EWRvirgin
Dial-up W/ A Cell Phone
Sun May 12, 2002 7:40 am
Has anyone tried this? I'd like to use my cell phone to dial up with my laptop when away from home. How do I set this up? Thanks in advance.
artsyman
RE: Dial-up W/ A Cell Phone
Sun May 12, 2002 8:40 am
You can do this one of two ways, there is a cable connection for connecting you phone to your laptop, or you can connect the phone to the laptop via the infra red port on both (assuming that they both have such a thing.
SophieMaltese
Sun May 12, 2002 10:46 am
I thought you needed a special type of modem?
JetService
Sun May 12, 2002 12:50 pm
There's cables out there that allow this. Just plug into cellphone and computer's tel-jack. I did it with a Nokia and a Mac laptop
"Shaddap you!"
EWRvirgin
Sun May 12, 2002 2:42 pm
ok, I have a cable with one end that goes into my nokia and the other end is a female serial db9 plug. Don't know how the laptop will recognize it as a modem or dial the number thru it.
Klaus
Sun May 12, 2002 7:16 pm
Many cellphones have an AT-command-set-compatible modem built in. Which means the phone behaves very much like a conventional serial modem. The connector goes into one of your computer´s serial ports.
You´d possibly need the right protocol configuration file for this phone ("modem description" for MacOS) if your system can´t work with the phone right out of the box. Try to get it from the phone´s manufacturer (if it didn´t come with the phone or the cable). It´s quite possible that several phones from the same manufacturer use the same modem commands, so you may not need an exact match.
Users browsing this forum: Airstud, BobPatterson, edgaren, Tugger, UltimoTiger777 and 4 guests
