cfalk
Windows XP Virus Help
Thu Aug 14, 2003 9:56 pm
Hi guys,
Knowing that there are several IT specialists here I'm hoping for some answers.
I've got a little problem with the computer virus which has been on the news over the past couple of days. Nothing really nasty, but about 5 minutes after you log on, a window pops us saying that your system will reboot in one minute.
There is a patch for this on the Windows Update site. But on the infected PC, it has an old-fashioned analog modem and there is no time to download the patch before the reboot happens.
I have 2 PCs at home - the one that I am using now, which is constantly updated and has all the patches, and the other one which is infected, which only gets used occasionally.
My question: Is there a way I can download the patch on this computer, put it on a CD-ROM, and run it on the other PC? I expect this will take a whole lot less time and would allow the patch to slip in before the reboot happens.
Can anyone tell me how to do this?
Charles
707CMF
RE: Windows XP Virus Help
Thu Aug 14, 2003 10:04 pm
Having encountered the same problem two days ago, I can assure you from my personal experience that you can do that. The file is less than 1 Mb, so it fits on a floppy disk without any problem.
I'll repost the link (works only for English versions of XP, but you'll find it easily on microsoft server if you have a foreign version)
http://www.microsoft.com/security/security_bulletins/ms03-026.asp
Hope this helps.
If you want to thank me, well, I've got a few unscreened pictures in the queue, so... a direct accept would be cool  Wink/being sarcastic
Antoine
racko
Thu Aug 14, 2003 10:08 pm
Lovsan loves you.
Ok here we go:
As soon as the window "Windows is gonna shut down in XX seconds" pops up, click on Start, then Run (Don't know the exact English names.), type "shutdown -a" and click on OK. Now your computer won't shutdown.
Now download this tool:
http://securityresponse.symantec.com/avcenter/FixBlast.exe
Download the tool and execute it. It will remove the virus from your computer.
Now you need to download the fix from Microsoft:
Go to http://www.microsoft.com/downloads/search.aspx?displaylang=en.
If you have Windows XP, download: "Blaster Worm: Critical Security Patch for Windows XP". Make sure to select the correct language.
if you have Windows 2000, download: "Blaster Worm: Critical Security Patch for Windows 2000". Correct language, as above.
Download it and install it.
Now you're fine. However, I would suggest you to use a AntiVirus Program and at least a Personal Firewall. PFs are not the best solution, but they are enough for daily use of the PC in most cases.
You can get a good free virus scanner at http://www.antivir.de.
For an easy-to-use freeware Personal Firewall, go to http://www.zonelabs.com
Hope this helps.
PS: I hate Microsoft. Had to edit this post 3 times until I got the links wrong with their damn asp.
[Edited 2003-08-14 15:24:59]
cfalk
Thu Aug 14, 2003 10:44 pm
Problem solved.
Thanks a million guys.
Charles
Andreas
Thu Aug 14, 2003 11:06 pm
Same here, thanks guys!!!
I know it's only VfB but I like it!
apathoid
Fri Aug 15, 2003 2:10 am
My only recommendation is that you run the Microsoft patch before you run the worm blaster .exe. If you do it the other way around, you risk re-infection before you get the hole plugged.
LHR340
Fri Aug 15, 2003 3:11 am
I had this aswell, all fixed via the windows update tool though, I never used it before, now I do  Big grin
LHR340
A340 LoVeR! EC-GQK - LHR The Bussiest International Airport & 3rd Bussiest In The World!
Users browsing this forum: agill and 1 guest
