Jkw777
How Much Thrust Does A Shuttle On Launch Produce?!
Sun Jan 11, 2004 5:43 am
As per the Topic...
How much is is?! Big grin
Justin  Smile/happy/getting dizzy
jkw6210@btopenworld.com or +447751242989
Jkw777
RE: How Much Thrust Does A Shuttle On Launch Produce?!
Sun Jan 11, 2004 6:26 am
Edit:
As per the Topic...
How much is it?! Embarrassment
Arsenal@LHR
Sun Jan 11, 2004 6:38 am
I don't remember where but i heard it generates 1 million lbs of thrust, i.e over 10 GE-powered 777's. I could be wrong.
In Arsene we trust!!
galaxy5
Sun Jan 11, 2004 6:50 am
Each engine has three primary levels of thrust or power - minimum, rated and full power. Engine thrust, however, can be varied throughout the range from minimum to full power level depending on mission needs. Shuttle payloads will be sized to be compatible with launch-to-orbit at a maximum of 104 percent of rated power level, with each engine developing 2,174,286 Newtons (488,000 pounds) of thrust, 1,734,803 Newtons (390,000 pounds) at sea level. full power level (109 percent of rated power) will be available for use in emergency situations. During the latter part of ascent, engine thrust will be reduced to insure that an acceleration force of no more than three times that of Earth's gravity is reached. This acceleration level, permitted by the throttleable Shuttle engines, is about one-third the acceleration experienced on previous manned space flights and is well under the physical stress limits of non-astronaut scientists who fly aboard the Shuttle. The lowest thrust throttle setting - minimum power level - equals 65 percent of rated power.
"damn, I didnt know prince could Ball like that" - Charlie Murphy
BlatantEcho
Sun Jan 11, 2004 7:29 am
I think that works out to 1.2million lbs of thrust or so? That is the figure I remember anyway.
George
They're not handing trophies out today
Staffan
Sun Jan 11, 2004 7:32 am
Don't forget about the solid rocket boosters. They add a considerable amount of thrust too.
Staffan
B2707SST
Sun Jan 11, 2004 9:01 am
According to NASA, each solid rocket booster provides about 3.3 million pounds of thrust at takeoff. As Galaxy5 mentioned, the three hydrogen-burning main engines provide another 393,000 pounds of thrust each, or 1.179 million pounds for all three.
Total system thrust at takeoff is about 7.779 million pounds. The orbiter/SRB vehicle weight at takeoff is usually around 4.5 million pounds (the orbiter and payload typically account for about 270,000 pounds, the rest coming from the solid rocket boosters and the liquid hydrogen external tank).
--B2707SST
Keynes is dead and we are living in his long run.
