28, 2017 2:09 am
This accident cannot be blamed on the helicopter. It was "biomechanical feedback".
They were practicing fast troop delivery/pickup in the field at night in total darkness using night vision goggles only. They landed on what was believed to be decently flat land, but they hit deep tracks from tanks or other heavy vehicles.
They couldn't see the tracks due to dust from the rotor blast. The bounces were so violent that the flying pilot couldn't hold his left arm steady on the collective control, and their night vision goggles fell off. Without the goggles they failed to stabilize the helicopter because they couldn't read the instruments.
The helicopter was rebuilt at the factory. Repair cost was DKK 119 million or just under US$ 20 million. This is how it looked before the repair...
https://bdk.bmcdn.dk/media/cache/resolv ... 01jpg.jpeg
The recommendations in the accident report were:
1. Better fixing of night vision goggles for the flight crews.
2. More careful preparations for "dust landings".
3. Eventual updates to emergency cockpit lighting.
4. Intensified information exchange of operating experiences among all AW101 operators in the world.
WIederling
Tue Nov 28, 2017 9:48 am
Universal good advice.
see also:
https://en.wikipedia.org/wiki/2013_Berl ... pter_crash
Mortyman
Tue Nov 28, 2017 4:08 pm
It is specualted here in Norway that the helicopter may have a design flaw and need a change in design. It is mentioned that the Wheels should perhaps be placed differently for better stability...
AirlineCritic
Wed Nov 29, 2017 4:49 am
On the side?
:duck:
WIederling
Wed Nov 29, 2017 4:56 pm
:duck:
On its back. the rotor blades stabilise the attitude.
reminds me:
what to you do about a DIL style integrated circuit that balks at working as desired and designed?
You turn it over and bend all its legs hard over so it can't fight back. :-)
breiz
Sat Dec 09, 2017 7:16 pm
While the accident investigation team is at work, a member of the Norwegian parliament (Jenny Klinge, deputy head of justice committee) asked the government if it had or would considered cancelling the order altogether, Question based on the potential risk for crews for a long period before the accident report is issued.
The minister of justice answered that there was no such plan, that deliveries will go on as planned, unless the manufacturer decides otherwise.
Looks like a move to avoid any contractual penalty.
Nicoeddf
Mon Dec 11, 2017 8:11 am
Or like a sensible decision to proceed with a planned and well thought through purchase of equipment. I am no fan of advocating cancelling the equipment just because it hasn't been operated properly.
A reasonable question would be, how do I know it wasn't operated properly. Well, AW101 aren't falling on their sides left and right. Might there be an improvement of design possible? Maybe, the accident report will surely hint to that. Is the design inherently flawed? Sure not, or other militaries would use the helicopter in actual battlefield operation.
It is always just too easy of a reaction to blame the equipment. Like giving your tennis rack a mad look after you've catapulted the ball into the net. ;)
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
Dutchy
Mon Dec 11, 2017 8:39 am
So do the Norwegians actually want to operate a helicopter? Given the recent rumors that the NH90 order might be canceled and now some politicians want to cancel the AW101.
Egerton
Mon Dec 11, 2017 5:44 pm
I know that years ago the British Army Air Corps had Saunders Roe Skeeter helicopters. https://en.wikipedia.org/wiki/Saunders-Roe_Skeeter They were small 2 seat jobs with a Gypsy piston engine, which was engaged by a long clutch handle which in a car application was pulled on a ratchet up from the floor as a hand brake. The landing gear was 3 small wheels from the small fuselage, thus of a small diameter. The rotor on the other hand was of a large diameter. If this pulling of the clutch handle was done too quickly and the ground surface was slippery perhaps concrete which has iced over, the rotor blades remained stationary while the rest of the Skeeter rotated.
This may have happened in Norway in winter, the ground looked slippery in the photos.
With a Skeeter, I guess that would roll over if the clutch was not instantly released? This might have been not caught quickly enough because the pilot would be thrown about a fair bit even with his 5 way harness tight? And as a brake handle on a car was often difficult to disengage
breiz
Thu Dec 14, 2017 11:44 pm
Quite strange reply from the accident leading investigator, Håkon Sitre, to a Norwegian paper's interview today (Stavanger Aftenblad):
He first states that no technical fault has been found so far.
As the journalist comments that if it's not technical, it must be human, the answer is that it is too early to say.
They have the flight data (more than a thousand parameters)which are being analyzed.
Yet, he can say if the helo was getting off ground. He refers to a witness testimony saying so: "the main undercarriage left the ground before the flip-over".
On the question about how experienced the Norwegian pilots are with the type, he logically replied that the this first Aw101 had arrived barely a week before the accident. Despite their type training by Leonardo Helicopters, the pilots cannot be regarded as experienced with the type.
As potential cause of the accident, he names electronics overload, or part which separated from the helo.
No quarantine on the type so far as no technical failure has been found.
I understand that the investigator has to be careful, but some of his statements look strange to me.
Aesma
Fri Dec 15, 2017 4:57 pm
What about : 5. place a big red button in the cockpit that when pressed would engage the autopilot in "stabilize to stationary flight" ?
Or maybe 6. implement flight (and ground) envelopes preventing the pilots from crashing ?
WIederling
Fri Dec 15, 2017 6:40 pm
you'll never find the time to press it in an emergency.:-)
( bad cockpit lighting: how do you find it?
Aesma
Fri Dec 15, 2017 9:02 pm
Put it between the legs of the pilots or something like that.
petertenthije
Fri Dec 15, 2017 10:32 pm
So when the pilot is shitting bricks the autopilot will automatically be triggered? :)
Attamottamotta!
breiz
Fri Jan 19, 2018 3:39 pm
Stavanger Aftenblad, the local newspaper, visited the military hangar where the damaged AW101 is stored. The journalist met the project leader for army equipment, Lieutenant-Colonel Bård Galåen, who told him the following:
- The final accident report will be issued before summer,
- The cause of the accident which they suspected from early investigation proved to be the right one,
- He will not disclose such cause,
- The repairs include changing gearbox, parts of engines, all rotors. Structural damages have not yet been evaluated,
- The helo will be repaired either in Stavanger or transported back to the UK at Yeovil,
- The cost will be paid by the Norwegian state,
- The accident is regretful,
- Such event will not happen again if lessons are learned.
All this indicate to me that the cause of the accident is a human error.
