Your Razor - Electric Or Manual
Fri May 04, 2001 8:00 am
So what is everyone using, electric razor or manual? And tell us why!
I preffer manual because it really shave you close. But I like electrical when i'm rushing. I got a Mach 3 from Gilette as manual and a Braun elec. razor.
Nicolas
DeltaRNOmd-80
RE: Your Razor - Electric Or Manual
Fri May 04, 2001 8:04 am
I use a manual, its a Schick Tracer FX, and I use Gillette shaving cream. I plan on getting an electric one though, I like those Norelco ones that spit out the lotion as you're shaving.
Lindy
Fri May 04, 2001 8:28 am
BIC one time use. Green one with vitamin E or B whatever hehehe I dont like Mach 3 and I dont like Electric razors.
 Smile
BWIADCA - Nikon D100
Fri May 04, 2001 8:37 am
Got some Schick ones cheap so I've been using them. Everything gets stuck in between the two blades...
I have an electric shaver but I usually leave my beard growing to the point the shaver can't handle most of it.
Western727
Fri May 04, 2001 8:53 am
Have a Norelco Electric, and I use to use it daily. But I switched back to the blade recently, because it shaves closer, and it doesn't hurt as much. I have a Gillette razor, and I like the Edge Gell.
Jack @ AUS
Starship
Fri May 04, 2001 9:13 am
I dislike electric razors and never use them, even though I do possess one. Like Nikolaki, I use a Gillette Mach 3. Great razor, but I cringe every time I have to buy replacement blades, which are imported and cost quite a lot due to our poor exchange rate.
Behind every "no" is a "yes"
Fri May 04, 2001 9:21 am
I use both, depending on how much time I have. For manual I use a Mach 3 and for electric I use a rechargeable philishave which is really really good.
The Philishave is great for travelling.
mb
Fri May 04, 2001 9:47 am
You're right starship, the remplacement blades of the Mach 3 are really costly!
guerosinfe
Fri May 04, 2001 9:48 am
I have a Mach 3 too, I prefer manual.
An-225
Fri May 04, 2001 11:32 am
I use Mach 3 and Sensor Excel when I am at home. By the way, I gotta go and shave...  Smile/happy/getting dizzy
Money does not bring you happiness. But it's better to cry in your own private limo than on a cold bus stop.
RayChuang
Fri May 04, 2001 11:49 am
I myself use an electric razor--the Panasonic Sonic 2 double-foil model. Fully charged, it really shaves you extremely close.
If I were to use a manual razor, I use Gillette Sensor Excel--Mach 3 is overkill given I don't have that dense facial hair.  Smile
Fri May 04, 2001 12:11 pm
I don't shave.
Samurai 777
Fri May 04, 2001 2:42 pm
Gillete Mach 3 is what I use - electric razors just don't achieve anywhere near the smoothness I can get with manual.
AC_A340
Fri May 04, 2001 9:46 pm
Mach 3. However I do have an electric when I'm in a hurry.
Thom@s
Fri May 04, 2001 11:02 pm
electric, don't have time for anything else.  Smile
Thom@s
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
sccutler
Sat May 05, 2001 3:32 am
The Mach III, and they are expensive to refill in ANY currency!
...three miles from BRONS, clear for the ILS one five approach...
Sat May 05, 2001 4:57 am
I use a Gilette Mach 3 & I like using a manual razor because the shaving cream makes you smell good after you use it.
Users browsing this forum: afcjets, Baidu [Spider] and 24 guests
