SSTjumbo
CD Player Help (extremely Technical)
Sat Jul 13, 2002 12:12 pm
Hello, I have a portable Sony sport CD player. I dropped it recently, and it seems like there is a problem with the lens moving thing. I put a CD in, and it says "no disc" and makes the noises as though it is searching for a disc. I tried cleaning the lens to no avail, so don't suggest that. I actually think the lens may have become misaligned or something. Any suggestions?
I don't know, so this is my signature.
Boeing4ever
RE: CD Player Help (extremely Technical)
Sat Jul 13, 2002 12:18 pm
When in doubt, get a bigger drill. My advice would be to open it up and try to tinker with it, CAREFULLY. If not, you might have to w/o that sucker and get a new one. It may be that the lens is misaligned, so when you open it up, check that specifically. Also look if the lens is damaged inside or not.
B4e  Big thumbs up
LOT767-300ER
Sat Jul 13, 2002 1:06 pm
If its on warranty just go to your local Sony store and they will send it off to fix it. Thats what they did with mine. Took 2 weeks.
747-451
Sat Jul 13, 2002 1:47 pm
Let's see, you dropped it, right?
Well Sony will void your warranty.
Buy a new one, since they are cheap and it would cost more to fix it....
apathoid
Sat Jul 13, 2002 9:02 pm
"Extremely technical post...."
the lens moving thingee....got a part number for that?
L-188
Sat Jul 13, 2002 9:04 pm
I think it is the same one that a Lear oil bypass pin ususes there Apatoid.
apathoid
Sat Jul 13, 2002 9:09 pm
Those Honeywell bastards can't get a damn thing right. If my Sony is using any Honeywell parts, I am going to look for a Pratt and Whitney TV.
victech
Sun Jul 14, 2002 12:44 am
If it's an IBM part, you're screwed! You'll need an FRU #, an Option #, a Part #, and an Assy # (and my customers wonder why I don't fix ThinkPads!)
Ralgha
Sun Jul 14, 2002 12:33 pm
Extremely technical huh?
SSTjumbo
Mon Jul 15, 2002 12:58 pm
Well guys, I hate to break the bad news, but by extremely technical I was hoping that I would get an answer from someone who worked with CD players and not someone who knew nothing beyond how to work it and how to think hypothetically and simplistically [as the lecture continues  Sleepy...]. However, on a positive note (if anyone cares  Laugh out loud) I did manage to find out that one of the lens mounts had broken and that was the only problem. I've just got to get inside it and glue it back on, hopefully.
victech
Mon Jul 15, 2002 7:22 pm
On a more serious note, SSTjumbo, just be very careful when working in and around the laser/lens assy. If you have a magnification workstation, use it--because the last thing you want to do is get your skin oils on the lens...
