VSMUT
Netherlands to cancel 3 F-35s?
Fri Dec 08, 2017 9:07 pm
It looks like the Netherlands is the latest country to find itself in a crunch with the constantly increasing price tag of the F-35. A decision is to be made in 2019:
https://nltimes.nl/2017/11/30/dutch-gov ... ghter-jets
Dutchy
Re: Netherlands to cancel 3 F-35s?
Fri Dec 08, 2017 9:20 pm
suppose to be because of the exchange rate with the Dollar, even though much of the Euro F-35's are made in the Euro zone.
Ozair
Fri Dec 08, 2017 9:42 pm
VSMUT did you read the article you quoted? It clearly says the reason for any potential inability to afford the F-35 is because of currency fluctuations.
Due to the high dollar rate, the Ministry of Defense may not have enough money to buy the last three of the 37 Joint Strike Fighter jets the government plans to purchase, State Secretary Barbara Visser of Defense wrote in a letter to the Tweede Kamer, the lower house of Dutch parliament
As for the price increases to the F-35, the facts present a different story.
VSMUT
Fri Dec 08, 2017 9:44 pm
An increase in the price is an increase in the price, regardless of the reason.
Ozair
Fri Dec 08, 2017 9:51 pm
The price any nation pays would still be in US dollars despite the work done in Italy, the UK and other locations. This is swings and roundabouts though, the currency will go up and down as it has demonstarted over the last ten years.
Slug71
Fri Dec 08, 2017 10:32 pm
Isn't that the cost without engines or support costs though?
At least that's what i remember hearing.
Ozair
Fri Dec 08, 2017 10:48 pm
The slide clearly says includes engine and it is a fly away cost.
WIederling
Fri Dec 08, 2017 10:57 pm
https://www.ainonline.com/sites/default ... ts-web.jpg
prototypes to serial only 60% ? ROFLMAO
787 prototypes were somewhere from $.6b .. $1b. serial frames would cost $360m each. (your 60% :: sold for $83m :-)
Murphy is an optimist
Ozair
Sat Dec 09, 2017 12:09 am
Two issues with your comment, first the above chart is from LRIP 1 to LRIP 10 so when the F-35 does hit FRP the percentage will be obviously higher.
Second, I fail to see what relevance there is in comparing the development of a 5th gen fighter to a commercial transport aircraft?
kanban
Sat Dec 09, 2017 4:52 pm
They could be looking at total program costs to field the plane instead of merely aircraft/engine procurement costs... next year we will know for sure until then it's all guessing
Dutchy
Sat Dec 09, 2017 6:04 pm
I don't understand what you are saying and what good it will do, could you elaborate on this a bit more?
petertenthije
Sun Dec 10, 2017 2:52 am
The program costs are the expected costs that are made during the entire time the JSF is used. So buying the aircraft and engines, as well as the costs for kerosene, maintenance, staffing, upgrades, support equipment etc that are needed for the next 30 or 40odd year. Those figures would of course be significantly more expensive then only looking at the money needed just to buy the aircraft and engines.
Of course some of these costs will be made regardless. You need spare parts and staff to operate your jet, whether it is a JSF, Typhoon, Rafale, Grippen or F-16. But of course these are not all the same, for instance: the Rafale and Typhoon likely need more fuel since they have two engines, but the spare parts for a JSF might be more expensive then the parts for a Rafale. I do not think information is available to the public.
Attamottamotta!
virage
Mon Dec 18, 2017 6:03 pm
The Dutch would be wise canceling the F-35 in favor of the latest Gripen variant.
Dutchy
Mon Dec 18, 2017 7:01 pm
That boat has sailed a long time ago.
Ozair
Mon Dec 18, 2017 8:11 pm
In what way would a Gripen E be better suited to the Dutch over the F-35?
Dutchy
Mon Dec 18, 2017 8:25 pm
price ;)
Ozair
Mon Dec 18, 2017 8:38 pm
Dutchy wrote:
price ;)
Which price? It certainly won't be acquisition, the price of the Gripen E sold to Brazil was significantly more than that being paid by F-35 nations and no one else has bought the jet other than Sweden. As for operating costs, no one knows what the Gripen E will cost. It is bigger, heavier and more complex than the Gripen A/C. It may cost less to operate than an F-35 but it is also significantly less likely to survive in a high threat environment as well as likely require additional upgrades over its operating life to maintain some capability against high end threats.
The question then is, do you buy something cheaper to operate but unlikely to survive, in the hope you will never have to use it, or buy something that may be more expensive to operate but with a far higher chance of survival?
