aak777
Can You Help Me Solve This Problem!
Tue Feb 17, 2004 11:03 pm
If i have airplanes height, true air speed, rate of descent, how can i calculate my ground distance. At calm wind.
can you provide me with a formula with thse variables,
THANKS
Qb001
RE: Can You Help Me Solve This Problem!
Wed Feb 18, 2004 12:31 am
Not sure I understand. Is it to determine the TOD, that is where to begin the descent to the airport?
Never let the facts get in the way of a good theory.
aak777
Wed Feb 18, 2004 1:19 am
Nothing to do with take offs and landings, only pure descent from one level to another, given the info above.
MD11Engineer
Wed Feb 18, 2004 1:27 am
Out of the altitude difference and the climb / sink rate you can easily calculate the time required to climb / descent to the required FL. Then multiply this time with the TAS and you get the distance flown ( this works only at 0 windspeed, once you´ve got a wind involved you´ve got to do a little vector subtraction / addition)
Jan
Users browsing this forum: aaden, B777LRF and 2 guests
