787
Hyper-Nova
Wed May 31, 2000 10:31 pm
I recently have heard about a star going hypernova a while ago. A few scientists said that the amount of radiation and cosmic dust are Exponential, and on that same hand if the star was at least 100 light years closer, we would of been hit harder by the cosmic dust and radiation. If anyone has heard anything such a follow up or an update, I would really appriciate it. Thank you in advance, and have a nice day.
-Chris
787 Italia - Io, il comandante dell'aria
787
RE: Hyper-Nova
Sun Jun 04, 2000 2:15 am
I take it as no one has heard of this hypernove! I'm shocked, but at the same time, I guess I would of been better off expecting it. Thank you anyway.
-Chris
RE: Hyper-Nova
Sun Jun 04, 2000 7:05 am
What comes after Hyper-Nova?
747-600X
RE: Hyper-Nova
Mon Jun 05, 2000 8:44 am
There is nothing I know of astronomically speaking that can be called a hypernova.
Nova: The explosion resulting from the birth or some death's of a star where sufficient gravitational force causes the star's matter to ignite or in instances of death where sufficient inward pressure causes the star to bulge and thus to cool and die.
Supernova: The explosion resulting from the death of a star where sufficient mass is built up to cause the interior temperatures to create enough pressure that, as enough of the stars mass is burnt off, it bursts apart from within while still burning.
In novae, gases and surrounding clouds may become illumined, and these nebulae are called 'star factories' as their dust combines to form stars. In supernovae, outward jets and thrusts of gas can exceed several million miles per second in speed because of the tremendous force.
Astronomically, the only things more powerful than supernovae are blackholes, quasars, pulsars, and galactic cores (which are theoretically blackholes).
Quasars have constant jets of gas that create the appearenc of a pole running through them, jetting out in two directions constantly. They are many times larger than stars and if one exploded, the resulting force would outmatch a supernova several hundred times. However, it isn't possible for a quasar to explode because enough pressure never builds up. Pulsars emit bursts of gas in brilliant flashes for one or two seconds every one or two seconds. This gives them the appearence of flashing from a distance. These constant releivings of pressure make it entirely improbable for one to explode.
A nova within visibility of our technology will only occur once every thousand years or so. A supernova will only occur once every million years. No one has ever seen either a quasar or pulsar explode.
In theory, a blackhole could explode. A blackhole is simply a mass of matter that is so increadibly dense that the gravity it creates pulls inward with such unprecedented force that even light cannot escape. The gravity of a blackhole is powerful enough to hold entire galaxies, such as our own (being 160,000 light years from edge to edge) together. Because of ionization and a bunch of other atom-stripping things that go on inside blackholes (and stars, for that matter), matter takes on pure properties. This means that every atom is broken apart into ions, simply the pieces of atoms. This very pure matter can be condensed into very small spaces because the distance between the nucleus of an atom and it's electron shell is no longer existant. Thus, all the matter of a blackhole can exist in a relatively small space. No one really knows why, but somewhere in the middle of burning itself to a crisp and ionizing atoms, blackholes don't quite have it in them to explode. If they did, the force would be sufficient to literaly tear our galaxy apart. If Earth, for example, were to be put ten million kilometers from a blackhole, it would be pulled inwards and disintegrated entirely in about one second. I suppose this could be where your hypernova is coming from, it could also be one of the other astronimical phenomenon discovered. However... from Earth and our imaging devices we can see thousands of galaxies, we can take pictures of every part of our galaxy. We can count the quasars and pulsars in our local cluster of galaxies (there aren't very many). In the near future we will be able to count the stars in our galaxy and chart the arms. If any one of these very large astronimical phenomenon were to explode, it would mean more to many scientists than almost anything else. I doubt it would go unherd of by most people, especially those with an interest in space.
My guess is that 'hypernova' is someone's synonym for 'supernova' who doesn't know that a supernova is more powerful than a nova and is mistaking it for being a nova.
Samurai 777
Gamma Ray Bursters
Tue Jun 06, 2000 5:01 pm
There is one kind of cosmic blast more powerful than a supernova - a gamma-ray burster. Gamma-ray bursters are thought by scientists to be more powerful than supernovae, but are at a near total loss as to what they really are. It was also not even known whether they originated within our galaxy or much farther away. They've actually been studied since the late '60s, but it's only within the last three years they've been able to come up with good clues as to what they are. It turns out that they apparently seem to originate from billions of light-years away, from a time when the Universe was younger. A measurement made by Caltech scientists on a galaxy where a gamma-ray burster occured showed the point of origin to be 12 billion light-years away!
Gamma-ray bursters are so called because they emit mostly huge amounts of gamma rays and X-rays. They have been theorized to be giant supernovas to exploding neutron stars. Recently, gamma ray bursters have been observed associated with fireballs visible by the Hubble Space Telescope. Any explosion would have to be extremely powerful, much more powerful than supernovas to so easily visible with large telescopes. At least one has been bright enough to be visible with a pair of binoculars! Gamma-ray bursters tend to occur all regions of the sky, exploding at a rate of 2-3 per day.
NASA does have some stuff about gamma-ray bursters. This is one of the most recent articles on gamma-ray bursters, with some links of its own:
http://science.nasa.gov/newhome/headlines/ast10feb99_1.htm Have a look if you want - these aren't exactly your average boring, super-dry scientific journals - these are kinda more like press releases.
Users browsing this forum: skywaymanaz and 1 guest
