KYIPpilot
Questions About Driving In England
Thu Nov 06, 2003 11:33 am
This is for those who know the English and American roads. I am thinking about traveling to England and would most likely rent a car. Besides driving on the other side of the road, how much different are the driving rules in England than America? I know the stearing wheel is on the right side also, but are the accelerator and brake pedals reversed also? Please fill me in with some general info. Thanks so much!
KYIP
"It starts when you're always afraid; You step out of line, the man come and take you away" -Buffalo Springfield
StarAC17
RE: Questions About Driving In England
Thu Nov 06, 2003 12:08 pm
No they're not reversed, but the turn signal and the winshield wiper controls are on the opposite sides. (I know this from Jamaica which also drives on the left so i don't know anything about British driving rules.)
Engineers Rule The World!!!!!
2912n
Thu Nov 06, 2003 1:22 pm
Pretty much the rules are the same, apply common sense. I think AAA has a book on European rules in general that you can get if you pick up an International License. (Some car rentals require this...God knows why since there is no test and it is not even issued by a government agency...)
The biggest problem I had was trying to look over my shoulder to back up. Habit has you putting your hand to the right rear and looking over your right shoulder...I don't know how many times I almost put my arm through the driver's side window! Be comfortable shifting as most of the rentals are standard transmission. If you don't want to deal with that be sure to ask for and reserve an automatic. They are limited in availability.
Roundabouts are something to get used to, but once you figure out the traffic flow you will wonder why we don't have them here. Just chant the mantra of "Keep to the LEFT." The first time you goof and see some big ass lorry coming right at you you will remember!  Smile
paulc
Thu Nov 06, 2003 4:56 pm
There is no equivalent to the USA's 'right turn on red' - if you jump a red you could be in trouble.
The traffic light sequence is different also - in the UK Red = Stop, Red & Amber = get ready to move off, Green = Go. This is followed by a single amber light = get ready to stop then Red to stop. You are allowed to go through on amber if there is a risk of causing an accident by braking hard (esp if wet).
Lane discipline at roundabouts can be tricky - remember to keep left if going left or across, right if going right - you will find people in the right lane who will want to go straight across - ok if the exit has 2 lanes - not so good if there is only one. Also give lorries with trailers plenty of room at roundabouts as they will be in the left lane when turning right to allow the trailer to swing round.
Speeds on motorways will probably be more than you may be used to - dont panic - stick to the limits and you will be ok.
Overtake on the right on motorways not the left (although this is permitted in some circumstances - queues/road works etc)
Motorway signs tend to be better here than in the USA (in my experience) but as motorway speeds are higher a bit more anticipation may be needed ie getting into the correct lane well ahead of the junction. Motorway junctions are normally shown as 1 mile ahead so that gives approx 1 minute (at 60mph) before the exit slip and you will need to be in the left (inside) lane.
Get an auto if that is what you are used to driving - manual transmission takes a while to get right.
Get familiar with the controls before driving away - especially light/indicators/wipers/boot(trunk) release/fuel filler release/bonnet (hood) release - they can be tricky to find in a strange car (esp in the dark)
hope this info is useful
English First, British Second, european Never!
saintsman
Thu Nov 06, 2003 4:57 pm
The biggest difference between USA and UK (and Europe come to that) is SIZE. The roads are so wide in the States and usually multi lane. We just don't have the space over here. Most roads have one lane per side unless you are on the major roads between towns and cities and even then you will rarely get more than two lanes.
You cannot turn left on a red light if it is clear like you can do a right in the States and watch the speed limits - There is an abundance of speed cameras where ever you go now.
When you hire your car you are more than likely to get a manual shift, especially on the budget cars. Book in advance if you want automatic.
Don't worry about it, just enjoy the experience.
bobrayner
Thu Nov 06, 2003 8:45 pm
If you'll be driving for long, get a copy of the "Highway Code" - a large newsagent, or maybe a bookshop, should have it. It's a standard handbook that apparently details all the driving rules (whether law or just common-sense or etiquette) about driving in the UK, although most drivers seem to forget it pretty quickly  Big grin
Try this:
http://www.highwaycode.gov.uk/drivers.shtml
There are some simple conventions on signs, so it doesn't take long to learn what each sign should mean, &c &c.
As everybody has said, try to book in advance if you want an automatic, though it's pretty common on the more expensive rentals. You might have to spend some extra time explaining your driving license to them if you don't have an IDL. Try to bring along some alternative ID (passport?), and more than one form of plastic, just in case.
Compared to the rest of Europe, the UK is a little stronger on lane discipline. If you have more than one lane to choose from, keep to the left.
Speed limits? If there's no sign telling you otherwise, assume 30mph in towns, 60mph on the open road, and 70mph on the motorway. Don't worry too much about speed cameras - if you stay close to the law, you're fine.
Cunning linguist
UTA_flyinghigh
Thu Nov 06, 2003 9:08 pm
Yes if it's a Japanese, Korean or UK make, but no if it's a French or German make. I've had a Renault Clio, Mazda 626, Fiat Brava and a Toyota Corolla (all in 5months ! Sob ! ), the Fiap and the Renault were on the same side as left-hand drive cars, not the Japs. Which is facheux when I take my GF's Accent, left-hand drive of course.
Fly to live, live to fly - Air France/KLM Flying Blue Platinum, BMI Diamond Club Gold, Emirates Skywards
Banco
Fri Nov 07, 2003 1:27 am
To be honest, most of the Japanese manufacturers have now abandoned this practice as well. Most of the big car markets drive on the right, and everyone is now used to it, so you probably won't have to worry about it all. Even if you do, it only takes a few minutes to get used to it.
I'm just wondering KYIPpilot, whether you are going to be picking up your car from Heathrow airport? If so, you will need to prepare yourself for joining the M25, the busiest road in Europe, for the first time. The technique adopted by natural born Brits around the western section is to hare down the slip road at about 90 mph, get in front of the lorry on the inside lane, and then slam on the brakes because there's a queue up ahead. DO NOT BE ALARMED! British drivers are actually quite courteous and they will let you in. Just drive normally. The M25 is a nightmare, it isn't all like that, but I have met numerous American tourists who have broken out into a cold sweat when talking about that motorway, because they weren't prepared for it.
She's as nervous as a very small nun at a penguin shoot.
2912n
Fri Nov 07, 2003 2:26 am
If you can drive in LA, Chicago, New York or any other major American metro area you can drive on the M25. After all, it is known as the worlds largest car park! (It frequently comes to a dead stop...)
What can really be an adventure is wandering off on a country lane that is maybe a foot wider than your car and then meeting up with a lorry coming at you....You really learn your backing skills!  Smile
KYIPpilot
Fri Nov 07, 2003 2:29 am
Wow, thanks guys for all the info! I have not planned a trip yet, but I am really interested.
Banco
Fri Nov 07, 2003 2:38 am
Agreed. It's just joining it for the first time that tends to freak people out. Incidentally, other nicknames for it include "The Magic Roundabout" and of course Chris Rea's "Road to Hell" was a paean to that fine circle of concrete and tarmac.  Smile
essjay
Fri Nov 07, 2003 4:13 am
One piece of advice if you're going to be driving in England: stay the hell away from London!  Wink/being sarcastic
Actually, it's not that bad if you know where you're going, but don't be in anything resembling a hurry...
If you're going to rent a car in London, check out easyCar (www.easycar.com). They are really quite cheap and (depending on rental location) you can rent a wicked Mercedes-Benz A-Class.
I rented a car 3 times from easyCar's Shepherd's Bush (London) office and all 3 times I got a A160 AvantGarde Automatic (which may be good for you if you are like most Americans and cannot drive a Manual or what y'all call a "stick"!) - sorry, just taking the piss there!  Smile/happy/getting dizzy
fspilot747
Fri Nov 07, 2003 4:24 am
"but are the accelerator and brake pedals reversed also? "
Nah. Them Brits aren't THAT screwed up  Big grin
FSP
Banco
Fri Nov 07, 2003 4:43 am
In that case, it's about time we mounted a campaign to get them changed around. Can't have you lot coming over here thinking it's pretty normal.  Big grin
N312RC
Fri Nov 07, 2003 4:50 am
not necessarily driving related, but make sure when crossing the street in England you look the opposite way for oncoming traffic as you would here.. its actually painted on the road. I almost got smashed when I went..
My views as expressed above are my views alone and do not constitute the views of my employer.
Banco
Fri Nov 07, 2003 4:53 am
That's how we control the numbers of visiting tourists N312RC.  Big grin
N312RC
Fri Nov 07, 2003 4:56 am
I dunno what would have been worse, a victim of a Vauxhall or a victim of the NHS!
Banco
Fri Nov 07, 2003 5:00 am
Oh a Vauxhall, without question. You see, at one time the NHS was a beacon to the world, the very best at what they do. Now Vauxhall, on the other hand, have always been crap.  Big grin
bobrayner
Fri Nov 07, 2003 5:19 am
It's pretty difficult to get fatal injuries from a collision with a Vauxhall.
The top speed is 30 mph (no km/h here!) and they're made of MDF.
Opel, on the other hand, are vastly superior. Of course.
Cunning linguist
airjampanam
Fri Nov 07, 2003 6:08 am
If you have never driven on that side, and you just must drive in the UK, I suggest you have someone with you to remind you to GET OVER, when you make turns into the wrong lanes around corners etc.
The round a bouts will drive you batty as well.
I spend a lot of time in London every year, and I NEVER drive for all those reasons and more, and I grew up in the Caribbean where we still drive on the left.
Suing is the new Lotto... if u wanna win u gotta sue!
2912n
Fri Nov 07, 2003 6:15 am
If you really want to get screwed up try Hertz's "Le Swap" program where you rent a rt hand drive in England, then take the Channel Tunnel over to Calais where you pick up a "normal" car...then on the way back you swap again. It got to the point where in France I was going the wrong way on their roundabouts and trying to shift with my left hand...YIKES!  Smile
Even my Brit friends try not to drive when going into London. Take the train in and then taxi or tube everywhere. Much easier!
And remember that the Brits are the best about giving road directions. I have seen grown men fight over who gave the best route somewhere!! (read the 1st chapter of Bill Bryson's "Notes from a small island" I thought he was kidding till I made my first trip over!)
Arsenal@LHR
Fri Nov 07, 2003 6:50 am
If you're hiring a car, 9 times out of 10 it will be a manual transmission so unless you're prepared to declare war on the gearbox, hire a auto. Specially so in London, this place is choked with stop-start traffic with narrow roads. But once you get out of London into the quiet country lanes and suburbs, it can be a joy to drive. Don't let this put you off though, if you want test your driving skills, you're in the right country!  Big grin
In Arsene we trust!!
KYIPpilot
Fri Nov 07, 2003 8:21 am
Thanks Arsenal. I can drive a manual trans here in the states, but I don't think its worth shifting with my left and fighting with just for a week or less. I would try to reserve an auto trans. Plus, I don't plan on driving in London anyway, just in the country side, especially in Norwich.
ybacpa
Fri Nov 07, 2003 9:21 am
If you are renting a car you can often request one with left-hand controls. Most of the larger renters, especially the US-based chains, have some in their fleet. You'll almost definately pay more for it though. Personally, though, I've found driving on the right side of the car to be more difficult than driving on the left side of the road.
Oh, and GET INSURANCE! Chances are your personal auto insurance doesn't cover you over there, and credit card insurance is iffy at best.
SkyTeam: The alliance for third rate airlines finally getting their act together!
bobrayner
Fri Nov 07, 2003 11:30 am
Insurance? Don't worry about that.
The rental co can make lots of money on insurance... they'll be sure to offer you some. ISTR it's illegal for them to let you drive off the forecourt without the minimum insurance requirement (IE third-party) anyway.
Cunning linguist
bhill
Fri Nov 14, 2003 1:54 am
The Brits arent that screwed up??...Whatta 'bout King Dick and Whitworth?
;-}...just foolin...I have an MG
Bob
Carpe Pices
silverfox
Fri Nov 14, 2003 4:25 am
Driving around Norwich
Watch out for the mountain passes!
And it might be a good idea if, when you arrive, to get a listee who lives near the airport to drive you around for an hour or so , so you can ask questions and get the 'feel' of what to do BEFORE you get behind the wheel. If you are coming into Heathrow, the M4/M25 is NOT the place to start learning, esp Fri pm
Users browsing this forum: Calder, Scorpius, senbdq, speedygonzales and 43 guests
