lehpron
I Need Some Serious Algebra Help
Fri Dec 14, 2001 5:05 pm
Here’s the deal:
Rather than trying to construct a wind tunnel and calculate various numbers to find the coefficient of lift of an airfoil, I thought of simply dropping a model airplane from some known height of Y. The force of lift will make it follow some curve away from a point on the ground at a distance of X. The picture below shows what I’m trying to get at and all of the formulas I’ve used.
The problem is I can’t get the formula to be without the terms of time and velocity. I know I’m missing something because every time I do it, my coeff has units!
Where g = 9.80m/s squared, rho (density) = 1.22 kg/m3, uF (coeff of friction) = assumed to be 1.0
[I don't know if I am dealing with coeff of friction or coeff of drag]
To check my answer for realism, the weight (mg) must equal the lift force (Fx) with speed (vy) of 3m/s, it never does. What am I doing wrong?
airways1
RE: I Need Some Serious Algebra Help
Fri Dec 14, 2001 10:43 pm
I'm sorry but the situation is a lot more complicated than you have made out with your maths.
First mistake, the acceleration that you have called a is actually proportional to vy-squared, not vx-squared. Why is this? Well you are considering acceleration in the X direction, so it should be equal to Fx/m, and Fx as you stated in your first equation is equal to vy-squared.
Second mistake, those equations you have quoted for the value of Y assume a constant acceleration, and this is not the case since you have a term proportional to vy-squared in your expression for Fy. If you want to calculate it properly you will need to use calculus.
Apart from all that, you assume that your model plane will remain at a constant angle during its whole descent, which is unlikely, plus you have neglected drag in the X direction, which might be important in practice.
I suggest you go back to the wind tunnel idea where everything is operating under steady conditions.
AgnusBymaster
Sat Dec 15, 2001 1:11 am
I have to admit, this is not what I expected when I opened this thread!
Olympic A-340
Sat Dec 15, 2001 6:40 am
AGH!!!!!!!...MATH=BAD, VERY BAD
American_4275
Sat Dec 15, 2001 6:42 am
Agnusbymaster,
I agree 100%.
Lehpron,
Good luck dude that looks horrid!
777236ER
Sat Dec 15, 2001 6:53 am
Argh, you've messed up quite a bit there. Airways1 spotted them all, i think.
my coeff has units! Lol. I love it when that happens. I've fucked up SO much in the past cos coeffs have units. Just today, a coeff of restitution was 5 (!) and had units Kg/m!!! The particles were hitting each other, there was a completly elastic collision, but the system ended up with more mass than it started with! ARGH!
In my expierence, theoretical windtunnel formulas look good, but there are too many variables for them to be too accurate in real life.
Still working on the SC replacement? I'd like to see the updated version! How's the sonic-boom-reducing lamina flow going?
777236ER
lehpron
Tue Dec 18, 2001 2:35 pm
Airways1:
...the acceleration that you have called a is actually proportional to vy-squared, not vx-squared. Why is this
Think of it this way: Lift depends on the velocity squared, assuming everything else is somewhat constant. Since velocity is governed by the fact than the force of gravity accelerates the planes down, hence Vy.
...you have quoted for the value of Y assume a constant acceleration...
It isn't constant, that's why I put Fy=mg-(.5)(rho)A(Vy^2)Cf. As the plane falls gravity pulls it down and drag friction keeps it from accelerating too fast, hence terminal velocity. On the other hand, I figure that since I am droping this thing in a room, the variance is somewhat negligible.
...you assume that your model plane will remain at a constant angle during its whole descent, which is unlikely
Why? The center of lift and the center of gravity are at the same point and with no elevator flaps or moments changing the AoA, it really cannot vary.
...plus you have neglected drag in the X direction, which might be important in practice.
Sorry, I forgot this! Yeah, no it's a whole lot easier to figure out, huh?  Insane  Smile/happy/getting dizzy
777236ER:
Yes I'm still trying to tweek it so the area rule works as well as the current problem of have induced drag at one end of the wing; aside from finals, it's all good. I haven't gone to my site and updated anything since I've been busy. Me and my engineering proffesor are going to be working on the engine phase of Project: Lehpron, I plan to introduce this as my entry into the 2002 Collegiate Inventor Competition this coming year in Ohio.
Lehpron is my brainchild, she's supposed to be about the size of NASA's Hyper-X, except she's supposed to takeoff on her own, it's a challege that represents my primary interest in commercial airliners: the advent of Hypersonic airliners.
I can't help it, I like hypersonic more than supersonic, do you blame me? That's probably why I'm getting behind, don't worry you guys, the "cm_8Wa" will be inaugurated by mid-January and will be revealed.
 Big thumbs up
lehpron
airways1
Tue Dec 18, 2001 10:37 pm
lephron
Your acceleration, a, is in the X direction, therefore it should be equal to Fx/m, not Fy/m as you have stated.
Secondly, I see you have the term proportional to vy-squared in your expression for Fy. However, I shall say again, the equation you have quoted for Y assumes a constant acceleration. In other words, your equation for Y is not compatible with your equation for Fy.
As for your aerofoil remaining at a constant angle, then I agree with you it should be OK if the centre of lift and centre of mass are coincident, but that assumes the position of the centre of lift is independent of the velocity.
777236ER
Tue Dec 18, 2001 11:21 pm
Bah, hypersonic isn't flying! It's just blasting through the air, knocking everything in front of it out of the way.
Seriuosly though, if you've come up with something you regard as being unique and good, you should patent it. It's very expensive, but it's worth it. Trust me. I had a design that i have produced stolen by a collegue once, and without a patent, you have almost no legal ground to show that you have the rights to the design, and not him.
Regards.
delta-flyer
Wed Dec 19, 2001 11:04 am
Lehpron, if you are assuming that terminal velocity is reached, then the trajectory of the plane will be a straight line (ignoring the initial transient from zero to terminal velocity). The only way for this experiment to make sense is if the plane could be made to glide at a constant angle of attack. Then, by conducting tests at different aoa's, it may be possible to map lift and drag coefficients, but I can't imagine any way of holding aoa to a given value. At least not without little pilots on board! That's what wind tunnels do, which is where we started.  Smile
Pete
"In God we trust, everyone else bring data"
lehpron
Wed Dec 19, 2001 12:43 pm
Airways1:...the equation you have quoted for Y assumes a constant acceleration. In other words, your equation for Y is not compatible with your equation for Fy.
If this is the case, what should/could it be?
Delta-flyer:...then the trajectory of the plane will be a straight line...
Perhaps stating the terminal velocity thing was misleading, this model will never reach a terminal velocity in a 2.4m room! I figured the calculations would be simpler if the drag due to falling were ignored because it might not have such a big effect on force considering it wouldn't be going all that fast.
But it is a paper-airplane, in fact it is an 80%-approx to Lehpron. I can't find much info online about flying wedges so I thought this type of analysis would help.
airways1
Wed Dec 19, 2001 7:35 pm
Lephron
It's a bit difficult to show you what the equation should be without being able to display the correct mathematical symbols.
Let's just say, use Newton's 2nd law in the form
F=m(d²y/dt²)
and put in your value for Fy, remembering that
vy=dy/dt.
Then you will be left with a differential equation that you need to solve for y.
Users browsing this forum: dazoy, Dutchy, Kiwirob, LittleFokker, Varsity1 and 2 guests
