lehpron
Someone Debug My C Source Code
Tue Nov 05, 2002 1:36 pm
Our assignment (I admit to procrastinating) is due by midnight, which is in 2.5 hours. I already tried looking for examples online but none was found.
Our assignment was in the C programming language, and we were to find the root of a quadratic function, Ax2 + Bx + C = 0, and thier corresponding slopes. The program is supposed to terminate when 'A', 'B' and 'C' equals zero, but instead it terminates at just 'A' = 0.
This is my code:
#include
#include
float flt_a;
float flt_b;
float flt_c;
int int_x1;
int int_x2;
int int_m1;
int int_m2;
int int_root;
void main ()
do
printf("For formula reading Ax^2 + Bx + C = 0,n");
printf("n");
printf("Enter first coefficent, A:n");
scanf("%f", & flt_a);
printf("n");
printf("Enter first coefficent, B:n");
scanf("%f", & flt_b);
printf("n");
printf("Enter first coefficent, C:n");
scanf("%f", & flt_c);
printf("n");
if (flt_a != 0.0 || flt_b != 0.0 || flt_c != 0.0)
if (flt_b * flt_b - 4 * flt_a * flt_c < 0.0)
int_root = 0;
else
int_root = 2;
int_x1=(-flt_b + sqrt((flt_b * flt_b)- 4*flt_a*flt_c))/(2*flt_a);
int_x2=(-flt_b - sqrt((flt_b * flt_b)- 4*flt_a*flt_c))/(2*flt_a);
int_m1= 2 * flt_a * int_x1 + flt_b;
int_m2= 2 * flt_a * int_x2 + flt_b;
else
if (flt_a == 0)
int_root= 1;
int_x1=(-flt_c / flt_b);
int_m1= flt_b;
else
int_root= 0;
while (flt_a != 0.0 || flt_b != 0.0 || flt_c != 0.0);
printf("n");
printf("n");
printf("Program terminated:n");
printf("n");
What am I missing, cuz it complied perfectly?
PPGMD
RE: Someone Debug My C Source Code
Tue Nov 05, 2002 1:39 pm
Where are your includes?
At worst, you screw up and die.
PPGMD
Tue Nov 05, 2002 1:41 pm
Also just a tip its bad programming mojo/style to declare all your varibles are global varibles.
lehpron
Tue Nov 05, 2002 1:47 pm
Sorry, it was supposed to be:
#include (stdio.h)
#include (math.h)
the carrots make the *.h files disappear.
Our teacher couldn't care less about complex roots, we should just let everything equal -999.99. I have not got there yet.
PPGMD
Tue Nov 05, 2002 1:50 pm
Got any test cases that I could run though it.
PPGMD
Tue Nov 05, 2002 1:54 pm
First problem:
should be:
while (flt_a != 0.0 && flt_b != 0.0 && flt_c != 0.0);
Need to use ands and not ors.
Second problem you have no output until the program exits? That doesn't seem right.
PPGMD
Tue Nov 05, 2002 1:56 pm
third problem all you n's should be /n for new line.
lehpron
Tue Nov 05, 2002 2:04 pm
Okay I changed the || into &&, now it loops through (like it supposed to) until put all coeff's as zero, then it freezes and doesn't terminate.
What did you mean by "n's should be /n for new line"? Which lines are these in reference to?
lehpron
Tue Nov 05, 2002 2:06 pm
In terms of out put, I'm taking baby steps to make sure this part works, if it does properly, i.e. it'll complie and run, then I'll just throw that stuff in last.
PPGMD
Tue Nov 05, 2002 2:11 pm
These three lines are a good example(there are more example that appear to need to be changed):
printf("n");
Which has the output of:
"For formula reading Ax^2 + Bx + C = 0,nnEnter first coefficent, A:n"
They should be if I read your code right:
printf("For formula reading Ax^2 + Bx + C = 0,/n");
printf("/n");
printf("Enter first coefficent, A:/n");
Which could have the output of:
Sorry I can't help you much more, I do need to goto sleep I have a Digital Logic test in the morning. But I suggest that you print it out and go though it line by line on paper(away from the computer), you will see alot of mistakes that way. Thats the verification phase the Personal Software Process (PSP) which dominates my 4 years in Computer Science.
lehpron
Tue Nov 05, 2002 2:23 pm
10Q 4 the help, PPGMD, good luck on ur test.
Users browsing this forum: EA CO AS, PanHAM, rfields5421 and 2 guests
