Temperature Of Graphics Card
Sun Feb 08, 2004 11:29 pm
Is there any program I can use to take the temperature of my graphics card?
Regards..
Chris
photopilot
RE: Temperature Of Graphics Card
Mon Feb 09, 2004 12:05 am
NO. Temperature cannot be measured by software alone. There must be a physical measuring device, either electrical or mechanical.
Try a thermometer.
gordonsmall
Mon Feb 09, 2004 1:50 am
Well, it depends.
If your graphics card has a built in thermocouple (as many of them do) then yes, it is possible to measure the temperature using software, just as you can measure the temp of your CPU, Motherboard etc - do a search on the net to find out if your card has the hardware required and software available to do this.
The ATI Radeon in one of my work PC's has a built in thermocouple, and I got a utility program along with it to query it's temperature. I can also query it by probing the hardware directly through some code.
Gordon.
Statistically, people who have had the most birthdays tend to live the longest.
Mon Feb 09, 2004 2:56 am
I have an ATI card.. can you give me a link or the name of the utility you use..
Thanks..
Chris
Mon Feb 09, 2004 4:53 am
If your card is so equipped you most likely have the software on the CD that came with the card.
Users browsing this forum: drew777, ThePointblank and 1 guest
