mrman_3k
What Phenomenon @ 0^F?
Tue Feb 26, 2002 12:14 pm
What is the name of the phenomenon at 0 degrees Farenheit? Also if there are any links to more information that would be appreciated.
NZ767
RE: What Phenomenon @ 0^F?
Tue Feb 26, 2002 12:17 pm
Dunno about Farenheit but 0 degrees Celcius (or Centigrade) is Freezing Point!
mrman_3k
Tue Feb 26, 2002 12:46 pm
I know that, but this paper says what phenomenon occurs at 0 degrees fahrenheit?
flyf15
Tue Feb 26, 2002 12:47 pm
If I remember correctly from Chemistry, 0F is the freezing point of some strange combination of water and some other things (I think salt was one of them).
Tue Feb 26, 2002 12:51 pm
Hmmm..... It could be "What phenomenon occurs at 0 degrees Celcius?" And that would be the freezing point of water. But 0 degrees F? Never heard of that before.... Could just be a typo.
mrman_3k
Tue Feb 26, 2002 12:57 pm
No it is not a typo, it talks about the celcius, kelvin and other things, then it says for an extra challenge, find what happens at 0F
JetService
Tue Feb 26, 2002 1:01 pm
The phenomenon is indeed at 0°F.
It works like this:
The closer to 0°F it is outside, the more likely your car needs gas.
"Shaddap you!"
Tue Feb 26, 2002 1:08 pm
Could it be the temperature at which ice contracts rather than expand?
mrman_3k
Tue Feb 26, 2002 2:00 pm
How stupid I am, 0F was the lowest temperature Farenheit could produce with water and salt.
Tue Feb 26, 2002 2:13 pm
The exact temperature at which the nipples achieve a perpendicular status in relation to the aeriola(sp?), without mechanical adgitation at atmospheric pressure. Commonly referred to in the physics and chemistry world (as well as in most trailer parks) as the Temperature of THO.
Users browsing this forum: afterburner, johnboy, ltbewr, salttee, WarRI1 and 2 guests
