airmale
Computer Query
Thu Feb 22, 2001 2:13 am
which is better for the computer;
to shut it off after youre through( everything off).
leave it on( so i can keep seeing the beautiful wallpaper i set from this site)
also does turning the PC on/off too often harm it in any way? and what about the monitor how can i retain the wallpaper without it turning into a screen saver after a while Confused
.....up there with the best!
RE: Computer Query
Thu Feb 22, 2001 2:30 am
I always leave it on during the day and shut it off at night. It takes alot of power to fire up a CPU so it's better for it to keep it on rather thatn turing it on and off.
9A-CRO
Crew
RE: Computer Query
Thu Feb 22, 2001 2:38 am
all electrical appliances work beter if they are not being turned off and on all the time
during turning on special transitional effects occur on some elements
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward...
9A-CRO
Crew
RE: Computer Query
Thu Feb 22, 2001 2:39 am
what I ment by work better is that chance of malfunction is smaller
airmale
RE: Computer Query
Thu Feb 22, 2001 2:43 am
What about thw wallpaper, how do i retain it without a screensaver popping up after a while Confused
9A-CRO
Crew
RE: Computer Query
Thu Feb 22, 2001 2:50 am
assuming that you have Windows system
go to Control Panel, and in dysplay menu (I am not quite sure) find screensaverr setting and set to never
Users browsing this forum: Dano1977, Google Adsense [Bot], TheF15Ace and 1 guest
