david b.
M1 Tanks
Wed Apr 02, 2003 3:52 pm
How well would a MI tank fend if it took a direct hit to the back(where the engine systems and coolers are) by a infantry anti-tank rocket? From what I understand, the vehicle stands up pretty well but the back end does look flimsy.
Teenage-know-it-alls should be shot on sight
Glenn
RE: M1 Tanks
Wed Apr 02, 2003 3:55 pm
I guess the M 1 would come out A1
M1A1 get it  Smile/happy/getting dizzy
TSV
RE: M1 Tanks
Wed Apr 02, 2003 4:10 pm
So does that mean an M1A2 would come out A2?
"I told you I was ill ..." Spike Milligan
b757300
RE: M1 Tanks
Wed Apr 02, 2003 4:11 pm
Actually, we've lost 2 M1-A1 because they were hit in the rear by a weapon the Iraqis weren't suppose to have, the Russian built "Kornet" anti-tank missile. This isn't some old piece of Soviet crap. The Kornet went into production in 1993.
The rear of tanks has always been the weakest area. During WWII, Allied Shermans, which blew up if just about anything hit them, had to flank the German Tiger and Panthers in order to get a good shot on the rear armor. This was the only way to have a chance to knock it out. Despite the fact that the M1-A1's were fairly FUBARed, the design worked perfectly and the crew escaped unhurt. The panels designed to blow off if the ammunition detonates did their job and saved the crew. The mistake was moving tanks along without infantry support. All it takes is one guy with a Kornet hiding behind some sand to fry a tank. Also, it happened during the middle of that sand storm last week so visibility totally sucked.
"There is no victory at bargain basement prices."
jwenting
RE: M1 Tanks
Wed Apr 02, 2003 4:53 pm
All tanks are indeed weakest from the rear.
The idea is to destroy the enemy BEFORE he sees your butt  Smile/happy/getting dizzy so it doesn't matter, but in highspeed warfare that won't always happen.
I wish I were flying
GDB
RE: M1 Tanks
Wed Apr 02, 2003 9:18 pm
Am I right in thinking that the M1 has Chobbam Armour (named after the British town where it was developed in the 1970's).
Worrisome about that modern Russian AT missile.
Did you hear about the British Challenger 2 tank that took 70 (yes 70) RPG hits, kept on going and fighting though!
victech
RE: M1 Tanks
Wed Apr 02, 2003 9:28 pm
No, the M1A2 has a highly secret active explosive reactive armor.
toady
RE: M1 Tanks
Wed Apr 02, 2003 9:32 pm
The M1 has Chobham ceramic armour - but, like Challenger, not on the arse end, turret top or hull bottom.
Doesn't suprise me about the Challenger taking those hits. I've seen footage of Chobham vs conventional armour being fired at by a 120mm main armament at very close range - the conventional armour had 5 very neat holes punched through it, the Chobham had 5 dents!
TSV
RE: M1 Tanks
Wed Apr 02, 2003 10:00 pm
Is that footage available on video or DVD?
I remember seeing footage (external and internal) of an Abrams taking a hit on the ammunition compartment on one of the Video Ordnance videos (Volume 6 Part 2 "Battle Tank"). The Challenger is also featured on this but I can't recall watching it. Must put it in the video and have a look.
toady
RE: M1 Tanks
Wed Apr 02, 2003 10:27 pm
I'll hazard a guess that the footage is not available. I saw it at the Royal Armoured Corps gunnery school in Lulworth, Dorset.
erj190
RE: M1 Tanks
Thu Apr 03, 2003 12:05 am
According with the data I have available, the M1A1 and M1A2 tanks indeed have Chobham armor.
The characteristics of that armor, and the way it is applied on the tank are secret. This applies for the M1A1/A2, the British Challenger 2 and the German Leopard 2A1/2A2
All vehicles have their negative points (sometimes all points are negative, like in the Sherman in WW2 or the pre-WW2 Russian tanks).
We don't know how many M1A1 or A2 have been destroyed, hit or damaged, because that is supposed to be classified information. Therefore we only have seen two M1 tanks destroyed, because the Iraqis took the area where they were destroyed, allowing the TV stations to broadcast the images.
At least one of the M1, was hit on the side, which is consistent with the use of more powerful anti-tank ammo, such as the Kornet.
We should remember the Palestinians destroyed some weeks ago a Merkava-II tank just by flaming the engine with a Molotov Cocktail.
I have nevertheless noted, at least twice, glimpse images of very damaged M1's and destroyed UMVEE's, on Sky News.
The lack of information is actually quite comprehensive in a situation of war.
I think the embedded reporters are a tactical problem, instead of a strategic advantage.
Although hit, the M1, is of course, one of the best tanks in the world. As all tanks, it needs infantry support. Without it the tank becomes vulnerable, especially in cities, where it's use is not advisable anyway.
L-188
RE: M1 Tanks
Thu Apr 03, 2003 3:56 am
You also had that Marine M1 that ran off the side of that bridge in the middle of a gunfight.
TSV
RE: M1 Tanks
Fri Apr 04, 2003 11:31 pm
Anyone know the winners of that Tank competition (run by Canada I think it is) over the last 20 years or so?
erj190
RE: M1 Tanks
Fri Apr 04, 2003 11:48 pm
There have been various comparison tests ran by various armies.
The most famous I know, (because it dealt with the supply of one thousand tanks) was held by the army of Saudi Arabia.
The competitors where the M1-A1, the British Challenger-1, the French AMX-30/40 and the Brazilian EE-T1 project.
The British tank and the French tank were soon set aside. The main competition was between the M1-A1 and the EE-T1.
In the end, after all the technical issues had been addressed, the ENGESA EE-T1 from Brazil was declared winner over the Abrahams M1-A1.
The fact that the Saudis had money to buy anything they wanted, and even so, they opted for the Brazilian project, is the best demonstration of which was really the best.
But, the influence the US administration had on the Saudi Royal family ended up deciding, in the end in favor of the US tank.
The Abrahams has in fact a number of faults, and even today there are many voices in the US military that are big critics of the model. The biggest negative point being that while in operation it needs refueling each 12 hours. The equivalent LEOPARD-2-A5, is heavier and better protected than the Abrahams, and in the same conditions needs refueling each 24 hours, because it uses a multifuel 12 cylinder engine, instead of a turbine.
TSV
RE: M1 Tanks
Fri Apr 04, 2003 11:51 pm
The one I'm thinking of is an annual (?) NATO (?) competition run by the Canadians. Can't recall what it is called. Must do a bit of research.
LHMark
RE: M1 Tanks
Fri Apr 04, 2003 11:55 pm
Well, whatever the Saudisactually purchased, I have a feeling it would have been M1s doing the lion's share of their defense.
"Sympathy is something that shouldn't be bestowed on the Yankees. Apparently it angers them." - Bob Feller
cfalk
RE: M1 Tanks
Sat Apr 05, 2003 12:01 am
Years ago when the Swiss Army ran a competition to select the tanks they would buy, it came down to the Leopard II in 1st place and the M1-A1 in second. I know a retired sergeant who was part of the evaluation team, and he said that the M1 would have won, except for its thirst and the requirement for different fuel from the diesel used in all the other vehicles, which required another logistics problem.
But what's this Brazilian tank? Since when does Brazil have any experience with tank warfare?
Charles
L-188
RE: M1 Tanks
Sat Apr 05, 2003 12:03 am
The diesel is more fuel efficent then the turbine but much heavier.
Besides there is one advantage to the turbine on the Abrams.
If it is wet day in the field it makes a very handy blow dryer for your gear.
Everything is nice and toasty.
toady
RE: M1 Tanks
Sat Apr 05, 2003 12:05 am
Tsv, the competition you're thinking of is "The Canadian Army Trophy" - or CAT.
http://www.3ad.org/cat_teams/default.htm
cfalk
RE: M1 Tanks
Sat Apr 05, 2003 12:08 am
L-188,
I was in a tank batallion, and while they were diesel, our tanks radiator vents on the back were wonderfully cozy on winter manoevers. Especially at the end of the day, as those heavy engines would keep warm a long time, and everyone would fight for the privilege of sleeping on it.
Charles
erj190
RE: M1 Tanks
Sat Apr 05, 2003 12:20 am
As I have said in my post the EE-T1 was a project, only a reduced number was produced. ENGESA, the manufacturer, spent one hundred million dollars in the development of the project. After the blow, of having won the technical part, but having lost the political issue, the company, found itself in heavy financial trouble and went bankrupt some years later.
ENGESA was one of the largest military vehicle manufacturers in the world.
IT produced the EE-9 cascavel 6x6 90mm gun (Iraq used lots of them in the war with Iran), the EE-T11 URUTU 6x6 Amphibious assault car, the EE-17/18 tank killer, the EE-3 4x4 Scout car, the XLP-10 tracked bridge-layer, the EE-T4 tracked scout car among others. There where other Brazilian manufacturers, such as Bernardini, and also Avibras and Avibras Aerospace. The latest famous for the production of the ASTROS-1/2 and recently ASTROS-3 Multiple Rocket launchers.
Iraq purchased many of them, but the Iraqi leaders were stupid in it's operational use. Some reports say that the "missiles" fired at Kuwait (yes, those that ended up not being SCUDS after all) where no more no less than old ASTROS rockets, fired without the help of their EDT-FILA targeting radar.
I suppose this answers about the Brazilian expertise in tank warfare. (they don't lack knowledge, what they lack is money)
racko
RE: M1 Tanks
Sat Apr 05, 2003 12:59 am
Who won the CAT competition in '91? The year 89 was somehow dominated by the Leopard 2.
GDB
RE: M1 Tanks
Sat Apr 05, 2003 6:00 am
Not a tank I know, but the news tonight had a British Warrior APC which had a RPG round buried in the additional armour fitted at the sides, the crew said another RPG had bounced off the front.
TSV
RE: M1 Tanks
Sun Apr 06, 2003 2:47 am
"The diesel is more fuel efficent then the turbine but much heavier."
Would definitely take the MTU over the Avco any day.
Users browsing this forum: 910A, BlueberryWheats, Flighty, vrbarreto, zckls04 and 44 guests
