Boeing Nut
The "tornado" Engine Accessory - Does It Work?
Fri Jun 27, 2003 1:18 am
Just curious to see if anyone has tried the "Tornado" engine accessory which is supposed to increase power and fuel economy. It kinda makes sence, but I'd like to hear from a "real world" user.
MaxPowers
RE: The "tornado" Engine Accessory - Does It Work?
Fri Jun 27, 2003 3:07 am
No, it does absolutly nothing...and I'm as serious as a heart attack. Your car needs one of those like you need a glock 9 to your face.
Max Powers.
aa61hvy
Fri Jun 27, 2003 3:20 am
It always looked so cool in the commericals, kind of like a mini-turbo.
Go big or go home
MaxPowers
Fri Jun 27, 2003 3:26 am
"It always looked so cool in the commericals, kind of like a mini-turbo."
Do you know what a turbo is?
N312RC
Fri Jun 27, 2003 6:36 am
a contraption that jams more air into the combustion chambers... idiot's explanation.
My views as expressed above are my views alone and do not constitute the views of my employer.
aa61hvy
Fri Jun 27, 2003 6:59 am
Max- I simply ment that the tornado spools up like a blower does and forces air down the intake.
Go big or go home
BlatantEcho
Fri Jun 27, 2003 7:04 am
AA61hvy-
surely this little thing you put in your intake box doesn't "Spool Up"
I mean, the only thing that COULD "spool it" would be in the incoming air, and obviously if the air itself is causing it to turn, well, it ain't going to have any energy of it's own to compress the air into the cylinders.
I believe the idea is simply to swirl the air, that will theoretically ensure a more complete mixture of the air and gas before it's injected into the cylinders.
George
aa61hvy
Fri Jun 27, 2003 7:06 am
I used to term spool up loosely. The air infact turns it  Wink/being sarcastic
Go big or go home
Boeing Nut
Fri Jun 27, 2003 7:26 am
Thank you Mr. Powers. You saved me some money.
MaxPowers
Fri Jun 27, 2003 10:34 am
Boeing Nut,
Here's a thought to back my opinion...
It's like putting a fan in your window, gluing the blades to each side of the window, and saying it's cooler in the room.
The "vortex" that it creates does not last. The "twisting" air WILL NOT swirl all the way into your cylinders. Though the idea is based on water and it shows it works well, the effect is not the same inside a car. Water is far denser than air allowing it's momentum to carry much farther.
People go and get it, spend an hour installing it into their car, and since the whole device is biased on saving gasoline, people are going to be driving more efficiently; not slamming the gas off of every light, etc. I think the thing has a "placebo effect". If someone spends 80 bucks on this, of course they are going to say it works no matter what....People want their purchases to work out.
Max
[Edited 2003-06-27 03:51:22]
DC10Tony
Fri Jun 27, 2003 10:50 am
That Tornado is a joke.
Any obstruction in your car's air flow will cause a decrease in air flow. You car won't suck in any more air with that little cookie cutter inside your air flow assembly box.
T prop
Sat Jun 28, 2003 7:54 pm
This thing is useless. The trick to good fuel economy is keeping your foot off the accelerator.
I'd like to see the tornado snake oil salesmen explain how the supposed 'tornado' of air created by this device gets around a huge restriction in the inlet path called the throttle plate. What are they gonna tell you, keep the throttle wide open so as not to interfere with the 'tornado'? What a load of crap.
The real beauty of this gadget is how it can lift money out of the pockets of the gullible.
T prop.
Users browsing this forum: SQ948 and 4 guests
