Blackened
Adding Sound To User Profile
Thu Apr 12, 2001 6:15 am
How does that work. Does anybody know?
Bring it back, bring it back, bring it back
Starship
RE: Adding Sound To User Profile
Thu Apr 12, 2001 7:24 am
Yes, I know; what do you want to put in your profile?
Behind every "no" is a "yes"
Blackened
Midi Files From My HD
Fri Apr 13, 2001 12:16 am
Tell me how it works anyway.
Starship
Fri Apr 13, 2001 8:19 am
Well, midi files from your harddrive ain't going to work!
You will need to upload that midi sound file to a website and once you have done that you will have to locate the sound file's URL (Uniform Resource Locator) address - the same as with a photo. Once you have done that, then you need to type the following instruction into a suitable place in your user profile:
{bgsound src="http://www.url.address.of.midi.file.mid"autostart="true"hidden="true"loop="infinite"}
If the sound file must just play once, then you would leave out the instruction: loop="infinite"
The brackets depicted as { } would have to be replaced with these < > before and after
Fri Apr 13, 2001 9:59 am
Let Me Try:
Fri Apr 13, 2001 10:01 am
One more time,
Fri Apr 13, 2001 10:04 am
What am I doing wrong?
I did:
{bgsound src="http://files.midifarm.com/midifiles/general_midi/c&c_music_factory="true"hidden="true"loop="infinite"}
With the { and } replaced by < and >. ??????????????
Fri Apr 13, 2001 10:11 am
Again,
DAMN!
AerLingus
Fri Apr 13, 2001 12:34 pm
With luck, you should be hearing a scene from 'Monty Python and the Holy Grail.'
Get your patchouli stink outta my store!
Thom@s
Fri Apr 13, 2001 9:56 pm
Right now, I'm hearing Beach boys. Dadadaadadaada. Catchy.  Smile
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
B-707
Sat Apr 14, 2001 2:41 am
Yes, Thom@s. Catchy indeed. "Fun Fun Fun" by the Beach Boys is very catchy.  Smile
Sat Apr 14, 2001 2:58 am
Hey! What's this I'm hearing? Big grin
Starship
Sat Apr 14, 2001 3:57 am
You are hearing Fun Fun Fun by the Beach Boys because that's what I imbedded in my first post!
Boeing 747-400's attempt at imbedding sound will not work, because he has left out some inverted commas, apart from which the URL looks wrong.
I'll have a closer look at that when I get a chance. However don't have any more attempts at imbedding sound in this particular post - it already has background sound.
Starship
Sat Apr 14, 2001 7:40 am
B747-400
I've had a look at what you were trying to do. You have a web address that takes you to the site of a midi file entitled gonna_make_you_sweat, but not the URL of the midi file itself, so it won't work. Also the inverted commas before and after the URL address, once located, are necessary, or the midi file will not load. So what you were trying to do should in fact have looked like this, other than for the < > brackets which need to replace the { } brackets
{bgsound src="http://files.midifarm.com/midifiles/general_midi/c&c_music_factory/gonna_make_you_sweat.mid"autostart="true"hidden="true"loop="infinite"}
I've tried it in a new post and it works - don't try it here, or you will have a sound file on top of an already embedded sound file, apart from which the URL address is rediculously long!
Users browsing this forum: BawliBooch, L410Turbolet, mad99, Majestic-12 [Bot], SOBHI51 and 3 guests
