aak777
What Watch Do You Compare To "Tissot T-Touch"?
Thu Jul 31, 2003 11:52 pm
This watch gives the air temp,height and it works as a compass, do you know any other watches with similar functions?
Here is a link to a picture of it.
http://www.orolus.com/images/tissot/T33-7-488-61.jpg
ryanb741
RE: What Watch Do You Compare To "Tissot T-Touch"?
Fri Aug 01, 2003 1:46 am
I own a Tissot T Touch - it is my watch to wear as something I don't mind damaged - when I want to impress I wear one of my Breitlings.
The T Touch is quite good, although for the thermometer to work properly you need to take the watch off your wrist for 15 minutes otherwise your body temperature will affect the reading. Also, you need to reset the altimeter to the correct height regularly. Also, if the watch face is wet you cannot use the touch screen easily.
The T Touch is quite good value - it costs only £360 in the UK (USD $ 520) which is a bargain for all the functions it has. I have a silver dial on mine.
I used to think the brain is the most fascinating part of my body. But, hey, who is telling me that?
Users browsing this forum: Dano1977, petertenthije, salttee, scbriml and 1 guest
